CollinDietz
New member
I have a Teensy 3.2 with the vin-vusb trace cut to allow external power use. It was functioning fine a day ago, and now it won't power on without the usb plugged into the computer. I have confirmed the battery is charged and delivering power, and there is an amperage draw from the battery in both cases, but the Teensy won't run even blink without being plugged into the computer.
It is soldered into a pcb, but I don't have the schematics.
The teensy is activated by a pulse to a STR which connects the GND line of the teensy to the gnd line of the battery, the Teensy then locks this connection by holding pin 23 high, which is linked to the same input on the STR
Any help is appreciated!
