Page 34 of 74 FirstFirst ... 24 32 33 34 35 36 44 ... LastLast
Results 826 to 850 of 1849
Thread: Project: SPI_MSTransfer
  1. #826
    Oct 2016
    16
    Hi tonton81,
    You were right that a wire was missing, but the ground wire is the green one in my setup. I was missing the CS line, now added between 15 on 3.6, and 2 on 3.1. Now everything is working great! Sorry about the rookie error!
    I'm hoping to use this to talk to multiple slaves, I will post my benchmarks as soon as I am able.
  2. #827
    Dec 2016
    Montreal, Canada
    3,377
    awesome, keep us posted. it should work with multiple slaves, make sure all the MISO/MOSI/SCK are all parallel, and run a different pin of master for each chipselect. get ready for 30mhz data transfers
  3. #828
    11,764
    I updated Post #1 to include link to GITHUB and added line to show GND must be connected.
    Update on T_3.6 & T_3.1 pair : NO Master OT, but one Slave miscount after 27.6 M F&F's :: 54380.00, #, #, #, #, #, #, #, #, #, #, #,27644545,1
  4. #829
    Dec 2016
    Montreal, Canada
    3,377
    not bad
  5. #830
    New York
    5,322
    Not too shabby
  6. #831
    Dec 2016
    Montreal, Canada
    3,377
    maybe it would still be 0 if nvic was set to 0 instead of 19, but youll need more patience
  7. #832
    11,764
    Very Good - 1 error :: 30,965,647 F&F's ++
    If we only had a way to log the error behavior that wouldn't scroll off the screen
    If nothing in the system uses pri # under 31 or more than - the value should be the same.
    I want to drop down to lower SPI MHz - based on prior posts - it will start failing and we'll have no way of seeing internal details that might suggest why.
    I need to fire up the CycleCounter to get a usable time base. Given that 100 bytes transfer in 50 uS - that resolution would be meaningless - and expensive. Even the T_3.1 will break that up into 96 points to see if the byte to byte are oddly timed or something.
  8. #833
    Dec 2013
    281
    Hey guys i know this is a bit off topic but it's too funny not to post.
    My first master and slave SPI implementation on ATmega328P.
    I even had a nickname for this ( MonsterSlaveDuino ).
ID:	13352Click image for larger version.
  9. #834
    11,764
    Started T_3.6 M to T_3.1 Slave at 12 MHz SPI and no errors at 600K F&F's. SPI transfer time is 94-95 uS, up from 51 uS at 30 MHz.
    >> All but Total fail at 1 MHz and 3 MHz. Have another T_3.6 on breadboard and a T_LC I'll wire and try
    @Chris O.- that looks unethical.
    tonton81 - another pull request :: I checked in the TVslave.ino with defines.h file removed - but left in the #include
    Also there I showed starting up the CPU CycleCounter. System (register?) value 'ARM_DWT_CYCCNT' can be used just like microseconds with uint32_t, it wraps in about 17.89 seconds at 240 MHz. I might start a 'ca' log if you don't.
  10. #835
    Dec 2016
    Montreal, Canada
    3,377
    down to 8 is no problem, its when you go lower
    a ca logger :P
  11. #836
    11,764
    a ca logger :P
    A good place to show it used - low overhead. If the transaction succeeds - delete the entry. Leave it as a record when it fails.
    Might be nice to have a message from Slave>Master:: SPI_delay( x ); // don't send for x micros though not sure where that goes?
    Perhaps:: Both Master and Slave: on entry record uint32_t StartCCV=ARM_DWT_CYCCNT, then push this struct:
    each event: ENUM { Start, Tx, Rx, ... , CRC Err, Resend, ... }
    Xfer_Word#
    Tx/Rx value
    Time offset from :: ARM_DWT_CYCCNT - StartCCV
    ? Anything else of value ?
    Context on post #835? NVIC Pri #?
