Project: SPI_MSTransfer
Get some rest - have it running now the T3.5s. Only thing is the prints:
Size: 24 Slave: 15 Port: 1
Gibberish is printed
Enjoy your nap - think I am done for the night
Morning tonton81 :)
Any other than I can't figure out why its not converting uint8's to chars it working like a charm. onDetect method is working. When I unplug the slave and replug in the slave it comes right up - same holds true for the master.
Since I am using a modified form of your original sketches posted for wire I decided to do a test and have the slave transmit back to the master as well :) Guess what its working fine.
Just have to work on the threaded version put the mutexes in the right spot :) Anyway, if interested here is what I am using (they should look familiar):
Master:
#include <i2c_t3.h>
#include "A_ConfigDefines.h"
#include <SPI_MSTransfer.h>
//#include "TeensyThreads.h"
//Threads::Mutex MST_QUEUE;
#include "circular_buffer.h"
#define SPI_SPEED 30000000
#define OT_CALC   100*(30000000/SPI_SPEED)
SPI_MSTransfer teensy_gpio = SPI_MSTransfer("Serial", SPI_MST_CS, &SPI_MST_BUS, SPI_SPD ); // bad with default timeouts
SPI_MSTransfer W1 = SPI_MSTransfer("Wire1", SPI_MST_CS, &SPI_MST_BUS, SPI_SPD ); // bad with default timeouts
uint32_t OverTime = 0;
  while (!Serial && millis() < 2000 ) {}
  teensy_gpio.onTransfer(myCallback);
  teensy_gpio.onTransfer(myCallback8);
#ifdef SPI_MST_SCK
  SPI_MST_BUS.setSCK( SPI_MST_SCK );
  SPI_MST_BUS.begin();
  //threads.addThread(SPI_MST_Thread);
  Wire1.begin(I2C_MASTER, 0, 0, 0, 0, I2C_PULLUP_INT, 100000, I2C_OP_MODE_IMM);
  Serial.println(SPI_MSTransfer::stmca.capacity());
  Serial.println(SPI_MSTransfer::stmca.max_size());
  //  teensy_gpio.debug(Serial);
  W1.onDetect([](AsyncMST info) {
    W1.begin(I2C_SLAVE, 0x22, I2C_PINS_37_38, I2C_PULLUP_INT, 100000);
    Wire1.beginTransmission(0x22);
    Wire1.write("Hello Master!", 13);
    Wire1.endTransmission();
    W1.onReceive(hello);
  }); // end of onDetect callback
  //threads.setTimeSlice(0, 1);
  //threads.setTimeSlice(1, 10);
  delay(3000);
  W1.events(1);
  //teensy_gpio.events(0);
  static uint32_t wire_write_timer = millis();
  if ( millis() - wire_write_timer >= 1000 ) {
    //Serial.println(millis());
    char text1[] = "Yellow World -- SPI_MST";
    //{ Threads::Scope scope(MST_QUEUE);
        Wire1.write(text1, sizeof(text1));
        Wire1.sendTransmission();
        static uint8_t t = 1;
        t++;
        Wire1.write(t);
  static uint32_t _timer = micros();
  static uint32_t led_timer = millis();
  if ( millis() - led_timer >= 100 )  {
      teensy_gpio.pinToggle(LED_BUILTIN);
   delay(1);
  if ( micros() - _timer >= 1000 ) {
    _timer = micros();
    uint8_t bufff[24];
    for (uint8_t i = 0; i < sizeof(bufff); i++) bufff[i] = i;
    uint32_t _time = micros();
    uint16_t *buf;
    double MST_PrintVals[12];
    buf = (uint16_t *)MST_PrintVals;
    int ii = 0;
    static uint16_t __count = 0;
    static uint16_t __countB = 0;
    for ( uint32_t i = 0; i < sizeof(MST_PrintVals) / sizeof( MST_PrintVals[0]  ); i++ ) MST_PrintVals[i] = __count++;
    _time = micros();
    __countB++;
    if ( __countB % 25 ) {
      uint32_t t1 = micros();
        teensy_gpio.transfer16((uint16_t *)MST_PrintVals, sizeof(MST_PrintVals) / 2, 60, 2); // DEBUGHACK output
    else {
      uint32_t t2 = micros();
