Results 1 to 5 of 5
Thread: Voice Transmission using Teensy+ Audio Shield+ NRF24L01
    Feb 2018
    3
    I wish to send audio through wireless. For this purpose I used one teensy+audio module (SGTL5000)+NRF+microphone in Transmitter side and same setup with an extra loud speaker on Receiver side. I am using RF24 library to communicate NRF24l01. When i switch on the circuit, audio transmission occurred. But noise level is very high & very hard to hear the voice from mic. I am attaching my code. Please verify and help me to over come this issue.
    ASHYMON
    Attached Files Attached Files
    Feb 2018
    3
    // Transmitter
    #include <SerialFlash.h>
    #include <nRF24L01.h>
    #include <RF24.h>
    RF24 radio(32, 31); // CE, CSN
    const byte address[6] = "00001";
    AudioInputI2S            i2s1;           //xy=206,128
    AudioRecordQueue         queue1;         //xy=437,134
    AudioConnection          patchCord1(i2s1, 0, queue1, 0);
    AudioControlSGTL5000     sgtl5000_1;     //xy=394,305
    uint8_t bufr[256];
      AudioMemory(64);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.8);
      SPI.setMOSI(28);
      SPI.setMISO(39);
      SPI.setSCK(27);
      radio.begin();
      radio.openWritingPipe(address);
      radio.setPALevel(RF24_PA_MIN);
      radio.setDataRate(RF24_2MBPS);
      radio.stopListening();
      queue1.begin();
      if (queue1.available() >= 2) {
        memcpy(bufr, queue1.readBuffer(), 32);
        queue1.freeBuffer();
        radio.write(&bufr[0], 32);
    Feb 2018
    3
    //Receiver
    #include <RF24.h>
    AudioPlayQueue           queue1;         //xy=299,187
    AudioOutputI2S           i2s1;           //xy=587,179
    AudioConnection          patchCord1(queue1, 0, i2s1, 0);
    AudioConnection          patchCord2(queue1, 0, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=393,311
      AudioMemory(64);
      sgtl5000_1.volume(0.5);
      SPI.setMOSI(28);
      SPI.setMISO(39);
      SPI.setSCK(27);
      radio.begin();
      radio.openReadingPipe(0, address);
      radio.startListening();
    if (radio.available()) {
        uint8_t text[32];
        radio.read(&text, sizeof(text));
        Serial.println(text[0]);
        Serial.println(text[15]);
        Serial.println(text[31]);
        int16_t *p=queue1.getBuffer();
        memcpy(p, text, 32);
        for (int i=32; i < 256; i++) {
                *((char *)p + i) =0;  // fill rest of buffer with zero
        queue1.playBuffer();
    Jul 2018
    6
    Hi, there
    I was trying to do something similar to what you were doing. Did you manage to fix the noise problem?
    I tried using you code, changing the mic with the Line In. I'm using a Teensy 3.6, which one were you using? Also, I see you were setting pins 31 and 32. But it seems those pins represent SPI1. I read a comment saying that some libraries use SPI0 only, and that there must be made some serious changes to use SPI1 and SPI2, but I'm not so sure.
    Jan 2019
    7
    Hello!
    Did anyone have any success with this????
    I'm trying the exact same thing and getting the same result.
