Results 1 to 3 of 3
Thread: Small size AudioBorad
    Nov 2015
    186
    Hi, do you know if there is a narrower version of the audioboard?
    I have to include it in a project but the 'regular' one is a little big.
    I read that if they do not overlap, there may be communication problems ... is it true? can it be solved?
    20,681
    This one is smaller, but has almost no features beyond basic line-level output.
    https://www.pjrc.com/store/pt8211_kit.html
    While it's best to keep the wires short, plenty of people have made the audio board work when located a couple inches away. Just keep the wires short and make sure there's a good ground direct connection between the two.
    Nov 2015
    186
    Thank you Paul!
    With this board can I do the same things I would do with the normal audio board?
    Synthesis, play audio files etc?
