Page 33 of 74 FirstFirst ... 23 31 32 33 34 35 43 ... LastLast
Results 801 to 825 of 1849
Thread: Project: SPI_MSTransfer
  1. #801
    Dec 2016
    Montreal, Canada
    3,379
    i might work on a new feature of circular buffer for different usage capability
    if you need a queue updated before it gets pulled ill have an updater function iterate over the arrays to find a match, then replace it with current updated array
    this could be a major feature that others might use! (ex serial output to uart displays as example)
  2. #802
    11,837
    My kitchen sink is good, though needs a new faucet - I do need like 3 bathroom sinks - can you put those in before the kitchen sink?
    Could the user get data pointers and methods to do things like that manually? That is: is enough stuff public to allow a user to do this kind of stuff in their own code?
    Someone will always want something a bit different ...
  3. #803
    Dec 2016
    Montreal, Canada
    3,379
    yeah but if i do the iterator and update built in, its less work for user and code, secondly, it can do it “behind the scenes” on the queues not accessible to user (between head and tail)
    currently its not possible to do this
    even i might have a use for this making another library for other project
  4. #804
    11,837
    So that is a no on the bathroom sinks then?
    By all means if it is simple and could be useful and not fatten the code GitRDun. Just wondering if it could be done with user code - or if a simple change to support it would allow that or similar features without editing the core code. I'd have to read it again to see the use case for what you want to add - so it seems about as odd as bathroom sinks when everyone always wants the kitchen sink thrown in
  5. #805
    Dec 2016
    Montreal, Canada
    3,379
    user has access to head and tail (fifo/lifo) not in between
    my proposal is if a user was writing commands to a device and the same command had a comparator of the first 3 bytes (3 being specified by user) and it still existed in queue before being pushed to the device (lcd), the entry would be updated rather than appended to a new entry thereby preventing duplicates while keeping queue entries up to date
  6. #806
    Dec 2016
    Montreal, Canada
    3,379
    of course if u dont use that feature it wont affect current system, it will be a new method for its usage, that goes from head to tail entries in a circular fashion to update the queue entry if a match was found
  7. #807
    Dec 2016
    Montreal, Canada
    3,379
    i could add the sink too, but i dont want any leaks
  8. #808
    Dec 2016
    Montreal, Canada
    3,379
    just got home and its still 0 errors tim, pushing 49uS with debughack data callbacks both ways 10ms both sides sending each other
  9. #809
    New York
    5,373
    Doesn't sound like you have any leaks yet
  10. #810
    Dec 2016
    Montreal, Canada
    3,379
    yeah, i moved back to yours now, just cuz i like to see both sides hammering each other at 0ms rates
    EDIT 10:52am, theyre still going crazy at each other, the mcu cores are not hot either, running quite stable
  11. #811
    Dec 2016
    Montreal, Canada
    3,379
  12. #812
    11,837
    Updating to github SPI_MSTranfer code
    T_3.1 Slave to T_3.6 running since 3/11- about 9 days. :: F&F (OT=4)micros() _time==56
    The first three were there with 'reset' of the Slave.
  13. #813
    11,837
    Master T_3.6 and Slave T_3.1 compiled and running fine.
    Still 10 LED pinToggle per second at 500 Hz :: if ( millis() - _timer >= 2 )
    Split the DEBUGHACK to F&F_PacketID==60.
    > Works
    Modified Master to send #60 and then about every 25 sent a standard #55 so lots of short DEBUGHACK prints with an occasional Full Print from the Slave. Had to put in a JUMP +12 after a #55 precedes a #60, or it reported failed missed 12.
    Then modified Slave to "NVIC_SET_PRIORITY(IRQ_SPI0, 99)" - I saw one batch of failures go by and correct. And another two or so have happened as well:
    M >> F&F (OT=15)micros() _time==51
    S >> 25388.000000, 0.0254, 0.0254,1454797.000000,1454854.375000,25393.0000, 159.3549, 159.3581, 159.3612,25397.0000,25398.0000,25399.0000
    S >> 25400.00, #, #, #, #, #, #, #, #, #, #, #,361916,17
    After 165,000 F&F's I set the NVIC_PRI to 19 and restarted, no errors after the one reported by SLAVE on startup.
    Added specific counter to do a #55 after each 25 #60's - Master show's 0 OT's and Slave reports 15 failures after 890,000 F&F's [ plus 1/25th more for the #55's I sneak in ]
    <EDIT>: Finally captured the error info - it is overlap on wrap around on the 65536 tracked value with intermixed #55's- ... added fix for that and also the startup case where #55 precedes #60
  14. #814
    Dec 2016
    Montreal, Canada
    3,379
    mine still pounding 0ms rates from both ends 0 OTnvic set at 0 here
  15. #815
    Dec 2016
    Montreal, Canada
    3,379
    i saw a thread somewhere where paul mentioned theres no set priorities lower than 32, 0-31 should be okay, but because the master deserves priority access i think we should keep it highest priority(<32) so it can manage the slave over SPI
  16. #816
    11,837
    NO LONGER SEEING ANY ERRORS - they were all caused by altered Master output test path replacing DEBUGHACK that needed catching in Slave.
    tonton81 - made a Pull Request to get updated versions with new names for TVMaster and TVSlave.
