computerjlt
New member
Hello everyone.
I'm working on a project that will send out CAN messages and respond to messages on a bus in a car. timing is fairly critical as some messages happen very often some not so much.
Is there an easier way with FlexCAN (or any other library) to time these without having to closely time the loop making things extremely complicated? for instance with one ecm function, weather its on or off sends 4 different packets in order repeating indefintaly at 20ms per packet. if the ecm doesn't see these in order or the timing is too far out it stops listening. i'm able to successfully replay these with kvaser hardware on a computer and i've got the teensy to do so similar on a bench. i'm just looking for an easier way to time the messaging without using any delays or convoluted code.
Also is there more reading available for flexcan or other can libraries that isn't just a few vague sentences on the github? I'm having to figure out some of the syntax and such by reading other projects code and just guess and testing on a lot of this.
