I am Enzo and I am new to the Teensy world. I need your help to get started with a project that shuould use audio board and a wifi module. I would like to use a Teensy 3.6: it should process a audio stream and then send data to multiple network devices.
I'll summarize my doubts/questions below:
1- I need to open multiple (two/three) TCP sockets and, probably, I need to handle a UDP data stream (but just one). If I am right I can do all this stuff with a Atwin1500C. Can you confirm it please?
2- For audio processing I'll use the Audio Board. I whatched the workshop video more times and it should be perfect for my needs. Can I use it with the Atwin1500C? It is not clear how they can share the SPI bus and I am not sure how I can configure each devices.
I would be glad for any help and/or any link that can help me. When I search on Google I am overwhelmed by the results so I don't know which is the better answer.
Thank you very much
Enzo
Thank you very much
Enzo
