#include <SPI_MSTransfer.h>
SPI_MSTransfer slave = SPI_MSTransfer("SLAVE", "STANDALONE");
void myCallback8(uint8_t *buffer, uint16_t length, AsyncMST info) {
Serial.print("PacketID: "); Serial.println(info.packetID);
Serial.print("Length: "); Serial.println(length);
for ( uint16_t i = 0; i < length; i++ ) {
Serial.print(buffer[i], HEX); Serial.print(" ");
while (!Serial && millis() < 5000 )
{ Serial.print( "Teensy NOT Online @ millis=" );
Serial.println( millis() );
delay(30);
Serial.print( "Teensy Online @ millis=" );
if ( ARM_DWT_CYCCNT == ARM_DWT_CYCCNT ) {
Serial.print( "Cycle Counter Not Enabled :" );
Serial.println( ARM_DWT_CYCCNT );
// Enable CPU Cycle Count
ARM_DEMCR |= ARM_DEMCR_TRCENA;
ARM_DWT_CTRL |= ARM_DWT_CTRL_CYCCNTENA;
if ( ARM_DWT_CYCCNT != ARM_DWT_CYCCNT ) {
Serial.print( "Cycle Counter Enabled! :" );
slave.begin( );
slave.onTransfer(myCallback);
slave.onTransfer(myCallback8);
// slave.debug(Serial); // SPI_MST Debug error tracking
void led() {
digitalWrite(13, !digitalRead(13));
slave.events();
// return;
static uint32_t retry = millis();
if ( millis() - retry > 100 ) {
retry = millis();
uint8_t buf[24];
for (uint8_t i = 0; i < sizeof(buf); i++) buf[i] = i;
slave.transfer(buf, sizeof(buf), 69);
static uint16_t last_packetID = 0;
elapsedMillis TogClk;
uint32_t TogCnt = 0;
uint32_t FaFCnt = 0;
void myCallback(uint16_t *buffer, uint16_t length, AsyncMST info) {
// Serial.print("PacketID: "); Serial.println(info.packetID);
// Serial.print("Length: "); Serial.println(length);
return;
if ( 55 == info.packetID ) {
if ( 48 != length ) {
Serial.print("Bad Length: "); Serial.println(length); // If this shows then the SPI Passed array size is nor wrong
else if ( 0 != info.error ) {
Serial.println("\nBad CRC: ");
else {
double* MST_PrintVals;
MST_PrintVals = (double *)buffer;
//trig conversions
float rad2deg = 180.0f / PI;
float deg2rad = PI / 180.0f;
int textLength = 12 * 31;
char text[textLength];
char utcText[30];
char tsIMUText[30];
char tsGPSText[30];
// KF parameters
char latText[30];
char lonText[30];
char altText[30];
char pk1xText[30];
char pk1yText[30];
char pk1zText[30];
char nuk1xText[30];
char nuk1yText[30];
char nuk1zText[30];
int ii = 0;
dtostrf( MST_PrintVals[ii] , 10, 6, utcText);
ii++;
dtostrf( MST_PrintVals[ii] * 0.000001f, 10, 4, tsIMUText);
ii++;
dtostrf( MST_PrintVals[ii] * 0.000001f, 10, 4, tsGPSText);
ii++;
dtostrf( MST_PrintVals[ii] *rad2deg, 10, 6, latText);
ii++;
dtostrf( MST_PrintVals[ii] *rad2deg, 10, 6, lonText);
ii++;
dtostrf( MST_PrintVals[ii] , 10, 4, altText);
ii++;
dtostrf(sqrt( MST_PrintVals[ii] ), 10, 4, pk1xText);
ii++;
dtostrf(sqrt( MST_PrintVals[ii] ), 10, 4, pk1yText);
ii++;
dtostrf(sqrt( MST_PrintVals[ii] ), 10, 4, pk1zText);
ii++;
dtostrf( MST_PrintVals[ii] , 10, 4, nuk1xText);
ii++;
dtostrf( MST_PrintVals[ii] , 10, 4, nuk1yText);
ii++;
dtostrf( MST_PrintVals[ii] , 10, 4, nuk1zText);
// Create single text parameter and print it
snprintf(text, textLength, "%s,%s,%s,%s,%s,%s,%s,%s,%s,%s,%s,%s",
utcText, tsIMUText, tsGPSText,
latText, lonText, altText,
pk1xText, pk1yText, pk1zText,
nuk1xText, nuk1yText, nuk1zText);
Serial.println(text);
//Serial.send_now();
else if ( 60 == info.packetID ) {
else {
// This provides a terse output with error checked based on MASTER output to the 12 DOUBLE value Array
static uint16_t TogLast = 0;
static uint16_t TogHz = 0;
static uint16_t FaFHz = 0;
static double LastVal = 100000;
static uint32_t ChkErr = 0;
static uint32_t CBcount = 0;
if ( digitalReadFast( LED_BUILTIN) != TogLast ) {
TogLast = !TogLast;
TogCnt++;
if ( TogClk >= 1000 ) {
TogClk -= 1000;
TogHz = TogCnt;
TogCnt = 0;
FaFHz = FaFCnt;
FaFCnt = 0;
if ( last_packetID != info.packetID ) {
LastVal += 12;
if ( LastVal > 65536 && LastVal < 100000 ) LastVal -= 65536;
elapsedMillis LastCB;
double DiffMiss = 0;
uint32_t ErrSeen = 0;
CBcount++;
FaFCnt++;
for ( uint32_t ii = 0; ii < 12; ii++ ) {
LastVal++;
if ( 65536 == LastVal ) LastVal = 0;
if ( LastCB > 10 || 100001 == LastVal || 100013 == LastVal ) LastVal = MST_PrintVals[ii];
if ( LastVal != MST_PrintVals[ii] ) {
DiffMiss = LastVal - MST_PrintVals[ii];
ChkErr++;
Serial.print("\nBad LASTVAL TEST INCREMENT <<<<<<<<<<<<<<<<<<<< DIFF OF> ");
Serial.println( DiffMiss );
ErrSeen++;
if ( 0 != ErrSeen || 1 > ii ) {
Serial.print( MST_PrintVals[ii] );
Serial.print(",");
else {
Serial.print(" #,");
Serial.print( CBcount );
Serial.print(",");
Serial.print( ChkErr );
Serial.print(" [");
Serial.print( FaFHz );
Serial.print(" ,");
Serial.print( TogHz );
LastCB = 0;
else {
last_packetID = info.packetID;
