ILI9325 with teensy 3.5 please really need help
hi i'm trying to get it work a ILI9325 tft with the teensy 3.5, i have tried modifying some libraries but i have no success. does some one have a library that works with this controller and this teensy board ? i really need to use the tft.
Any more info on the unit you have? Where it came from? Is it still 320x240? Search shows Adafruit has one in 2.8" and another noted one 3.2" both 320x240 so the code they use may work. First page didn't show one at 3.5"
Thanks to reply the tft is actually a 2.4 touch shield for arduino uno is from mcufriends is like this:
http://www.microcontroller-project.com/uploads/2/2/1/5/22159166/8044063_orig.jpg
i actually tried with Adafruit_TFTLCD but it don't copile
Went to https://www.adafruit.com 2.8" ILI9325 and it linked to the ILI9341
PJRC store has one of these in 2.8" with Touch that has excellent/awesome support for Teensy. They have a 2.4" with no touch hardware.
I didn't look close enough to see what library it uses for ili9325 - if it maps to something in the TeensyDuino install that would be good to make sure it is used. And then there may be some edits that won't compile due to erroneous or missing #defines? If the verbose compile errors were posted that could be determined and perhaps resolved. That output will show what libraries are used from where.
Also link to or include the sample sketch used. The ILI9341 is way more popular and better supported. It was exciting to see suggestion of a 3.5" display :(
i bougth this display because is the only one i found in my city if i order one from the internet it would take a lot of time to arrive and i really need it to work. i see in other post other people have copile sucessfully the adrafruit library but i can't made it work
Hopefully there is a solution. Even theILI9341 had issues at points with changes to Adafruit libraries making it fail to compile - the ones I recall were from trivial changes to min() and max() ...
Please re-read the rest of that quote - reproduced below with emphasis. It relates to "Forum Rule: Always post complete source code & details to reproduce any issue!". Without this info there is no way of knowing the nature of the failure only seen ...
Also link to or include the sample sketch used. ...
Also if references to the posts where it was seen to have worked could be provided they might help bridge the gap.
Maybe this can help?
https://forum.pjrc.com/threads/3874...dafruit_TFTLCD?p=120875&viewfull=1#post120875
Perhaps you could try following the description on that thread in msg #8 ?
Yes, it would be easier if someone does this for you, but really, how hard is it to just delete 1 line, or add the 2 lines as described in msg #8?
i have follow that post and made all the changes, but as i said i can't made it compile. The problem is that i get errors in the pin_magic.h the error menssage is this
Arduino:1.8.5 (Windows 8.1), TD: 1.41, Tarjeta:"Teensy 3.5, Serial, 120 MHz, Fastest + pure-code with LTO, US English"
In file included from G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:21:0:
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:282:33: warning: backslash and newline separated by space
   #define read8inline(result) { \
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:350:3: error: #error "Board type unsupported / not recognized"
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In constructor 'Adafruit_TFTLCD::Adafruit_TFTLCD(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:46:3: error: '_reset' was not declared in this scope
   _reset     = reset;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:59:3: error: 'csPinSet' was not declared in this scope
   csPinSet   = digitalPinToBitMask(cs);
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:60:3: error: 'cdPinSet' was not declared in this scope
   cdPinSet   = digitalPinToBitMask(cd);
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:61:3: error: 'wrPinSet' was not declared in this scope
   wrPinSet   = digitalPinToBitMask(wr);
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:62:3: error: 'rdPinSet' was not declared in this scope
   rdPinSet   = digitalPinToBitMask(rd);
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:63:3: error: 'csPinUnset' was not declared in this scope
   csPinUnset = ~csPinSet;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:64:3: error: 'cdPinUnset' was not declared in this scope
   cdPinUnset = ~cdPinSet;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:65:3: error: 'wrPinUnset' was not declared in this scope
   wrPinUnset = ~wrPinSet;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:66:3: error: 'rdPinUnset' was not declared in this scope
   rdPinUnset = ~rdPinSet;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::begin(uint16_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:380:22: error: 'csPort' was not declared in this scope
  #define CS_ACTIVE  *csPort &=  csPinUnset
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:264:5: note: in expansion of macro 'CS_ACTIVE'
     CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:380:33: error: 'csPinUnset' was not declared in this scope
     CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:278:5: note: in expansion of macro 'CS_ACTIVE'
     CS_ACTIVE;
     CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:276:14: warning: unused variable 'a' [-Wunused-variable]
     uint16_t a, d;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:276:17: warning: unused variable 'd' [-Wunused-variable]
     uint16_t a, d;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:304:5: note: in expansion of macro 'CS_ACTIVE'
     CS_ACTIVE;
     CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:378:22: error: 'cdPort' was not declared in this scope
  #define CD_COMMAND *cdPort &=  cdPinUnset
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:315:2: note: in expansion of macro 'CD_COMMAND'
  CD_COMMAND;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:378:33: error: 'cdPinUnset' was not declared in this scope
  CD_COMMAND;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:379:33: error: 'cdPinSet' was not declared in this scope
  #define CD_DATA    *cdPort |=  cdPinSet
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:317:2: note: in expansion of macro 'CD_DATA'
