Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 51 to 75 of 83
Thread: Teensyduino 1.42 Beta #2
  1. #51
    11,506
    Rebooted Win 10. Opened twin IDE's - one for T_3.5 and one for T_3.6. Programmed both devices in turn.
    Pressed T_3.5 button and got ERROR: Code for T_3.6.
    Can Teensyloader track which .HEX last went to the device and send the proper one in response to a device Button?
    Then pushed button T_3.6 and it has gone NEUROTIC again: Tport3536nuerotic.txt
  2. #52
    21,825
    No, it can't.
    If fact, Teensy Loader doesn't even (yet) have the ability to verify the board it's programming is really the intended location. In fact, on top of that, so far the teensy_reboot program doesn't even have a way to send that location info to Teensy Loader.
    At this point, Teensy Loader is still a very simple single-file, single-board approach. Multiple boards only works because teensy_reboot can now send the reboot request to the correct board, and the ports menu now offers selection based on actual physical port location. It all depends on Teensy Loader having the right file open and be configure in auto mode (both of which teensy_reboot does do) when the Teensy shows up in bootloader mode.
    I'm very likely going to leave Teensy Loader this way for 1.42. We're already into March, which means the ~3 month release cycle is coming up soon. I really want to get the new ports menu and serial monitor working well, and then roll up a big batch of minor fixes and improvements for a 1.42 release. Expanding the scope of this work to also change how Teensy Loader works internally would delay 1.42 too much.
  3. #53
    6,632
    Any chance you still have Teensy Loader open and the Verbose Info window has the log from when that unresponsive serial monitor window opened?
    I ran another one... The interesting thing is the window says offline... But I am getting output showing up in the window, although it is grayed/dimmed in the off line state...
    15:29:07.992 (ports): nothing new, skipping HID & Ports enum
    15:30:22.457 (ports): got command: "list"
    15:30:22.458 (ports): nothing new, skipping HID & Ports enum
    15:30:30.867 (post_compile): Begin, version=1.42-beta3-pre2, high-res time
    15:30:31.020 (loader): Teensy Loader 1.42-beta3-pre2, begin program
    15:30:31.075 (loader): File "WellMonitor.ino.hex". 74696 bytes, 7% used
    15:30:31.083 (loader): Listening for remote control on port 3149
    15:30:31.084 (loader): initialized, showing main window
    15:30:31.167 (loader): remote connection 1252 opened
    15:30:31.168 (loader): remote cmd from 1252: "comment: Teensyduino 1.42-beta3-pre2 - WINDOWS (teensy_post_compile)"
    15:30:31.169 (post_compile): Sending command: comment: Teensyduino 1.42-beta3-pre2 - WINDOWS (teensy_post_compile)
    15:30:31.169 (loader): remote cmd from 1252: "status"
    15:30:31.171 (loader): HID/win32:  vid:045E pid:07A5 ver:0797
    15:30:31.172 (loader): HID/win32:  vid:045E pid:07A5 ver:0797
    15:30:31.172 (loader): remote cmd from 1252: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\"
    15:30:31.172 (loader): remote cmd from 1252: "file:WellMonitor.ino.hex"
    15:30:31.173 (post_compile): Status: 1, 0, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:31.173 (post_compile): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\
    15:30:31.173 (post_compile): Sending command: file:WellMonitor.ino.hex
    15:30:31.183 (loader): File "WellMonitor.ino.hex". 74696 bytes, 7% used
    15:30:31.187 (loader): remote cmd from 1252: "status"
    15:30:31.189 (post_compile): Status: 1, 0, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:31.189 (post_compile): Sending command: auto:on
    15:30:31.189 (loader): remote cmd from 1252: "auto:on"
    15:30:31.190 (post_compile): Disconnect
    15:30:31.201 (loader): remote connection 1252 closed
    15:30:31.470 (loader): remote connection 1252 opened
    15:30:31.475 (ports): got command: "list"
    15:30:31.476 (ports): nothing new, skipping HID & Ports enum