    Post #834 M&S F&F now no errors at 1.14 M
  12. #837
    Dec 2016
    Montreal, Canada
    3,377
    have the master send a simple array to slave and slave return it and master return it like ping pong, see where it fails
  13. #838
    11,764
    With added logging that could be a controlled way to see what the behavior is. The Master would have controlled send rate that would HALT on Error on either end. And either end could print the logged process details without causing more errors or having the log data interrupted by ongoing transfers.
    Terminated my MS::T_3.6&T_3.1 with no errors at 17,232,121 :: 52112.00, #, #, #, #, #, #, #, #, #, #, #,17232121,0
  14. #839
    Oct 2016
    16
    Improvement to slave handling
    Hi Tonton81,
    For my uses with multiple slaves, the amount of them fluctuates throughout operation. In an ideal system, I can use the same handler to parse the data of each slave, but without knowing which slave the handler got data from, it's quite difficult. To solve this, I added the current chip_select data to AsyncMST and a corresponding line to events(). With this, the handler is able to distinguish which slave the data comes from with minimal changes to the code:
    Inside SPI_MSTransfer.h
    struct AsyncMST {
      uint16_t packetID = 0;
      uint8_t error = 0;
      uint8_t chip_select = -1;
    Inside SPI_MSTransfer.cpp, around the line 1630:
              if ( buf[1] > 4 ) {
                uint16_t _slave_array[buf[3]];
                memmove (&_slave_array[0], &buf[5], buf[3] * 2 );
                AsyncMST info; info.packetID = buf[4];
    	    info.chip_select = chip_select;      // The new line
                _master_handler(_slave_array, buf[3], info);
                spi_port->transfer16(0xD0D0); // send confirmation
                SPI_deassert(); return 0x00A6;
  15. #840
    Dec 2016
    Montreal, Canada
    3,377
    why not include it in the array data? ahh okay thats good for identifying at master end, cuz slaves always have same CS
    good idea
    you don, t actually need to modify the cpp file
    you can define it directly in the struct
    when the struct is created the object is already assigned
    struct AsyncMST {
      uint8_t error = 0;
      uint8_t chip_select = chip_select;
    EDIT, the slave is not capturing so I added your method, but instead of chip_select we'll call it info.slave:
      Serial.print("Slave: "); Serial.println(info.slave);
    H
    struct AsyncMST {
      uint8_t error = 0, slave = -1;
    CPP
                AsyncMST info; info.packetID = buf[4]; info.slave = chip_select;
    output:
    PacketID: 55
    Length: 48
    Slave: 43
    0 0 C00 40EA 0 0 C20 40EA 0 0 C40 40EA 0 0 C60 40EA 0 0 C80 40EA 0 0 CA0 40EA 0 0 CC0 40EA 0 0 CE0 40EA 0 0 D00 40EA 0 0 D20 40EA 0 0 D40 40EA 0 0 D60 40EA
  16. #841
    11,764
    @linarism - that looks like a useful simple change! Whenever the Master is dealing with a message - it knows the Slave CS.
    @tonton81: Is the problem at slower SPI rates the hardcoded timeout references or the delaymicroseconds()? Or perhaps at slower rates there is a need for an added delay where things flow more slowly?
    I tried SPI at 30.5 KHz :: 30500 with these HamHanded edits and it starts working better at that speed:
    //#define resTime_uS 2000 // was 50 >>> if ( micros() - timeout > resTime_uS ) {
    //#define TxTime_ms 1000 // was 100 >>> while ( spi_port->transfer16(0xFFFF) != 0xBABE && millis() - timeout < TxTime_ms );
    //#define _transfer_slowdown 100 // was ZERO
    At that speed it still won't toggle the LED - but the F&F messages pass with misses of 1,2,4 or 5 sets [most often 1 or 2] instead of 8, 11, 12 or 17 missed messages.
    With my lack of understanding of the code it is slow going recompiling Master and Slave randomly - perhaps that tip will point out the area to concentrate on?
