Hi all.
I’m using the IntervalTimer class to run periodic processing on a T3.2. I also have an external signal that generates an interrupt on its rising edge. I need to time the interval between these interrupts with micro-second precision. One idea I have is to use the micros() function for this as shown in the code below.
So, my question -- Is the counter that keeps track of time for micros() disabled during interrupts? Since the IntervalTimer runs my periodicTask() so frequently, I’m concerned that my timing of the external interrupts will be thrown off if the counter for micros() doesn’t keep running.
If the counter does keep running during ISRs, I think I’m OK.
Otherwise, I was thinking of using one of the other Periodic Interrupt Timers (counter enabled but interrupt disabled) to count down from 0xFFFFFFFF. I could then read it during my serviceTrigger() ISR to determine the interval since the previous trigger (and then reset it to 0xFFFFFFFF). Thoughts?
Thanks.
Thanks.
void periodicTask(void);
IntervalTimer myTimer;
volatile uint32_t previousMicros, deltaMicros;
volatile bool newDeltaAvailable = false;
const uint8_t triggerPin = 2;
pinMode(triggerPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(triggerPin), serviceTrigger, RISING);
previousMicros = micros();
myTimer.begin(periodicTask, 200);
uint32_t deltaT;
if (newDeltaAvailable) {
noInterrupts();
deltaT = deltaMicros;
interrupts();
// Do stuff here with new deltaT value
void periodicTask() {
// Do periodic task here in ISR
void serviceTrigger() {
uint32_t currentMicros = micros();
deltaMicros = currentMicros - previousMicros;
previousMicros = currentMicros ;
newDeltaAvailable = true;