    15:30:31.476 (ports): got command: "list"
    15:30:31.477 (ports): nothing new, skipping HID & Ports enum
    15:30:31.502 (loader): remote connection 1304 opened
    15:30:31.502 (loader): remote cmd from 1304: "comment: Teensyduino 1.42-beta3-pre2 - WINDOWS (teensy_post_compile)"
    15:30:31.502 (loader): remote cmd from 1304: "status"
    15:30:31.502 (loader): remote cmd from 1304: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\"
    15:30:31.502 (loader): remote cmd from 1304: "file:WellMonitor.ino.hex"
    15:30:31.504 (post_compile): Begin, version=1.42-beta3-pre2, high-res time
    15:30:31.506 (post_compile): Sending command: comment: Teensyduino 1.42-beta3-pre2 - WINDOWS (teensy_post_compile)
    15:30:31.507 (post_compile): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:31.507 (post_compile): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\
    15:30:31.507 (post_compile): Sending command: file:WellMonitor.ino.hex
    15:30:31.517 (loader): File "WellMonitor.ino.hex". 74696 bytes, 7% used
    15:30:31.517 (loader): remote cmd from 1304: "status"
    15:30:31.522 (post_compile): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:31.522 (post_compile): Disconnect
    15:30:31.533 (loader): remote connection 1304 closed
    15:30:31.533 (loader): remote connection 1304 opened
    15:30:31.533 (loader): remote connection 1328 opened
    15:30:31.533 (loader): remote cmd from 1328: "show:arduino_attempt_reboot"
    15:30:31.533 (loader): got request to show arduino rebooting message
    15:30:31.533 (post_compile): Running teensy_reboot: "D:\arduino-1.8.5\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY36" "-port=usb:0/140000/0/2/1" "-portlabel=hid#vid_16c0&pid_0478... (Teensy 3.6) Bootloader" "-portprotocol=Teensy"
    15:30:31.544 (reboot): Begin, version=1.42-beta3-pre2, high-res time
    15:30:31.544 (reboot): location = usb:0/140000/0/2/1
    15:30:31.544 (reboot): portlabel = hid#vid_16c0&pid_0478... (Teensy 3.6) Bootloader
    15:30:31.544 (reboot): portprotocol = Teensy
    15:30:31.544 (reboot): Only location usb:0/140000/0/2/1 will be tried
    15:30:31.544 (reboot): LoadLibrary cfgmgr32 ok
    15:30:31.544 (reboot): LoadLibrary ntdll ok
    15:30:31.545 (reboot): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#2320690#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    15:30:31.545 (reboot): found_usb_device, loc=usb:0/140000/0/2/1    Port_#0001.Hub_#0003
    15:30:31.545 (reboot): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0200
    15:30:31.545 (reboot): found_usb_device, devinst=00000003
    15:30:31.545 (reboot): add: loc=usb:0/140000/0/2/1, class=Ports, vid=16C0, pid=0483, ver=0200, serial=232, dev=\\?\usb#vid_16c0&pid_0483#2320690#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    15:30:31.545 (reboot):   comport_from_devinst_list attempt
    15:30:31.545 (reboot):   found Ports in classguid_list at index=0
    15:30:31.545 (reboot):   port COM25 found from devnode
    15:30:31.545 (reboot): found_usb_device complete
    15:30:31.548 (reboot): found Teensy Loader, version 1.42
    15:30:31.548 (reboot): Sending command: show:arduino_attempt_reboot
    15:30:31.549 (loader): remote cmd from 1328: "comment: Teensyduino 1.42-beta3-pre2 - WINDOWS (teensy_reboot)"
    15:30:31.549 (loader): remote cmd from 1328: "status"
    15:30:31.551 (reboot): Sending command: comment: Teensyduino 1.42-beta3-pre2 - WINDOWS (teensy_reboot)
    15:30:31.552 (reboot): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:31.552 (reboot): do_reset (serial) COM25
    15:30:31.560 (reboot): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:31.560 (reboot): status read, retry 0
    15:30:31.654 (ports): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    15:30:31.656 (ports): remove: loc=usb:0/140000/0/2/1
    15:30:31.656 (ports): usb_remove: usb:0/140000/0/2/1
    15:30:31.656 (ports): nothing new, skipping HID & Ports enum
    15:30:31.664 (ports): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    15:30:31.664 (ports): nothing new, skipping HID & Ports enum
