In short I am trying to read the output of a DC motor using a teensy 3.6 and then send this data to matlab to display! The problem I am having is I dont seem to be getting enough data points in Matlab. Im unsure of where to go next any help would be appreciated!
MATLAB CODE:
%%Clear comm port
if ~isempty(instrfind)
fclose(instrfind);
delete(instrfind);
end
%%Clear all variables
clear all;
close all;
SerialPort='com5'; %serial port
TimeInterval=0.01;%time interval between each input.
loop=15;%count values
%%Set up the serial port object
s = serial(SerialPort,'BaudRate',115200);
fopen(s);
time =now;
voltage = 0;
%% Set up the figure
figureHandle = figure('NumberTitle','off',...
'Name','Voltage Characteristics',...
'Color',[0 0 0],'Visible','off');
% Set axes
axesHandle = axes('Parent',figureHandle,...
'YGrid','on',...
'YColor',[0.9725 0.9725 0.9725],...
'XGrid','on',...
'XColor',[0.9725 0.9725 0.9725],...
'Color',[0 0 0]);
hold on;
plotHandle = plot(axesHandle,time,voltage,'Marker','.','LineWidth',1,'Color',[0 1 0]);
xlim(axesHandle,[min(time) max(time+0.001)]);
xlabel('Time','FontWeight','bold','FontSize',14,'Color',[1 1 0]);
ylabel('Voltage in V','FontWeight','bold','FontSize',14,'Color',[1 1 0]);
title('Real Time Data','FontSize',15,'Color',[1 1 0]);
%% Initializing variables
voltage(1) = 0;
time(1)=0;
count = 2;
k=1;
fwrite(s,1,'int'); %write data
while ~isequal(count,loop)
%Serial data accessing
voltage(count) = fscanf(s,'%f',1);
voltage = a.analogRead(0)
time(count) = count;
set(plotHandle,'YData',voltage,'XData',time);
set(figureHandle,'Visible','on');
datetick('x','mm/DD HH:MM');
pause(TimeInterval);
count = count +1;
end
fwrite(s,2,'int'); %write data
%% Clean up the serial port
fclose(s);
delete(s);
clear s;
ARDUINO CODE:
#include <ADC.h>
int out1 = 0;
int j =0;
ADC *adc = new ADC();
void setup(){
adc->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH_SPEED);
adc->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPEED);
adc->setResolution(8);
pinMode(2,OUTPUT) ; //Logic pins are also set as output
pinMode(3,OUTPUT) ;
pinMode(32, INPUT_DISABLE);
j = Serial.read() ;
if(j==1){
digitalWrite(2,LOW) ;
digitalWrite(3,HIGH) ;
out1 = adc->analogRead(32);
Serial.print(out1);
Serial.print('\n');
if(j==2){
digitalWrite(2,LOW);
digitalWrite(3,LOW);
MATLAB CODE:
%%Clear comm port
fclose(instrfind);
delete(instrfind);
end
clear all;
close all;
fopen(s);
time =now;
voltage = 0;
% Set axes
'YGrid','on',...
'XGrid','on',...
'Color',[0 0 0]);
hold on;
voltage(1) = 0;
time(1)=0;
count = 2;
k=1;
count = count +1;
end
fclose(s);
delete(s);
clear s;
ARDUINO CODE:
#include <ADC.h>
int out1 = 0;
int j =0;
void setup(){
pinMode(3,OUTPUT) ;
j = Serial.read() ;
if(j==1){
Serial.print(out1);
Serial.print('\n');
if(j==2){