  CD_DATA;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:381:33: error: 'csPinSet' was not declared in this scope
  #define CS_IDLE    *csPort |=  csPinSet
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:322:2: note: in expansion of macro 'CS_IDLE'
  CS_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:332:5: note: in expansion of macro 'CS_ACTIVE'
     CS_ACTIVE;
     CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::reset()':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:381:22: error: 'csPort' was not declared in this scope
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:350:3: note: in expansion of macro 'CS_IDLE'
   CS_IDLE;
   CS_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:377:22: error: 'wrPort' was not declared in this scope
  #define WR_IDLE    *wrPort |=  wrPinSet
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:352:3: note: in expansion of macro 'WR_IDLE'
   WR_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:377:33: error: 'wrPinSet' was not declared in this scope
   WR_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:375:22: error: 'rdPort' was not declared in this scope
  #define RD_IDLE    *rdPort |=  rdPinSet
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:353:3: note: in expansion of macro 'RD_IDLE'
   RD_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:375:33: error: 'rdPinSet' was not declared in this scope
   RD_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:360:6: error: '_reset' was not declared in this scope
   if(_reset) {
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:368:3: note: in expansion of macro 'CS_ACTIVE'
   CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:369:3: note: in expansion of macro 'CD_COMMAND'
   CD_COMMAND;
   CD_COMMAND;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:376:33: error: 'wrPinUnset' was not declared in this scope
  #define WR_ACTIVE  *wrPort &=  wrPinUnset
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:387:21: note: in expansion of macro 'WR_ACTIVE'
 #define WR_STROBE { WR_ACTIVE; WR_IDLE; }
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:371:30: note: in expansion of macro 'WR_STROBE'
   for(uint8_t i=0; i<3; i++) WR_STROBE; // Three extra 0x00s
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::setAddrWindow(int, int, int, int)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:379:3: note: in expansion of macro 'CS_ACTIVE'
   CS_ACTIVE;
   CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:451:3: note: in expansion of macro 'CS_IDLE'
   CS_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::setLR()':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:461:3: note: in expansion of macro 'CS_ACTIVE'
   CS_ACTIVE;
   CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:464:3: note: in expansion of macro 'CS_IDLE'
   CS_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::flood(uint16_t, uint32_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:475:3: note: in expansion of macro 'CS_ACTIVE'
   CS_ACTIVE;
   CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:476:3: note: in expansion of macro 'CD_COMMAND'
   CD_COMMAND;
   CD_COMMAND;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:489:3: note: in expansion of macro 'CD_DATA'
   CD_DATA;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:376:22: error: 'wrPort' was not declared in this scope
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:501:9: note: in expansion of macro 'WR_STROBE'
         WR_STROBE; WR_STROBE; WR_STROBE; WR_STROBE; // 2 bytes/pixel
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:387:32: note: in expansion of macro 'WR_IDLE'
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:501:20: note: in expansion of macro 'WR_STROBE'
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:501:31: note: in expansion of macro 'WR_STROBE'
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:501:42: note: in expansion of macro 'WR_STROBE'
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:502:9: note: in expansion of macro 'WR_STROBE'
         WR_STROBE; WR_STROBE; WR_STROBE; WR_STROBE; // x 4 pixels
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:502:20: note: in expansion of macro 'WR_STROBE'
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:502:31: note: in expansion of macro 'WR_STROBE'
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:502:42: note: in expansion of macro 'WR_STROBE'
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:507:7: note: in expansion of macro 'WR_STROBE'
       WR_STROBE;
       WR_STROBE;
       WR_STROBE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:508:7: note: in expansion of macro 'WR_STROBE'
       WR_STROBE;
       WR_STROBE;
       WR_STROBE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:523:3: note: in expansion of macro 'CS_IDLE'
   CS_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'virtual void Adafruit_TFTLCD::fillScreen(uint16_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:622:5: note: in expansion of macro 'CS_ACTIVE'
     CS_ACTIVE;
     CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'virtual void Adafruit_TFTLCD::drawPixel(int16_t, int16_t, uint16_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:642:3: note: in expansion of macro 'CS_ACTIVE'
   CS_ACTIVE;
   CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:679:5: note: in expansion of macro 'CD_COMMAND'
     CD_COMMAND; write8(0x22); CD_DATA; write8(hi); write8(lo);
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:679:31: note: in expansion of macro 'CD_DATA'
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:684:5: note: in expansion of macro 'CD_COMMAND'
     CD_COMMAND;
     CD_COMMAND;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:686:5: note: in expansion of macro 'CD_DATA'
     CD_DATA;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:690:3: note: in expansion of macro 'CS_IDLE'
   CS_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::pushColors(uint16_t*, uint8_t, boolean)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:700:3: note: in expansion of macro 'CS_ACTIVE'
   CS_ACTIVE;
   CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:702:5: note: in expansion of macro 'CD_COMMAND'
     CD_COMMAND;
     CD_COMMAND;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:379:22: error: 'cdPort' was not declared in this scope