    15:30:31.665 (ports): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    15:30:31.666 (ports): nothing new, skipping HID & Ports enum
    15:30:31.674 (loader): remote cmd from 1328: "status"
    15:30:31.675 (reboot): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:31.675 (reboot): status read, retry 1
    15:30:31.782 (loader): remote cmd from 1328: "status"
    15:30:31.785 (reboot): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:31.785 (reboot): status read, retry 2
    15:30:31.891 (loader): remote cmd from 1328: "status"
    15:30:31.895 (reboot): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:31.895 (reboot): status read, retry 3
    15:30:32.000 (loader): remote cmd from 1328: "status"
    15:30:32.002 (reboot): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:32.002 (reboot): status read, retry 4
    15:30:32.107 (loader): remote cmd from 1328: "status"
    15:30:32.108 (reboot): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:32.108 (reboot): status read, retry 5
    15:30:32.214 (loader): remote cmd from 1328: "status"
    15:30:32.216 (reboot): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:32.216 (reboot): status read, retry 6
    15:30:32.322 (loader): remote cmd from 1328: "status"
    15:30:32.323 (reboot): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:32.323 (reboot): status read, retry 7
    15:30:32.429 (loader): remote cmd from 1328: "status"
    15:30:32.430 (reboot): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:32.430 (reboot): status read, retry 8
    15:30:32.538 (loader): remote cmd from 1328: "status"
    15:30:32.540 (reboot): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:32.540 (reboot): status read, retry 9
    15:30:32.600 (ports): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    15:30:32.601 (ports): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#00038a85#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    15:30:32.601 (ports): found_usb_device, loc=usb:0/140000/0/2/1    Port_#0001.Hub_#0003
    15:30:32.601 (ports): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0103
    15:30:32.601 (ports): found_usb_device, devinst=00000015
    15:30:32.601 (ports): add: loc=usb:0/140000/0/2/1, class=HID, vid=16C0, pid=0478, ver=0103, serial=000, dev=\\?\usb#vid_16c0&pid_0478#00038a85#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    15:30:32.601 (ports): hiddev_from_devinst_list: iface=0
    15:30:32.602 (ports): found_usb_device complete
    15:30:32.602 (ports): usb_add: usb:0/140000/0/2/1  [no_device] (Teensy 3.6) Bootloader
    15:30:32.604 (ports): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    15:30:32.605 (ports): hid, found devinst=00000016
    15:30:32.605 (ports): hid, path=\\?\hid#vid_16c0&pid_0478#7&11b7d899&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    15:30:32.605 (ports): hid,  opened handle
    15:30:32.605 (ports):  devinst=00000016, location=usb:0/140000/0/2/1
    15:30:32.605 (ports):  vid=16C0, pid=0478, ver=0103, usepage=FF9C, use=0022
    15:30:32.605 (ports):  devpath=\\?\hid#vid_16c0&pid_0478#7&11b7d899&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    15:30:32.605 (ports): usb_add: usb:0/140000/0/2/1  \\?\hid#vid_16c0&pid_0478#7&11b7d899&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030} (Teensy 3.6) Bootloader
    15:30:32.653 (loader): remote cmd from 1328: "status"
    15:30:32.654 (loader): Device came online, code_size = 1048576
    15:30:32.654 (loader): Board is: Teensy 3.6 (MK66FX1M0), version 1.03
    15:30:32.667 (loader): File "WellMonitor.ino.hex". 74696 bytes, 7% used
    15:30:32.667 (loader): set background IMG_ONLINE
    15:30:32.681 (loader): File "WellMonitor.ino.hex". 74696 bytes, 7% used
    15:30:32.682 (loader): elf size appears to be 1048576
    15:30:32.682 (loader): elf binary data matches hex file
    15:30:32.682 (loader): Code size from .elf file = 1048576
    15:30:32.682 (loader): begin operation