        teensy_gpio.transfer16((uint16_t *)MST_PrintVals, sizeof(MST_PrintVals) / 2, 55, 2);
    return;
    if ( _time > OT_CALC ) OverTime++;
void hello(size_t count, AsyncMST info) {
  Serial.print("Size: "); Serial.print(count);
  Serial.print(" Slave: "); Serial.print(info.slave);
  Serial.print(" Port: "); Serial.println(info.port);
  if ( count > 10 ) {
    uint8_t buf[count] = { 0 };
    W1.read(buf, count);
    for ( uint16_t i = 0; i < count; i++ ) {
      Serial.print((char) buf[i]);
    } Serial.println();
  else {
    Serial.print("Count: "); Serial.println(W1.read());
//void SPI_MST_Thread() {
  //while (1) {
    //  teensy_gpio.events(0);
    //threads.yield();
void myCallback8(uint8_t *buffer, uint16_t length, AsyncMST info) {
  Serial.print("PacketID: "); Serial.println(info.packetID);
  Serial.print("Length: "); Serial.println(length);
  for ( uint16_t i = 0; i < length; i++ ) {
    Serial.print(buffer[i], HEX); Serial.print(" ");
void myCallback(uint16_t *buffer, uint16_t length, AsyncMST info) {
  //return;
Slave:
#include <i2c_t3.h>
SPI_MSTransfer slave = SPI_MSTransfer("SLAVE", "STANDALONE");
//FastLED.addLeds<WS2812B, DATA_PIN>(leds, NUM_LEDS);
  while (!Serial && millis() < 5000 )
  { Serial.print( "Teensy NOT Online @ millis=" );
    Serial.println( millis() );
    delay(30);
  Serial.print( "Teensy Online @ millis=" );
  if ( ARM_DWT_CYCCNT == ARM_DWT_CYCCNT ) {
    Serial.print( "Cycle Counter Not Enabled :" );
    Serial.println( ARM_DWT_CYCCNT );
    // Enable CPU Cycle Count
    ARM_DEMCR |= ARM_DEMCR_TRCENA;
    ARM_DWT_CTRL |= ARM_DWT_CTRL_CYCCNTENA;
  if ( ARM_DWT_CYCCNT != ARM_DWT_CYCCNT ) {
    Serial.print( "Cycle Counter Enabled! :" );
  slave.begin( );
  slave.onTransfer(myCallback);
  slave.onTransfer(myCallback8);
void led() {
  digitalWrite(13, !digitalRead(13));
   slave.events();
  static uint32_t retry = millis();
  if ( millis() - retry > 200 ) {
    retry = millis();
    uint16_t buf[96];
    for (uint16_t i = 0; i < sizeof(buf) / 2; i++) buf[i] = i;
    slave.transfer16(buf, sizeof(buf) / 2, 69);
static uint16_t last_packetID = 0;
elapsedMillis TogClk;
uint32_t TogCnt = 0;
uint32_t FaFCnt = 0;
  //  Serial.print("PacketID: "); Serial.println(info.packetID);
  //  Serial.print("Length: "); Serial.println(length);
  return;
  if ( 55 == info.packetID ) {
    if ( 48 != length ) {
      Serial.print("Bad Length: "); Serial.println(length); // If this shows then the SPI Passed array size is nor wrong
    else if ( 0 != info.error ) {
      Serial.println("\nBad CRC: ");
    else {
      double* MST_PrintVals;
      MST_PrintVals = (double *)buffer;
        //trig conversions
        float rad2deg = 180.0f / PI;
        float deg2rad = PI / 180.0f;
        int  textLength = 12 * 31;
        char text[textLength];
        char utcText[30];
        char tsIMUText[30];
        char tsGPSText[30];
        // KF parameters
        char latText[30];
        char lonText[30];
        char altText[30];
        char pk1xText[30];
        char pk1yText[30];
        char pk1zText[30];
        char nuk1xText[30];
        char nuk1yText[30];
        char nuk1zText[30];
        int ii = 0;
        dtostrf( MST_PrintVals[ii] , 10, 6, utcText);
        ii++;
        dtostrf( MST_PrintVals[ii] * 0.000001f, 10, 4, tsIMUText);
        ii++;
        dtostrf( MST_PrintVals[ii] * 0.000001f, 10, 4, tsGPSText);
        ii++;
