So I am running into a problem with my project. I hear a lot of noise when using the digitalRead as the cue to play a sound. I am using mpr121 capacitive touch sensors to get input from the user. An arduino uno is interpreting which pins have been touch and sending a digital high signal to the teensy 3.2 to play the corresponding sound. The sounds do play when the touch is detected but there is a beep that is playing over them and persist if the touch sensor is held. I am using a modified version of the sample player example with digitalRead instead of buttons.
I have the arduino, capacitive touch, and teensy all wired to the same ground. Any solutions to this problem would be greatly appreciated.
#include <SerialFlash.h>
#include <Bounce.h>
// WAV files converted to code by wav2sketch
#include "AudioSampleSnare.h" // http://www.freesound.org/people/KEVOY/sounds/82583/
#include "AudioSampleTomtom.h" // http://www.freesound.org/people/zgump/sounds/86334/
#include "AudioSampleHihat.h" // http://www.freesound.org/people/mhc/sounds/102790/
#include "AudioSampleKick.h" // http://www.freesound.org/people/DWSD/sounds/171104/
#include "AudioSampleGong.h" // http://www.freesound.org/people/juskiddink/sounds/86773/
#include "AudioSampleCashregister.h" // http://www.freesound.org/people/kiddpark/sounds/201159/
// Create the Audio components. These should be created in the
// order data flows, inputs/sources -> processing -> outputs
AudioPlayMemory sound0;
AudioPlayMemory sound1; // six memory players, so we can play
AudioPlayMemory sound2; // all six sounds simultaneously
AudioPlayMemory sound3;
AudioPlayMemory sound4;
AudioPlayMemory sound5;
AudioMixer4 mix1; // two 4-channel mixers are needed in
AudioMixer4 mix2; // tandem to combine 6 audio sources
AudioOutputI2S headphones;
AudioOutputAnalog dac; // play to both I2S audio board and on-chip DAC
// Create Audio connections between the components
AudioConnection c1(sound0, 0, mix1, 0);
AudioConnection c2(sound1, 0, mix1, 1);
AudioConnection c3(sound2, 0, mix1, 2);
AudioConnection c4(sound3, 0, mix1, 3);
AudioConnection c5(mix1, 0, mix2, 0); // output of mix1 into 1st input on mix2
AudioConnection c6(sound4, 0, mix2, 1);
AudioConnection c7(sound5, 0, mix2, 2);
AudioConnection c8(mix2, 0, headphones, 0);
AudioConnection c9(mix2, 0, headphones, 1);
AudioConnection c10(mix2, 0, dac, 0);
// Create an object to control the audio shield.
AudioControlSGTL5000 audioShield;
int val0 = 0;
int val1=0;
int val2= 0;
int val3= 0;
int val4=0;
pinMode(0, INPUT_PULLDOWN);
pinMode(1, INPUT_PULLDOWN);
pinMode(2, INPUT_PULLDOWN);
pinMode(3, INPUT_PULLDOWN);
pinMode(4, INPUT_PULLDOWN);
pinMode(5, INPUT_PULLDOWN);
// Audio connections require memory to work. For more
AudioMemory(10);
// turn on the output
audioShield.enable();
audioShield.volume(0.5);
// by default the Teensy 3.1 DAC uses 3.3Vp-p output
// if your 3.3V power has noise, switching to the
// internal 1.2V reference can give you a clean signal
//dac.analogReference(INTERNAL);
// reduce the gain on mixer channels, so more than 1
// sound can play simultaneously without clipping
mix1.gain(0, 0.4);
mix1.gain(1, 0.4);
mix1.gain(2, 0.4);
mix1.gain(3, 0.4);
mix2.gain(1, 0.4);
mix2.gain(2, 0.4);
val0=digitalRead(2);
val1=digitalRead(3);
val2=digitalRead(4);
val3=digitalRead(5);
val4=digitalRead(6);
if (val0 == true) {
sound0.play(AudioSampleSnare);
if (val1 == true) {
sound1.play(AudioSampleTomtom);
if (val2 == true) {
sound2.play(AudioSampleHihat);
if (val3 == true) {
sound3.play(AudioSampleKick);
if (val4 == true) {
sound4.play(AudioSampleGong);
