Results 1 to 11 of 11
Thread: How to add a pre-compiled library?
    May 2017
    9
    I need to add a precompiled library (.a file) to a project. How can I accomplish that?
    The library is pre-compiled for the cortex M4.
    I'm using a Teensy 3.2
    Regards
    2,527
    I did this once and it's not pretty. Given your lib libtst.a
    cp libtst.a arduino-1.8.4/hardware/tools/arm/arm-none-eabi/lib/
    edit hardware/teensy/avr/boards.txt for each architecture
    teensy35.build.flags.libs=-larm_cortexM4lf_math -lm -ltst
    of course, you have to re-do this every time you upgrade IDE. maybe there is a better way
    22,080
    I recall seeing mention that Arduino added support for libraries with a pre-compiled .a file into newer versions. I haven't used it and I can't easily find any documentation on how it works, so maybe not?
    2,527
    there was discussion here https://github.com/arduino/Arduino/w...es-file-format
    but I haven't confirmed it works ...
    someone tried: https://github.com/arduino/Arduino/issues/7005
    EDIT: I don't think the precompiled lib stuff works. I tried with the T3.5/3.6 CryptoAccel library. I edited library.properties and created src/cortex-m4/libcau.a, and built my crypto benchmark sketch (verbose) with 1.8.4. I get undefined references, and the link command shows no references to libcau. Possibly, teensyduino might have to be modified to support the precompiled options ??
    For now, use the method described in post #2
    May 2017
    9
    Hello and thank you for your replys. I got it working in the meantime.
    I copied the .a file to
    <Arduino_Install_Dir>\hardware\tools\arm\arm-none-eabi\lib
    Then I edited the boards.txt file found here:
    <Arduino_Install_Dir>\hardware\teensy\avr\boards.t xt
    The library to add be used must be edited before the -lm option
    Example
    Before:
    teensy31.build.flags.libs=-larm_cortexM4l_math -lm
    After:
    teensy31.build.flags.libs=-larm_cortexM4l_math -lmylib -lm
    The sketch compiles and links and I successfully called a library function with a correct output.
    Of course this solution is suboptimal since from now on mylib is linked into every teensy31/32 project.
    2,527
    Quote Originally Posted by sevenEleven View Post
    No harm. If your sketch doesn't have any references to symbols in your mylib, nothing will be linked in
    Senior Member Blackaddr's Avatar
    Mar 2017
    Canada
    262
    Here's my understanding of how the static libraries work. Please correct me if I'm wrong.
    Static library files (.a) are 'archives' of the object files that were compiled (.o). You can think of a .a file as tarball of the .o files. When the linker uses this library, you can think of it like extracting the tarball back to object .o files, then only linking the object files you need into the final binary.
    Here's an example.
    sourceA.c contains FunA1() and FunA2().
    sourceB.c contains FunB()
    The library file source.a contains sourceA.o and sourceB.o.
    The user is ONLY USING FunA1() from the library. Since the sourceA.o is needed, the entire object files contents ends up in the final binary, even though FunA2() isn't actually needed. Nothing from SourceB.o was needed, so FunB() will not end up in the binary.
    Thus, when designing a static library, think about how you break up the functions into source files if you are concerned about the size of the final binary.
    22,080
    Yes, that's pretty much it. Often the term "compile unit" is used for the all-or-nothing chunk of data which the linker must include.
    By default, Arduino uses "-ffunction-sections -fdata-sections" as it compiles code. This is supposed to cause each function and each global scope variable to become its own compile unit. It greatly helps reduce code size without the need to create so many very small files. Much of the advise you'll see on general non-Arduino programming sites is written for the compiler's default where everything from a single .c or .cpp file becomes a .o file with only 1 compile unit.
    Mar 2017
    Canada
    262
    Thanks Paul, that's good to know! That will save me from having to break up my library into more source files than I would otherwise like.
    3,743
    Cool
    To be pedantic, in addition to using "-ffunction-sections -fdata-sections" when it compiles code, Arduino needs to pass -Wl,--gc-sections when linking, so that the linker will actually delete the various sections that aren't used by active code.
    Quote Originally Posted by Blackaddr View Post
    If you can, be sure to compile your library with "-ffunction-sections -fdata-sections", to allow unused functions and data to be discarded.
    Apr 2013
    151
    An support for precompiled would be nice