        dtostrf( MST_PrintVals[ii] *rad2deg, 10, 6, latText);
        ii++;
        dtostrf( MST_PrintVals[ii] *rad2deg, 10, 6, lonText);
        ii++;
        dtostrf( MST_PrintVals[ii] , 10, 4, altText);
        ii++;
        dtostrf(sqrt( MST_PrintVals[ii] ), 10, 4, pk1xText);
        ii++;
        dtostrf(sqrt( MST_PrintVals[ii] ), 10, 4, pk1yText);
        ii++;
        dtostrf(sqrt( MST_PrintVals[ii] ), 10, 4, pk1zText);
        ii++;
        dtostrf( MST_PrintVals[ii] , 10, 4, nuk1xText);
        ii++;
        dtostrf( MST_PrintVals[ii] , 10, 4, nuk1yText);
        ii++;
        dtostrf( MST_PrintVals[ii] , 10, 4, nuk1zText);
        // Create single text parameter and print it
        snprintf(text, textLength, "%s,%s,%s,%s,%s,%s,%s,%s,%s,%s,%s,%s",
                 utcText, tsIMUText, tsGPSText,
                 latText, lonText, altText,
                 pk1xText, pk1yText, pk1zText,
                 nuk1xText, nuk1yText, nuk1zText);
        Serial.println(text);
        //Serial.send_now();
  else if ( 60 == info.packetID ) {
    else {
      // This provides a terse output with error checked based on MASTER output to the 12 DOUBLE value Array
        static uint16_t TogLast = 0;
        static uint16_t TogHz = 0;
        static uint16_t FaFHz = 0;
        static double LastVal = 100000;
        static uint32_t ChkErr = 0;
        static uint32_t CBcount = 0;
        if ( digitalReadFast( LED_BUILTIN) != TogLast ) {
          TogLast = !TogLast;
          TogCnt++;
        if ( TogClk >= 1000 ) {
          TogClk -= 1000;
          TogHz = TogCnt;
          TogCnt = 0;
          FaFHz = FaFCnt;
          FaFCnt = 0;
        if ( last_packetID != info.packetID ) {
          LastVal += 12;
          if ( LastVal > 65536 && LastVal < 100000 ) LastVal -= 65536;
        elapsedMillis LastCB;
        double DiffMiss = 0;
        uint32_t ErrSeen = 0;
        CBcount++;
        FaFCnt++;
        for ( uint32_t ii = 0; ii < 12; ii++ ) {
          LastVal++;
          if ( 65536 == LastVal ) LastVal = 0;
          if ( LastCB > 10 || 100001 == LastVal || 100013 == LastVal ) LastVal = MST_PrintVals[ii];
          if ( LastVal != MST_PrintVals[ii] ) {
            DiffMiss = LastVal - MST_PrintVals[ii];
            ChkErr++;
            Serial.print("\nBad LASTVAL TEST INCREMENT <<<<<<<<<<<<<<<<<<<< DIFF OF> ");
            Serial.println( DiffMiss );
            ErrSeen++;
          if ( 0 != ErrSeen || 1 > ii ) {
            Serial.print( MST_PrintVals[ii] );
            Serial.print(",");
          else {
            Serial.print(" #,");
        Serial.print( CBcount );
        Serial.print(",");
        Serial.print( ChkErr );
        Serial.print(" [");
        Serial.print( FaFHz );
        Serial.print(" ,");
        Serial.print( TogHz );
        LastCB = 0;
  else {
  last_packetID = info.packetID;
Hi Mike, I just got home from work, and I think I just found the bug too! Hope it works for you :)
When I added the state checking, I was doing it the original way where it shifts the different state in first and starts shifting the data after, the problem was, the first attempt wasnt always catching. Regardless, the state is all we need, so I've set it to always loop send the state on request for guarenteed delivery and im getting back now immediate responses for i2c, even for hotplugging either master or slave!
