Hi Guys...,
I've created a keyboard with illuminated buttons, when a button is pressed it illuminates the LED then sends the keyboard command.
My problem, it works, but the keys are only being seen by the selected program and not the system overall. (Windows 10 64bit)
If I press the same keyboard combination on a normal keyboard the key press work as I want them to, no matter which program I have selected/active.
I'm using OBS - open broadcast system to send an output to a big screen at a soccor ground, so when I press CTRL-ALT-F1 a certain graphics is selected, likewise CTRL-ALT-F2 a video is played of a recent goal... I can be in another program and press the keyboard combinations and it will still affect OBS, as in... it will change scenes.
When I do the same with my prototype keyboard it doesn't only the selected program see's the key presses, so only works when OBS is the selected/active program.
Any Ideas how I can get the Teensy to send the keyboard keys to windows and not just the active program?
Code snipped
Here is the keyboard and an example of what I am doing with it.
https://youtu.be/wY4b77sp_0M
Thanks in advance
Steve
Code snipped
if (button1.risingEdge()) {
//Keyboard.println("B1 release");
Keyboard.press(MODIFIERKEY_CTRL);
Keyboard.press(MODIFIERKEY_ALT);
Keyboard.press(KEY_F11);
Keyboard.releaseAll();
Thanks in advance
Steve
