soundstream32
Hi i'm new in this forum and i'm new with the teensy, i was making a project with arduino but i run out of memory program and ram, so i searched for other boards with more resourses and compartible with arduino and i found teensy, so i bought a teensy 3.5,the thing is that im using a library that uses the sdfat library the library is for reading standar midi files and is this https://majicdesigns.github.io/MD_MIDIFile/ so i wonder if i can use this library with the teensy without modification in my code, because i see the class that is used for the teensy in the sdfat library is the SdFatSdio and no the SD, and if i need to do some modifications in the library what do i need to do i'm really noob about this device and arduino so i hope you can help me with this and if some one has use this library with a teensy maybe you can give me some advices . sorry for the bad english but i'm not a native speaker.