I'm just fool proofing the ::read/::read(buf) methods for the callback hijack before ill post the library fix here
example:
doing hijack emulation:
    if ( _wire_callback_active ) {
      [COLOR="#FF0000"]_wire_callback_readpos = mtsca.peek_front()[4]; [/COLOR]
      for ( uint16_t i = 0; i < size; i++ ) buffer[i] = (uint8_t)mtsca.peek_front()[i+5];
      return 0;
for ::read(), i added the red, because, in reality, if we pull the buffer, im force returning -1's during that callback session :) looks kind of real :)
Nice one Tony. Going to try it out next on the T3.5/T3.2 Combo. Know it works on the T3.5/T3.5 combo. In the mean time going to reload the uNav sketches and do a double check. Sure it will work as it doesn't only use sSer3 and SPI transfers.
Go get some coffee and take a nap first - works better.
Mike
Yes, this was a problem for state check for slave to master data as well, the same system shares the queues, so this would fix those slow slave data capture issues
Ok, nailed it!
  if ( wire_port != -1 ) {
      uint8_t _shift = mtsca.peek_front()[4] - available();
      for ( uint16_t i = 0; i < size; i++ ) {
        if ( _wire_callback_readpos >= mtsca.peek_front()[4] ) break;
        buffer[i] = (uint8_t)mtsca.peek_front()[i+5+_shift];
        _wire_callback_readpos++;
      if ( size >= mtsca.peek_front()[4] ) return mtsca.peek_front()[4]-_shift;
      return size;
Basically, this returns how many bytes (simulated like original) pulled from the buffer, pulling less leaves remaining buffer still available for buffered/single reads
Pull less than available, you'll get a count of pulled bytes, pull too much, the function will kick you out after writing whatever was available
The other methods(peek/read/available) didnt need any mods. They all work off the same variable:
After your callback is done, that buffer is destroyed from queue :)
[ATTACH]13608._xfImport[/ATTACH]
The speed of the recovery is faster too now, to fire the lambda
Keep in mind that the lambda fires only if the slave was ever reset, hotplugging doesnt count because the slave hasnt reset, so no need to reset it's registers
Plus, your lambda only fires after the grace period has passed, to make sure the slave is accepting responses properly, before it fires the lamda, to run your init settings, so it guarentees the writes make it to the slave
I just tested the new library with the t3.5 (Master) and T3.2 (slave) combination. I didn't test it with the T3.5/3.5 combo yet before you ask. With the 3.5/3.2 combo I running into an interesting situation but before that the master is at 168 and the slave is at 120.
The master does the transfer16's to slave no problem but they come in bunches of 2 (probably the queue empting ). Then there is a noticeable pause on the slave. The master, on the otherhand, shows no i2c info coming back or transfer16's from the slave. I Checked the wiring a couple times and hooked up an sensor just to make sure. Tested the i2c transfers with and without the slave doing transfers to the master and the same thing. Know I am missing something.
On the only thing I changed in the posted sketch is as follows:
    SPI_MSTransfer W1 = SPI_MSTransfer("Wire", SPI_MST_CS, &SPI_MST_BUS, SPI_SPD ); // bad with default timeouts
and
    W1.begin(I2C_SLAVE, 0x22, I2C_PINS_18_19, I2C_PULLUP_INT, 100000);
and of course I changed all the wire1's to wire calls.
Don't think this has anything to do with the newest version of the library as I saw the same behavior in the previous version of the I2c version.
Issue with speeds again, but then why would the slave receive and not the master?