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:710:3: note: in expansion of macro 'CD_DATA'
   CD_DATA;
   CD_DATA;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:718:3: note: in expansion of macro 'CS_IDLE'
   CS_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'virtual void Adafruit_TFTLCD::setRotation(uint8_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:727:3: note: in expansion of macro 'CS_ACTIVE'
   CS_ACTIVE;
   CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'uint16_t Adafruit_TFTLCD::readPixel(int16_t, int16_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:816:3: note: in expansion of macro 'CS_ACTIVE'
   CS_ACTIVE;
   CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:843:7: note: in expansion of macro 'CD_COMMAND'
       CD_COMMAND; write8(0x00); write8(0x22); // Read data from GRAM
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:844:7: note: in expansion of macro 'CD_DATA'
       CD_DATA;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:852:5: note: in expansion of macro 'CS_IDLE'
     CS_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:860:5: note: in expansion of macro 'CD_COMMAND'
     CD_COMMAND; write8(0x22); // Read data from GRAM
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:862:5: note: in expansion of macro 'CD_DATA'
     CD_DATA;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:868:5: note: in expansion of macro 'CS_IDLE'
     CS_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'uint16_t Adafruit_TFTLCD::readID()':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:913:3: note: in expansion of macro 'CS_ACTIVE'
   CS_ACTIVE;
   CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:914:3: note: in expansion of macro 'CD_COMMAND'
   CD_COMMAND;
   CD_COMMAND;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:916:3: note: in expansion of macro 'WR_STROBE'
   WR_STROBE;     // Repeat prior byte (0x00)
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:918:3: note: in expansion of macro 'CD_DATA'
   CD_DATA;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:922:3: note: in expansion of macro 'CS_IDLE'
   CS_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'uint32_t Adafruit_TFTLCD::readReg(uint8_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:933:3: note: in expansion of macro 'CS_ACTIVE'
   CS_ACTIVE;
   CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:934:3: note: in expansion of macro 'CD_COMMAND'
   CD_COMMAND;
   CD_COMMAND;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:937:3: note: in expansion of macro 'CD_DATA'
   CD_DATA;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:950:3: note: in expansion of macro 'CS_IDLE'
   CS_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::write8(uint8_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:968:21: error: 'write8inline' was not declared in this scope
   write8inline(value);
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'uint8_t Adafruit_TFTLCD::read8fn()':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:975:21: error: 'read8inline' was not declared in this scope
   read8inline(result);
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::setWriteDir()':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:982:21: error: 'setWriteDirInline' was not declared in this scope
   setWriteDirInline();
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::setReadDir()':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:988:20: error: 'setReadDirInline' was not declared in this scope
   setReadDirInline();
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::writeRegister8(uint8_t, uint8_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:394:3: note: in expansion of macro 'CD_COMMAND'
   CD_COMMAND; write8(a); CD_DATA; write8(d); }
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:994:3: note: in expansion of macro 'writeRegister8inline'
   writeRegister8inline(a, d);
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:394:26: note: in expansion of macro 'CD_DATA'
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::writeRegister16(uint16_t, uint16_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:400:28: note: in expansion of macro 'CD_COMMAND'
   hi = (a) >> 8; lo = (a); CD_COMMAND; write8(hi); write8(lo); \
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:1000:3: note: in expansion of macro 'writeRegister16inline'
   writeRegister16inline(a, d);
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:401:28: note: in expansion of macro 'CD_DATA'
   hi = (d) >> 8; lo = (d); CD_DATA   ; write8(hi); write8(lo); }
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::writeRegisterPair(uint8_t, uint8_t, uint16_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:406:3: note: in expansion of macro 'CD_COMMAND'
   CD_COMMAND; write8(aH); CD_DATA; write8(hi); \
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:1006:3: note: in expansion of macro 'writeRegisterPairInline'
   writeRegisterPairInline(aH, aL, d);
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:406:27: note: in expansion of macro 'CD_DATA'
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::writeRegister24(uint8_t, uint32_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:1012:3: note: in expansion of macro 'CS_ACTIVE'
   CS_ACTIVE;
   CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:1013:3: note: in expansion of macro 'CD_COMMAND'
   CD_COMMAND;
   CD_COMMAND;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:1015:3: note: in expansion of macro 'CD_DATA'
   CD_DATA;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:1022:3: note: in expansion of macro 'CS_IDLE'
   CS_IDLE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::writeRegister32(uint8_t, uint32_t)':
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:1028:3: note: in expansion of macro 'CS_ACTIVE'
   CS_ACTIVE;
   CS_ACTIVE;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:1029:3: note: in expansion of macro 'CD_COMMAND'
   CD_COMMAND;
   CD_COMMAND;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:1031:3: note: in expansion of macro 'CD_DATA'
   CD_DATA;
G:\Documentos\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:1040:3: note: in expansion of macro 'CS_IDLE'
   CS_IDLE;
The post don't mention what to change in the pin_magic so that's why i ask for help here.