    15:30:32.690 (reboot): Status: 1, 1, 1, 1, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:32.696 (loader): flash, block=0, bs=1024, auto=1
    15:30:32.702 (loader): flash, block=1, bs=1024, auto=1
    15:30:32.704 (loader): flash, block=2, bs=1024, auto=1
    15:30:32.706 (loader): flash, block=3, bs=1024, auto=1
    15:30:32.981 (loader): remote cmd from 1328: "status"
    15:30:32.981 (reboot): Status: 1, 1, 1, 1, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:32.981 (loader): flash, block=4, bs=1024, auto=1
    15:30:33.012 (loader): flash, block=5, bs=1024, auto=1
    15:30:33.013 (loader): flash, block=6, bs=1024, auto=1
    15:30:33.015 (loader): flash, block=7, bs=1024, auto=1
    15:30:33.016 (loader): flash, block=8, bs=1024, auto=1
    15:30:33.043 (loader): flash, block=9, bs=1024, auto=1
    15:30:33.045 (loader): flash, block=10, bs=1024, auto=1
    15:30:33.046 (loader): flash, block=11, bs=1024, auto=1
    15:30:33.074 (loader): remote cmd from 1328: "status"
    15:30:33.074 (loader): flash, block=12, bs=1024, auto=1
    15:30:33.074 (reboot): Status: 1, 1, 1, 1, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:33.076 (loader): flash, block=13, bs=1024, auto=1
    15:30:33.077 (loader): flash, block=14, bs=1024, auto=1
    15:30:33.079 (loader): flash, block=15, bs=1024, auto=1
    15:30:33.106 (loader): flash, block=16, bs=1024, auto=1
    15:30:33.108 (loader): flash, block=17, bs=1024, auto=1
    15:30:33.109 (loader): flash, block=18, bs=1024, auto=1
    15:30:33.136 (loader): remote cmd from 1328: "status"
    15:30:33.136 (reboot): Status: 1, 1, 1, 1, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:33.136 (loader): flash, block=19, bs=1024, auto=1
    15:30:33.138 (loader): flash, block=20, bs=1024, auto=1
    15:30:33.139 (loader): flash, block=21, bs=1024, auto=1
    15:30:33.141 (loader): flash, block=22, bs=1024, auto=1
    15:30:33.168 (loader): flash, block=23, bs=1024, auto=1
    15:30:33.170 (loader): flash, block=24, bs=1024, auto=1
    15:30:33.171 (loader): flash, block=25, bs=1024, auto=1
    15:30:33.198 (loader): remote cmd from 1328: "status"
    15:30:33.198 (reboot): Status: 1, 1, 1, 1, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:33.198 (loader): flash, block=26, bs=1024, auto=1
    15:30:33.200 (loader): flash, block=27, bs=1024, auto=1
    15:30:33.201 (loader): flash, block=28, bs=1024, auto=1
    15:30:33.203 (loader): flash, block=29, bs=1024, auto=1
    15:30:33.230 (loader): flash, block=30, bs=1024, auto=1
    15:30:33.231 (loader): flash, block=31, bs=1024, auto=1
    15:30:33.233 (loader): flash, block=32, bs=1024, auto=1
    15:30:33.260 (loader): flash, block=33, bs=1024, auto=1
    15:30:33.262 (loader): remote cmd from 1328: "status"
    15:30:33.262 (loader): flash, block=34, bs=1024, auto=1
    15:30:33.262 (reboot): Status: 1, 1, 1, 1, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_606612\, WellMonitor.ino.hex
    15:30:33.263 (loader): flash, block=35, bs=1024, auto=1
    15:30:33.265 (loader): flash, block=36, bs=1024, auto=1
    15:30:33.291 (loader): flash, block=37, bs=1024, auto=1
    15:30:33.292 (loader): flash, block=38, bs=1024, auto=1
    15:30:33.294 (loader): flash, block=39, bs=1024, auto=1
    15:30:33.321 (reboot): status read, retry 10
    15:30:33.321 (reboot): Disconnect
    15:30:33.321 (reboot): Success
    15:30:33.322 (loader): flash, block=40, bs=1024, auto=1
    15:30:33.323 (loader): flash, block=41, bs=1024, auto=1
    15:30:33.325 (loader): flash, block=42, bs=1024, auto=1
    15:30:33.326 (loader): flash, block=43, bs=1024, auto=1
    15:30:33.342 (ports): got command: "list"
    15:30:33.343 (ports): nothing new, skipping HID & Ports enum
    15:30:33.343 (ports): got command: "list"
    15:30:33.353 (loader): remote connection 1328 closed
    15:30:33.353 (loader): remote connection 1304 closed
    15:30:33.354 (loader): flash, block=44, bs=1024, auto=1
    15:30:33.355 (loader): flash, block=45, bs=1024, auto=1
    15:30:33.357 (loader): flash, block=46, bs=1024, auto=1