    Left the lowered priority at #19 :: NVIC_SET_PRIORITY(IRQ_SPI0, 19); // set priority
    Compiled and tested with current CircularBuffer version of SPI_MSTransfer for my T_3.6 Master and T_3.1 Slave combo. It cleaned up the primary TVslave TViewer #55 F&F used for the IMU_GPS code, remove unused configs.h file.
    Added a TVslave #56 placeholder if anyone wants to format a new TViewer string
    Modified TVMaster and TVSlave to push/accept #60 F&F's that are printed in the slave as DEBUGHACK was - Terse output
    TVMaster as provided will push out a #55 normal FULL LENGTH TViewer string after each 25 #60's - proves output can work and quick USB stress for longer string
  17. #817
    Dec 2016
    Montreal, Canada
    3,379
    since CB is part of the library you can add in-sketch buffering for other things, portability is awesome
  18. #818
    11,837
    For some reason I recall Paul noting that the 256 PRI levels are banded in groups of 8, i.e. 0-7 (etc) are treated the same? I picked 19 as in any case that allows at least two levels of higher priority. For some reason I saw error cascades as noted at pri==99.
    So far after last re-compile before pull request is over 730K F&F's with ZERO errors noted on either end.
  19. #819
    Dec 2016
    Montreal, Canada
    3,379
    its a shame how c++ stl containers can cause so much damage when dealing with ISRs, no reason to use them anymore at this point with cb-ca, although my other library uses it, it doesn’t use it in an ISR so I can leave it like that
    we could also create a circular debug buffer, and have a central switch, where it would print from the loop instead of the ISR, maybe 32 or 64 uint8_t circular queue (non array version)
    that way we dont need ( if debugSerial != nullptr ) in all the debug locations, we can print directly to the buffer and only have 1 condition check during loop
  20. #820
    11,837
    I mentioned debug buffer before. My use case was log EVERY character of SPI transaction with time since prior character (whatever might be meaningful to understand where the errors creep in) - if it succeeds - delete the entry. Time could be with CycleCounter - millis too low res and micros() too much overhead. Not sure what else could matter or point to any common point of messages failing?
    But yes, that could then be handled AFTER the fiasco clears outside the isr - or even the Master retry - those master retry messages are way too long - they could be very very short during retry - and then when succeeded the verbose data could be shown could.
    <edit> OF COURSE my demo is about 1.6 M F&F's and no error so it would be a good test of cb utility and speed - and when an error shows up - we might no why?
    Could keep the last 5-10 errors and then print on request of the SerMon
  21. #821
    Dec 2016
    Montreal, Canada
    3,379
    only reason i made the retry long was to make it easier for me to see it blip at high speeds :P
  22. #822
    11,837
    Having a static ca of logged errors could allow dumping it on command from the Serial SerMon Terminal.
    My combo 30 MHz SPI on the TV examples with T_3.6/T_3.1 shows No Errors:
    Master== (OT=0)
    Slave notes 15,846,807 #60 debug F&F which also implies 633,872 Full #55 prints and 316,936 pinToggles:
    37016.00, #, #, #, #, #, #, #, #, #, #, #,15846806,0
    37028.000000, 0.0370, 0.0370,2121720.000000,2121777.250000,37033.0000, 192.4422, 192.4448, 192.4474,37037.0000,37038.0000,37039.0000
    37040.00, #, #, #, #, #, #, #, #, #, #, #,15846807,0
  23. #823
    Dec 2016
    Montreal, Canada
    3,379
      Circular_Buffer<uint8_t, 64> c5;
      Serial.println("----------------------");
      c5.print("Hello SPI_MSTransfer, ");
      c5.print("from ");
      c5.println("tonton81");
      while ( c5.size() > 0 ) {
        Serial.print((char)c5.read());
      Serial.println("Proof the newline was carried into queue");
    console:
    Hello SPI_MSTransfer, from tonton81
    Lets do the reverse read:
      c5.print("from ");
        Serial.print((char)c5.pop_back());
    Output:
    18notnot morf ,refsnarTSM_IPS olleHProof the newline was carried into queue
    oh dear lord, how silly of me, why dont i buffer those prints?
    template<typename T, uint16_t _size, uint16_t multi>
    void Circular_Buffer<T,_size,multi>::print(const char *p) {
      if ( multi ) return;
      for ( uint16_t i = 0; i < strlen(p); i++ ) write(p[i]);
    void Circular_Buffer<T,_size,multi>::println(const char *p) {
      write('\n');
    becomes:
      write((T*)p,strlen(p));
      write('\n');
  24. #824
    Oct 2016
    16
    Hi All,
    I've been reading throughout development of this library and decided it's time to try it myself. Unfortunately, I'm having trouble getting the master and slave to communicate.
    I used the wiring as described here, running the TVmaster and TVslave examples with no modifications from the "eaeb407" commit (latest at the time of posting). Master is the 3.6 and the slave is the 3.2. Both are confirmed to work well, and the connections tested for continuity.
    Here is an image of my setup: https://imgur.com/a/gFZhF#QK0aQln
  25. #825
    Dec 2016
    Montreal, Canada
    3,379
    wheres the ground signal between both? the high speed SPI needs a link between, not common
    the chipselect wire is missing. the slave chipselect pin is PIN 2. tie it to a master gpio, and use the pin in the master’s constructor in the sketch
    just rechecked, your ground link is fine, but you need chipselect (CS) wire, can be any master pin, but must be pin2 of slave