I tested transfer16's:
 OT_CALC==100  micros() _time==9
ACK PacketID 60: 5uS
 OT_CALC==100  micros() _time==10
ACK PacketID 60: 6uS
0 0 300 40D6 0 0 340 40D6 0 0 380 40D6 0 0 3C0 40D6 0 0 400 40D6 0 0 440 40D6 0 0 480 40D6 0 0 4C0 40D6 0 0 500 40D6 0 0 540 40D6 0 0 580 40D6 0 0 5C0 40D6
0 0 D600 40D5 0 0 D640 40D5 0 0 D680 40D5 0 0 D6C0 40D5 0 0 D700 40D5 0 0 D740 40D5 0 0 D780 40D5 0 0 D7C0 40D5 0 0 D800 40D5 0 0 D840 40D5 0 0 D880 40D5 0 0 D8C0 40D5
0 0 D900 40D5 0 0 D940 40D5 0 0 D980 40D5 0 0 D9C0 40D5 0 0 DA00 40D5 0 0 DA40 40D5 0 0 DA80 40D5 0 0 DAC0 40D5 0 0 DB00 40D5 0 0 DB40 40D5 0 0 DB80 40D5 0 0 DBC0 40D5
0 0 DC00 40D5 0 0 DC40 40D5 0 0 DC80 40D5 0 0 DCC0 40D5 0 0 DD00 40D5 0 0 DD40 40D5 0 0 DD80 40D5 0 0 DDC0 40D5 0 0 DE00 40D5 0 0 DE40 40D5 0 0 DE80 40D5 0 0 DEC0 40D5
0 0 DF00 40D5 0 0 DF40 40D5 0 0 DF80 40D5 0 0 DFC0 40D5 0 0 E000 40D5 0 0 E040 40D5 0 0 E080 40D5 0 0 E0C0 40D5 0 0 E100 40D5 0 0 E140 40D5 0 0 E180 40D5 0 0 E1C0 40D5
0 0 E200 40D5 0 0 E240 40D5 0 0 E280 40D5 0 0 E2C0 40D5 0 0 E300 40D5 0 0 E340 40D5 0 0 E380 40D5 0 0 E3C0 40D5 0 0 E400 40D5 0 0 E440 40D5 0 0 E480 40D5 0 0 E4C0 40D5
0 0 3300 40D6 0 0 3340 40D6 0 0 3380 40D6 0 0 33C0 40D6 0 0 3400 40D6 0 0 3440 40D6 0 0 3480 40D6 0 0 34C0 40D6 0 0 3500 40D6 0 0 3540 40D6 0 0 3580 40D6 0 0 35C0 40D6
0 0 3600 40D6 0 0 3640 40D6 0 0 3680 40D6 0 0 36C0 40D6 0 0 3700 40D6 0 0 3740 40D6 0 0 3780 40D6 0 0 37C0 40D6 0 0 3800 40D6 0 0 3840 40D6 0 0 3880 40D6 0 0 38C0 40D6
0 0 3900 40D6 0 0 3940 40D6 0 0 3980 40D6 0 0 39C0 40D6 0 0 3A00 40D6 0 0 3A40 40D6 0 0 3A80 40D6 0 0 3AC0 40D6 0 0 3B00 40D6 0 0 3B40 40D6 0 0 3B80 40D6 0 0 3BC0 40D6
0 0 3C00 40D6 0 0 3C40 40D6 0 0 3C80 40D6 0 0 3CC0 40D6 0 0 3D00 40D6 0 0 3D40 40D6 0 0 3D80 40D6 0 0 3DC0 40D6 0 0 3E00 40D6 0 0 3E40 40D6 0 0 3E80 40D6 0 0 3EC0 40D6
0 0 3F00 40D6 0 0 3F40 40D6 0 0 3F80 40D6 0 0 3FC0 40D6 0 0 4000 40D6 0 0 4040 40D6 0 0 4080 40D6 0 0 40C0 40D6 0 0 4100 40D6 0 0 4140 40D6 0 0 4180 40D6 0 0 41C0 40D6
0 0 4200 40D6 0 0 4240 40D6 0 0 4280 40D6 0 0 42C0 40D6 0 0 4300 40D6 0 0 4340 40D6 0 0 4380 40D6 0 0 43C0 40D6 0 0 4400 40D6 0 0 4440 40D6 0 0 4480 40D6 0 0 44C0 40D6
0 0 1500 40D6 0 0 1540 40D6 0 0 1580 40D6 0 0 15C0 40D6 0 0 1600 40D6 0 0 1640 40D6 0 0 1680 40D6 0 0 16C0 40D6 0 0 1700 40D6 0 0 1740 40D6 0 0 1780 40D6 0 0 17C0 40D6
0 0 1800 40D6 0 0 1840 40D6 0 0 1880 40D6 0 0 18C0 40D6 0 0 1900 40D6 0 0 1940 40D6 0 0 1980 40D6 0 0 19C0 40D6 0 0 1A00 40D6 0 0 1A40 40D6 0 0 1A80 40D6 0 0 1AC0 40D6
0 0 1B00 40D6 0 0 1B40 40D6 0 0 1B80 40D6 0 0 1BC0 40D6
thats with threading of course
im getting i2c responses as well, post your master/slave ill write my teensies with it
and
events() ? post your code? :)
This is the master/slave im using testing F&F's
Master:
//#include "FastLED.h"
#include <i2c_t3.h>
#include <EventResponder.h>
EventResponder  eresp;
//0x99BB, 0x0003, 0x99B8
//#define SPI_SPEED 30500
SPI_MSTransfer teensy_gpio = SPI_MSTransfer("Serial", SPI_MST_CS, &SPI_MST_BUS, SPI_SPEED ); // bad with default timeouts
SPI_MSTransfer W0 = SPI_MSTransfer("Wire", SPI_MST_CS, &SPI_MST_BUS, SPI_SPEED ); // bad with default timeouts