    15:30:33.384 (loader): flash, block=47, bs=1024, auto=1
    15:30:33.386 (loader): flash, block=48, bs=1024, auto=1
    15:30:33.387 (loader): flash, block=49, bs=1024, auto=1
    15:30:33.389 (loader): flash, block=50, bs=1024, auto=1
    15:30:33.415 (loader): flash, block=51, bs=1024, auto=1
    15:30:33.417 (loader): flash, block=52, bs=1024, auto=1
    15:30:33.418 (loader): flash, block=53, bs=1024, auto=1
    15:30:33.447 (loader): flash, block=54, bs=1024, auto=1
    15:30:33.448 (loader): flash, block=55, bs=1024, auto=1
    15:30:33.450 (loader): flash, block=56, bs=1024, auto=1
    15:30:33.451 (loader): flash, block=57, bs=1024, auto=1
    15:30:33.478 (loader): flash, block=58, bs=1024, auto=1
    15:30:33.479 (loader): flash, block=59, bs=1024, auto=1
    15:30:33.481 (loader): flash, block=60, bs=1024, auto=1
    15:30:33.509 (loader): flash, block=61, bs=1024, auto=1
    15:30:33.511 (loader): flash, block=62, bs=1024, auto=1
    15:30:33.512 (loader): flash, block=63, bs=1024, auto=1
    15:30:33.513 (loader): flash, block=64, bs=1024, auto=1
    15:30:33.540 (loader): flash, block=65, bs=1024, auto=1
    15:30:33.541 (loader): flash, block=66, bs=1024, auto=1
    15:30:33.543 (loader): flash, block=67, bs=1024, auto=1
    15:30:33.571 (loader): flash, block=68, bs=1024, auto=1
    15:30:33.572 (loader): flash, block=69, bs=1024, auto=1
    15:30:33.574 (loader): flash, block=70, bs=1024, auto=1
    15:30:33.575 (loader): flash, block=71, bs=1024, auto=1
    15:30:33.602 (loader): flash, block=72, bs=1024, auto=1
    15:30:33.607 (loader): sending reboot
    15:30:33.609 (loader): begin wait_until_offline
    15:30:33.686 (ports): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    15:30:33.686 (ports): remove: loc=usb:0/140000/0/2/1
    15:30:33.686 (ports): usb_remove: usb:0/140000/0/2/1
    15:30:33.686 (ports): nothing new, skipping HID & Ports enum
    15:30:33.713 (loader): offline, waited 2
    15:30:33.713 (loader): end operation, total time = 1.031 seconds
    15:30:33.713 (loader): set background IMG_REBOOT_OK
    15:30:33.713 (loader): redraw timer set, image 14 to show for 1200 ms
    15:30:33.822 (loader): HID/win32:  vid:045E pid:07A5 ver:0797
    15:30:33.823 (loader): HID/win32:  vid:045E pid:07A5 ver:0797
    15:30:33.961 (ports): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    15:30:33.961 (ports): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#2320690#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    15:30:33.961 (ports): found_usb_device, loc=usb:0/140000/0/2/1    Port_#0001.Hub_#0003
    15:30:33.961 (ports): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0200
    15:30:33.961 (ports): found_usb_device, devinst=00000013
    15:30:33.961 (ports): add: loc=usb:0/140000/0/2/1, class=Ports, vid=16C0, pid=0483, ver=0200, serial=232, dev=\\?\usb#vid_16c0&pid_0483#2320690#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    15:30:33.961 (ports):   comport_from_devinst_list attempt
    15:30:33.961 (ports):   found Ports in classguid_list at index=0
    15:30:33.961 (ports):   port COM25 found from devnode
    15:30:33.961 (ports): found_usb_device complete
    15:30:33.962 (ports): usb_add: usb:0/140000/0/2/1  COM25 (Teensy 3.6) Serial
    15:30:33.967 (ports): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    15:30:33.968 (ports): nothing new, skipping HID & Ports enum
    15:30:34.172 (ports): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    15:30:34.172 (ports): nothing new, skipping HID & Ports enum
    15:30:34.928 (loader): redraw, image 9
    15:30:36.300 (ports): got command: "list"
    15:30:36.339 (loader): remote connection 1260 opened
    15:30:36.346 (serialmon): Begin, version=1.42-beta3-pre2, high-res time
    15:30:36.346 (serialmon): teensy_serialmon, cmdline='D:\arduino-1.8.5\hardware\tools\teensy_serialmon -v usb:0/140000/0/2/1'
    15:30:36.346 (serialmon): listening for location: usb:0/140000/0/2/1
    15:30:36.346 (serialmon): LoadLibrary cfgmgr32 ok
    15:30:36.346 (serialmon): LoadLibrary ntdll ok