  17. #842
    Dec 2016
    Montreal, Canada
    3,377
    ahh, maybe you think it could be possible the slower spi rates require more time to exchange (shift both ways completely) data? you seen an improvement?
    I included linarism's implementation in the repo
  18. #843
    11,764
    Improvement is hard to measure without a custom test like you noted - or at least customizing the current setup which I did not do - just hoping I'd stumble on the right adjustment.
    The current setup trying 500 Hz F&F is frustrated. The long delay(1000) on error takes a long time to watch a trend - but turning that down could open a flood gate.
    I keep thinking knowing how long is spent where - post #836 - might show what happens too fast or too slow or where corrupted data appears if what is what is showing up.
    The errors are detected on the Master side - rarely does the Slave print : DEBUG: [DATA] 9712 4 0 9716
    First thing I did was trim the Master debug messages so they don't scroll too wide::
    >> FAIL_Res #2 RETRY...FAIL_Res #3 RETRY...DBG: [S_CS 15] FAIL_RES #4 Tx ABORT. F&F (OT=399)micros() _time==110287
  19. #844
    Dec 2016
    Montreal, Canada
    3,377
    500khz master _time == 1885
    750khz master _time == 1400
    these are causing OT's to increment
    threw me off while I'm checking timings
  20. #845
    11,764
    I got as far as this for logging.
    Put CycleCounter Enable in .begin. Plan is record start and every transfer16 value. If the transfer works - delete the array, if not then index the array.
    enum:: List of things expected to happen during a transfer
    Start is enter master send or the slave ISR. [.data=PacketID]
    WAIT is random in case there is a place to use it?
    Rx or Tx event stores that value
    CRCERR records that
    TO1 is location 1 for a time out
    TO2 is location 2 for a time out
    On each event record .time = ARM_DWT_CYCCNT;
    enum SPI_EV { START, WAIT, RX, TX, CRCERR, TO1, TO2 };
    struct SPI_event {
      SPI_EV event;
      uint32_t time;
      uint16_t data;
    Circular_Buffer<SPI_event, 12, 150> EventQ;
  21. #846
    Dec 2016
    Montreal, Canada
    3,377
    I think i have narrowed it down
    I have 10khz spi working blinking led with a few modifications, its late now ill work on it tomorrow
    btw, it has nothing to do with delay/delaymicroseconds...
  22. #847
    11,764
    No update for me to work with?
    delaymicros was my last gasp - wondering if that might trigger something.
  23. #848
    Dec 2016
    Montreal, Canada
    3,377
    no its a combo between the functions and isr crc checking routines
    workaround, we kill that code and run without function crc
    ill figure it out eventuallly
    the fact i got it running at 10khz means were on the right track
    the only mystery other than working on a fix is the big magic question, how was the high speed working on same code... we will find out that after its patched and will compare old vs new
  24. #849
    11,764
    Interesting to see the change. Wonder if the T_3.5 will run different for Mike? Found it to run well on the T_3.1. Didn't get wires for the T_LC yet.
  25. #850
    Dec 2016
    Montreal, Canada
    3,377
    yeah im pretty sure this will fix mike’s 3.5 issues, the fact he was getting intermittant successes and alot of errors seems to be pointed in that direction, its just a mystery as why its not occuring at high speeds, but i was never able to get below 8mhz without crashing on the 3.6m3.5s, so its pretty obvious i found that sweet spot
    workaround requires all functions to be patched as well as isr
    id rather fix this issue than just patching everything with a workaround
    the good news is we dont need to delay(Microsecond)s the transfers, all that slow_down flag overhead can be removed for both high and low speed
    i cant offer a workaround patch as that would require double time and function retesting, im testing only the stability of one at a time. im using the pintoggle to trace down and hunt the bug down, thats how i found it, in the end when its done and working the way it should, the corrections would need to follow the other methods