SPI_MSTransfer W1 = SPI_MSTransfer("Wire1", SPI_MST_CS, &SPI_MST_BUS, SPI_SPEED ); // bad with default timeouts
SPI_MSTransfer sSPI1 = SPI_MSTransfer("SPI1", SPI_MST_CS, &SPI_MST_BUS, SPI_SPEED ); // bad with default timeouts
void I2Cscan(SPI_MSTransfer &port) {
  SPI_MSTransfer* thePort;
  thePort = &port;
  // scan for i2c devices
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for (address = 1; address < 127; address++ ) {
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    thePort->beginTransmission(address);
    error = thePort->endTransmission();
    if (error == 0) {
      Serial.print("I2C device found at address 0x");
      if (address < 16) Serial.print("0");
      Serial.print(address, HEX);
      Serial.println("  !");
      nDevices++;
    else if (error == 4) {
      Serial.print("Unknow error at address 0x");
      Serial.println(address, HEX);
  if (nDevices == 0) {
    Serial.println("No I2C devices found\n");
    while (1) {};
    Serial.println("done\n");
  //return;
  //  SPI_MSTransfer::mtsca._init();
  Circular_Buffer<double, 16> myFloats;
  myFloats.push_back(3.14159);
  myFloats.push_back(12.3456);
  myFloats.push_back(78.91234);
  myFloats.push_back(7.91234);
  myFloats.push_back(11.91234);
  myFloats.push_back(58.91234);
  myFloats.push_back(18.91234);
  //  myFloats.push_back(2.91234);
  Serial.print("SUM: "); Serial.println(myFloats.sum(), 5);
  Serial.print("MIN: "); Serial.println(myFloats.min(), 5);
  Serial.print("MAX: "); Serial.println(myFloats.max(), 5);
  Serial.print("MEDIAN: "); Serial.println(myFloats.median(1), 5);
  uint8_t blah[5];
  //  qsort(blah, 5, sizeof(uint8_t), *(uint8_t*)a - *(uint8_t*)b);
  Serial.print("AVG: "); Serial.println(myFloats.average(), 5);
  uint8_t _size = myFloats.size();
  Serial.print("Deviation: "); Serial.println(myFloats.deviation(), 8);
  for ( uint8_t i = 0; i < _size; i++ ) {
    Serial.print(myFloats.pop_front(), 5); Serial.print(" ");
  } Serial.println();
  //  while(1);
  //uint16_t v = 1010;
  //v--;
  //v |= v >> 1;
  //v |= v >> 2;
  //v |= v >> 4;
  //v |= v >> 8;
  //v |= v >> 16;
  //v++;
  //Serial.println(v);
  //uint16_t v = 300;
  //  Serial.println(v);
  // Circular_Buffer<uint16_t, 4> cb2;
  //  I2Cscan(W0);
  threads.setTimeSlice(0, 5);
  threads.setTimeSlice(1, 0);
  //  W1.begin(I2C_MASTER, 0x00, I2C_PINS_37_38, I2C_PULLUP_EXT, 400000);
  //  W0.begin(I2C_SLAVE, 0x22, I2C_PINS_18_19, I2C_PULLUP_EXT, 100000);
  //  W0.onReceive(hello);
  //  teensy_gpio.onDetect([](AsyncMST info) {
  //    { Threads::Scope scope(MST_QUEUE);
  //      //  W0.onReceive(hello);
  //  }); // end of onDetect callback
  Wire.begin();
  //  delay(2000);
    Serial.print((char)W0.read());
  } Serial.println();
  while (1) {
    threads.yield();
    //    Serial.println("LED TOGGLE!");
    //    delay(1);
  //  return;
    _timer = micros();
    uint8_t bufff[24];
    //    teensy_gpio.transfer(bufff, sizeof(bufff), 69, 2);
    //uint16_t notify = 0xAD00;
    //Serial.println(notify |= 1 << 0,HEX);
    // set:  notify |= 1 << 7;
    // unset:  notify &= ~(1 << 7);
    //    Serial.println(millis());
    //    W0.beginTransmission(0x20);
    //    uint8_t ibuffer[3] = { 0x0C, 0xFF, 0xFF };