    15:30:36.348 (serialmon): callback 0024
    15:30:36.348 (serialmon): callback 0081
    15:30:36.349 (serialmon): callback 0083
    15:30:36.350 (serialmon): hWnd = 3279444
    15:30:36.350 (serialmon): loop stdin, ready=2097151
    15:30:36.351 (serialmon): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#2320690#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    15:30:36.351 (serialmon): found_usb_device, loc=usb:0/140000/0/2/1    Port_#0001.Hub_#0003
    15:30:36.351 (serialmon): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0200
    15:30:36.351 (serialmon): found_usb_device, devinst=00000003
    15:30:36.351 (serialmon): add: loc=usb:0/140000/0/2/1, class=Ports, vid=16C0, pid=0483, ver=0200, serial=232, dev=\\?\usb#vid_16c0&pid_0483#2320690#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    15:30:36.351 (serialmon):   comport_from_devinst_list attempt
    15:30:36.352 (serialmon):   found Ports in classguid_list at index=0
    15:30:36.352 (serialmon):   port COM25 found from devnode
    15:30:36.352 (serialmon): found_usb_device complete
    15:30:36.353 (serialmon): usb_add: usb:0/140000/0/2/1
    15:30:36.353 (serialmon): translate "COM25" -> "\\.\COM25"
    15:30:36.353 (serialmon): Opened \\.\COM25 Serial
    15:30:48.013 (loader): Verbose Info event
  4. #54
    21,825
    Thanks for posting this! It's a huge help.
    I see at least a couple small things going wrong, so going to focus on those first. Also going to add a little more logging into teensy_serialmon. Hopefully you'll be able to get this neurotic thing to happen again?
    One of my many goals in this new scheme is making everything respond as quickly as possible. Previously I've "solved" problems by just adding delays. Trying really hard to avoid delays this time, and instead drive everything as much as possible from WM_DEVICECHANGE. But Windows is incredibly difficult. If you're willing to keep running these tests, maybe I'll try creating a version that registers for WM_DEVICECHANGE on more device class GUIDs? I can find lots of details on MSDN and in the header files, but Microsoft seems to have a terrible lack of guidance on how to actually use this stuff to rapidly respond to composite USB device arrival and removal. The really frustrating part how much things seem to vary between a fairly fresh Windows install and one that's been heavily used. At least we're finally getting better logging with high-res timestamps. Your testing is really helping now!
  5. #55
    11,506
    No, it can't.
    Good answer. Nice step forward. So much for taking the weekend off
    NOTE: I have STREAMING USB output - I stop AutoScroll and attempt to select to copy an output section - BAM - before I can select and copy 4 out of 5 tries the windows text jumps and the selection is voided. I have to page to the target area and try again. I suppose that behavior is beyond your control - but just in case . . .
    { kudos to koromix for his focus on this with tycommander! }
  6. #56
    11,506
    ... If you're willing to keep running these tests, ... Your testing is really helping now!
    Glad to help, yes I can run more tests.
    I have seen the neurosis twice now - IIRC it was caused both times with a Button press after successfully programming had the Teensy running - both times IIRC it was the T_3.6's Button.
    It seems neurosis also showed up when I unplugged both my running Teensys - the messages started spewing? Just did that again now and it did not go there with multiple plugs and a T_3.6 Button.
    HOWEVER - then doing a T_3.5 button and it is in SPAZ mode: Click image for larger version.
  7. #57
    21,825
    Yeah, some weekend plans didn't quite work out. Might take a little time this week, so if you see my pace slowing over the next few days... that's why.
  8. #58
    21,825
    Yeah, that's a bug on the Java side looking for the "Opened" string. It's assuming data will arrive 1 line at a time, which isn't true on Windows. I'll put in better parsing for the next beta.
