I tired to compile Pjon library examples but returned error with following error message.
I installed the library by adding zipped file and other arduino boards compile well.
Any help wopuld be appreciated!
thank you.
In file included from /opt/arduino-1.8.3/libraries/PJON-master/src/strategies/EthernetTCP/EthernetLink.h:132:0,
Multiple libraries were found for "Ethernet.h"
Used: /opt/arduino-1.8.3/hardware/teensy/avr/libraries/Ethernet
from /opt/arduino-1.8.3/libraries/PJON-master/src/strategies/EthernetTCP/EthernetTCP.h:24,
Not used: /opt/arduino-1.8.3/libraries/Ethernet
from /opt/arduino-1.8.3/libraries/PJON-master/src/strategies/PJON_Strategies.h:65,
from /opt/arduino-1.8.3/libraries/PJON-master/src/PJON.h:87,
from /opt/arduino-1.8.3/libraries/PJON-master/examples/ARDUINO/Local/SoftwareBitBang/SendAndReceive/Device1/Device1.ino:1:
/opt/arduino-1.8.3/libraries/PJON-master/src/interfaces/ARDUINO/TCPHelper_ARDUINO.h:10:30: fatal error: utility/socket.h: No such file or directory
compilation terminated.
Error compiling for board Teensy 3.2 / 3.1.
thank you.