    //    W0.write(ibuffer, 3); // set pullups
    //    W0.endTransmission();
    //    W0.write(0x12); // set bankA to read
    //    W0.requestFrom(0x20, 2); // read bankA and bankB
    //    Serial.print(W0.read()); Serial.print(":"); Serial.println(W0.read());
    //    Serial.println( W0.requestFrom(0x48, 1, 1));
    //    uint8_t buffer[48];
    //    for ( uint8_t i = 0; i < sizeof(buffer); i++ ) {
    //      buffer[i] = i;
    //    uint32_t ___time = micros();
    //    teensy_gpio.transfer(buffer, sizeof(buffer), 10750,1);
    //    Serial.print("T: "); Serial.println(micros() - ___time);
    //    SPIClass teensy_gpio;
    //SPI3 = (SPIClass)teensy_gpio;
    uint16_t *buf;
    int ii = 0;
    //    Serial.print("F&F (OT=");
    //    Serial.print( OverTime );
    //    Serial.print(")");
    _time = micros();
    __countB++;
      Serial.print("ACK PacketID 60: ");
      Serial.print(micros() - t1);
      Serial.println("uS");
    else {
      Serial.print("F&F PacketID 55: ");
      Serial.print(micros() - t2);
    //    return;
    _time = micros() - _time;
    Serial.print(" OT_CALC==");
    Serial.print(OT_CALC);
    Serial.print("  micros() _time==");
    Serial.println(_time);
    //    teensy_gpio.events();
Slave:
#include <i2c_t3.h>
    delay(30);
  SPI1.begin();
  SPI2.begin();
  SPI1.setSCK(20); SPI1.setMOSI(21); SPI1.setMISO(5); SPI1.begin();
  SPI2.setSCK(46); SPI2.setMOSI(44); SPI2.setMISO(45); SPI2.begin();
  SPI1.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE0)); // default speed
  SPI2.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE0)); // default speed
  slave.begin( );
//  slave.debug(Serial); // SPI_MST Debug error tracking
//  Wire.begin(I2C_SLAVE, 0x22, I2C_PINS_18_19, I2C_PULLUP_EXT, 100000);
void led() {
  slave.events();
//      return;
  if ( millis() - retry > 100 ) {
    retry = millis();
    uint16_t buf[96];
  return;
    else {
        //trig conversions
        char utcText[30];
        char tsIMUText[30];
        char tsGPSText[30];
        // KF parameters
        char latText[30];
        char lonText[30];
        char altText[30];
        char pk1xText[30];
        char pk1yText[30];
        char pk1zText[30];
        char nuk1xText[30];
        char nuk1yText[30];
        char nuk1zText[30];
        int ii = 0;
        ii++;
        ii++;
        ii++;
        ii++;
        ii++;
        ii++;
        ii++;
        ii++;
        ii++;
        ii++;
        ii++;
    else {
          TogLast = !TogLast;
          TogCnt++;
          TogClk -= 1000;
          TogHz = TogCnt;
          TogCnt = 0;
          FaFHz = FaFCnt;
          FaFCnt = 0;
          LastVal += 12;
        CBcount++;
        FaFCnt++;
          LastVal++;
            ChkErr++;
            ErrSeen++;
            Serial.print(",");
          else {
        Serial.print(",");
        Serial.print(" [");
        Serial.print(" ,");
        LastCB = 0;
  else {
As for code its the same as posted in post #1302. Except I remembered to uncomment the events()? Remember that one from the previous time I forgot it :)
I give just the F&F examples a shot. Didn't think about retrying just that.