  9. #59
    21,825
    @defragster - Can you try to get the neurotic problem to happen with these files?
    https://www.pjrc.com/teensy/beta/win...2b2_fixes3.zip
    This update adds numbering to the remote logging instances, which will make sorting out the similar-looking multiple instances much easier. I also fixed a minor bug in detecting HID devices, but that's unlikely to be the problem.
    Edit: this update also has several minor improvements on the Windows side, like showing anything teensy_reboot prints to the Arduino console without waiting for the process to end (not nearly as easy in Windows as on Mac & Linux).
  10. #60
    11,506
    Downloaded - will test in coming hours.
    Paul - I wasn't sure which to link where - but this user might have an issue to test? : PT-8211-and-teensy-3-2 >> mac with Elcapitan not working
  11. #61
    11,506
    Paul - switched to IDE w/td 1.42 beta w/fixes#3
    Here is a long TLoader_Verbose: This has twin T_3.5 + T_3.6 and various uploads that seemed to work - though the sketch pair isn't working just now. NOTE: TyCommander has HUNG some times after T_3.5 uploads on my system.
    I just saw this "Board at usb:0/140000/0/1 is not available" after I closed t_sermon after upload - then hit the T_ports and moved to Com10 - until then there was no connected t_sermon output?::
    teensy_serialmon, cmdline='T:\arduino_1.8.5_142\hardware\tools\teens y_serialmon -v usb:0/140000/0/2'
    callback 0024
    callback 0081
    callback 0083
    hWnd = 1117928
    found_usb_device, id=\\?\usb#vid_16c0&pid_0483#2114150#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    found_usb_device, loc=usb:0/140000/0/3/1 Port_#0001.Hub_#0003
    found_usb_device, devinst=00000002
    add: loc=usb:0/140000/0/3/1, class=Ports, vid=16C0, pid=0483, ver=0200, serial=211, dev=\\?\usb#vid_16c0&pid_0483#2114150#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    00000002, class=Ports, portname=COM12, id=USB\VID_16C0&PID_0483\2114150
    port COM12 found from devnode
    found_usb_device, id=\\?\usb#vid_16c0&pid_0483#2273070#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    found_usb_device, loc=usb:0/140000/0/2 Port_#0002.Hub_#0001
    found_usb_device, devinst=00000007
    add: loc=usb:0/140000/0/2, class=Ports, vid=16C0, pid=0483, ver=0200, serial=227, dev=\\?\usb#vid_16c0&pid_0483#2273070#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    00000007, class=Ports, portname=COM10, id=USB\VID_16C0&PID_0483\2273070
    port COM10 found from devnode
    translate "COM10" -> "\\.\COM10"
    Opened COM10 Serial
    usb_add: usb:0/140000/0/3/1
    You can set up a repro of what I'm doing with two SPI teensys wired like this: Project-SPI_MSTransfer :: Connects
    And it should run from Master/Slave in this library examples: Project-SPI_MSTransfer :: Library > SPI_MSTransfer.zip <link edited to V_0.0.16>
  12. #62
    Feb 2014
    Colmar, France
    2,573
    OSX 10.11 El Capitan was released in 2015. Since then, all users could upgrade for free to 10.12 Sierra in Sept 2016 and, again for free, to 10.13 High Sierra in Sept 2017. Thus, I‘m not sure if it makes sense to bother with that outdated stuff...
  13. #63
    11,506
    Paul - All is working well on Win 10 with teensy_sermon and two instances of the IDE [ one T_3.5 Slave code and the other T_3.6 Master code ].
    Both T_sermon title bars ODDLY indicate as before "[offline] (Teensy)" - when both are streaming data at 1,000 msgs/sec.
    For your reading enjoyment here is the current TLoader since my last post (opps 400K too big - have to zip):
    Thiery: that sounds to be an old and obscure build - but maybe it will work for free with the changes?
  14. #64
    21,825
    My goal as been to support Mac 10.7 (Lion) to the latest High Sierra. That's currently the range Arduino supports, but it's looking like they may drop Lion and maybe Mountain Lion support with a JRE update on 1.9.0.
    When the next version comes out with the 32 bit warnings, might be time to update my build system and drop Lion? Or maybe I can coax it to build 64 bit versions with my current system? (seem to recall an issue deep within wxWidgets using 64 bits & supporting very old MacOS)
  15. #65
    Feb 2014
    Colmar, France
    2,573
    These 32bit warnings are already in the current High Sierra 10.13.4 beta and I can tell you that these are annoying... Fortunately, I could already update or replace all my other apps to have a clean 64bit system - out of Teensyduino.
