Hello everyone!
I am re-making an old project. It used to run on Arduino + Processing but a friend recommended me to use a Teensy because it can play audio by itself and it is reliable for a LONG term project.
This is the first time I will be using a Teensy so I am very excited to learn how to use a new tool.
First I want to buy a Teensy Board and I wanted to know which one would you recommend me to buy for this project??
The project is not that complicated.
Basically I need 4 inputs (4 Buttons) and 4 outputs (4 LEDs) and a good quality speaker. I am planning on having everything Run on 5V.
The system works like this :
When I press button 0, LED 0 will light up and start playing Song 0
When I press button 1, LED 1 will light up and start playing Song 1
When I press button 2, LED 2 will light up and start playing Song 2
When I press button 3, LED 3 will light up and start playing Song 3
The code is al ready figured out (I think it will be the same I used with the Arduino and play a little bit with it to replace what Processing did)
I saw the Teensy Audio Tutorial & Workshop and they use a Teensy 3.2 and an Audio Shield is this my best option?
Since that video was made in 2015 I was wondering if maybe I should just use the Teensy 3.5 or 3.6? Or do I really need to have the Audio Shield to make this project work?
Thank you very much for your help!!