It's something stupid on master sketch, only master sketch, I write yours, I see that lag, I write mine, it rolls along nicely... still trying to pinpoint it...
Just as a point of info its the same sketch I ran on the 2 T3.5s except for the change from Wire1 to Wire. So I am really lost.
events(0)?
EDIT-UPDATE: Just to be contrary I loaded up the SPI2WayComm example sketches. F&F didn't work. Slave got some messages but everything on the master was OT's and times were like 9999.
So I changed it to message to 2 and even stranger things started happening - master would fire but nothing received from the slave (nothing strange on the ots and times but on the slave the first 4 messages would print but then it would freeze a little while later would get errors... see below:
0.00, #, #, #, #, #, #, #, #, #, #, #,1,0
12.00, #, #, #, #, #, #, #, #, #, #, #,2,0
24.00, #, #, #, #, #, #, #, #, #, #, #,3,0
36.00, #, #, #, #, #, #, #, #, #, #, #,4,0
48.00, #, #, #, #, #, #, #, #, #, #, #,5,0
60.00, #, #, #, #, #, #, #, #, #, #, #,6,0
72.00, #, #, #, #, #, #, #, #, #, #, #,7,0
84.00, #, #, #, #, #, #, #, #, #, #, #,8,0
96.00, #, #, #, #, #, #, #, #, #, #, #,9,0
108.00, #, #, #, #, #, #, #, #, #, #, #,10,0
120.00, #, #, #, #, #, #, #, #, #, #, #,11,0
132.00, #, #, #, #, #, #, #, #, #, #, #,12,0
144.00, #, #, #, #, #, #, #, #, #, #, #,13,0
156.00, #, #, #, #, #, #, #, #, #, #, #,14,0 #, #, #,23,0
Bad LASTVAL TEST INCREMENT <<<<<<<<<<<<<<<<<<<< DIFF OF> -12.00
288.00,289.00,290.00,291.00,292.00,293.00,294.00,295.00,296.00,297.00,298.00,299.00,24,1
300.00, #, #, #, #, #, #, #, #, #, #, #,25,1
Bad LASTVAL TEST INCREMENT <<<<<<<<<<<<<<<<<<<< DIFF OF> -300.00
612.00,613.00,614.00,615.00,616.00,617.00,618.00,619.00,620.00,621.00,622.00,623.00,26,2
624.00, #, #, #, #, #, #, #, #, #, #, #,27,2
Ok I figured it out, well not really, just narrowed it down...
It's working if events() is in a thread, but not in a single nonthreaded sketch, it's something in events() I gather, gonna have to poke around to see whats up
Sorry I am giving you so many headaches but .... at least you are finding the issues before going live with the changes.
Heres another interesting thing, comment out events and try F&F's... its running fast!
that means, its crashing somewhere in events()...
i narrowed it down, your sketch is running with the first section of events() commented out
need to see where its crashing in there now
yes i know, still working on it but i goto work soon :)
if you comment out events()/remove it, master is sending fine
i have to see where its crashing to fix it tomorrow if i have time (double shifts)
post #1319 i tested your #1302 *without* events() in loop() and its running fine
so i know its something in events i need to poke and fix
Morning Tony,
Understand. Just wanted to let you know about the issue and kind of confirm that the problem is with events. So I was going to revert to the GitHub version for now. Didn't mean to sound upset. Was late and was tired I guess. I just saw your post so I will give it a shot without events in the master and update this post.
Mike
UPDATE: Seems to be working with events not in the loop. But it freezes periodically for a few seconds up to a couple of minutes each time and then shoots a few more messages to the slave and then just freezes.
yes i know, this happened since queue implementation, the events is suppose to fire when slave TELLS master its ready, can you try without events loaded on master with latest version, and try the github version flashed to slave to restore slave events()?