  16. #66
    21,825
    Yeah, that's a known bug. I'll work on it soon. I believe the Java code isn't properly parse the message teensy_serialmon sends to tell it the device is back online. Or it could be the Windows version of teensy_serialmon isn't sending it properly, or maybe some other issue? Been prioritizing the other problems higher than this, but it does need to get fixed before a 1.42 release.
  17. #67
    21,825
    I've got this on my list of upcoming issues. I'm not planning to install 10.13.4 beta. Going to deal with it when 10.13.4 releases.
    So far, I'm still on 10.13.3.
Name:	Screen Shot 2018-03-07 at 4.55.08 PM.png
  18. #68
    11,506
    Okay - noted as known - ugly but not critical.
    >> Is there any chance it relates to the one time the T_sermon didn't come back online - maybe it is sending an unexpected string/ID - COM10 was back online but: Board at usb:0/140000/0/1 is not available
    I've done muiltiple Uploads to both paired T_3.5 and T_3.6 with NO ISSUES.
    In the last 2.7+ hours at 1,000 / sec both T_sermons are running strong and fine message counter is at 10,063,420 and counting. { and the output on Slave comes from a 49 uS SPI message of 96 bytes from the Master }
  19. #69
    21,825
    Nope, that's a "real" bug. If it happens again, please save the log file!
  20. #70
    21,825
    Another question, how is the interactive speed looking on your system? One of the long-standing problems this was meant to solve is the need for extra delays (especially on Windows) before opening the COM port after uploading.
  21. #71
    11,506
    Was logged - see post #61
  22. #72
    11,506
    So far it seems Good and fast since first noted - reports Serial connect at 400 ms no issues.
  23. #73
    11,506
    Paul - is seems T_sermon is not asserting Serial ? Early note was clouded by having micros()<5000 not millis() - DOH!
    Sketch below shows lots of printing coming to T_sermon ( and IDE SerMon ) while ( !Serial )? It also shows IDE SerMon able to print but not 'telling' Teensy as fast as TyCommander, this agrees with prior discoveries of slow starting SerMon.
    It prints this in T_sermon either after Upload or on plugging in USB:
    Not Serial ??? @ millis=400
    Not Serial ??? @ millis=901
    Not Serial ??? @ millis=1401
    Not Serial ??? @ millis=1901
    Not Serial ??? @ millis=2401
    Not Serial ??? @ millis=2901
    Not Serial ??? @ millis=3401
    Not Serial ??? @ millis=3901
    Not Serial ??? @ millis=4401
    Not Serial ??? @ millis=4901
    Teensy !Serial ??? @ millis=5401
    T:\tCode\_TEENSY_INFO\StartPrint\StartPrint.ino Mar 8 2018 22:09:35
    Not Serial ???
    This Sketch running on T_3.5:
    	uint32_t foo = millis();
    	while (!Serial && millis() < 5000 )
    	{	Serial.print( "Not Serial ??? @ millis=" );
    		Serial.println( millis() );
    		while ( !Serial && ( millis() <= (foo + 500) ) );
    		foo += 500;
    	if ( !Serial )
    		Serial.print( "Teensy !Serial ??? @ millis=" );
    		Serial.print( "Teensy Serial Online !!! @ millis=" );
    	if ( !Serial )
    		Serial.println( "Not Serial ???" );
    		Serial.println( "YES Serial !!!" );
    Programming with IDE SerMon shows:
    Teensy Serial Online !!! @ millis=1926
    T:\tCode\_TEENSY_INFO\StartPrint\StartPrint.ino Mar 8 2018 22:08:26
    YES Serial !!!
    TyCommander shows this on plugging it in:
    Teensy Serial Online !!! @ millis=466
    YES Serial !!!
  24. #74
    21,825
    Here's a fix.
    Attached Files Attached Files
  25. #75
    21,825
    Also, this fixes a sort-of related problem, where (Serial) doesn't become false with Windows when you close the serial monitor.
    https://github.com/PaulStoffregen/co...92941b3cc03acd
    You'll probably also like another small change I put in, to shave the startup delay from 400 to 300 ms.
