Teensy 3.5 only works with torsion applied to board
DJ Namaste
Hello, I have a teensy 3.5 that will only work if pressure is applied on the board after a hard fall/impact to the board. I am wondering if I can resolder by hot plate method with the 3.5? Any other tips?
Does sound like a joint has parted, and in theory the ride on the hot plate might fix it. Certainly not aware of any other magic tricks for this one.
If the board's already damaged, seems like there's probably not a lot of risk. Well, other than time & effort spent. But if you have the time and it's interesting to do, then why not?
I know I've sometimes poured way more time into fixing stuff than I probably should. Just ask Robin about our old dishwasher....
