Results 1 to 5 of 5
Thread: Inverting pin signal for bi-color led
    Mar 2014
    19
    I'm sure this is documented somewhere, but I can't find it...
    Looking at picking up a bi-color led like this:
    https://www.mouser.com/ds/2/26/Apem_...Q6-1158530.pdf
    The color is changed by reversing the polarity of the supply voltage.
    Clueless as to how to implement this. AnalogWrite() does not accept negative value, AFAIK.
    Feb 2014
    Colmar, France
    2,530
    With a 150R current limiter resistor between 2 GPIO pins. Drive one high, the second low (always with digitalWrite()) = one color. Drive the first low, the second high = other color. Both high or both low = LED off.
    Feb 2014
    Colmar, France
    2,530
    It was documented in the electronics class in secondary school...
    Senior Member Wozzy's Avatar
    354
    You can also use the method described in THIS POST to drive your Bicolor LED, from only a single pin.
    This can give you Red Green or Yellow.
    EDIT: Actually, Never Mind... this won't work because you can't tie in between the two LEDs on a two pin device.
    Theremingenieur's method is the way to go. Note that you can also get yellow by toggling between the two states very rapidly.
    Mar 2014
    19
    thanks for your response.
    Must stop nodding off in class....
