I'm using 3.2 on Ubuntu 16.04 without the Arduino IDE as explained at
http://blogs.omnicron.com/ford/2015/06/17/easy-teensy-development-on-ubuntu/
The following test program is included
Instead of PC5 (pin 13), I want to toggle pin 10, how can I do it?
Thank you for your help in advance.
#include "common.h"
#define LED_ON GPIOC_PSOR=(1<<5)
#define LED_OFF GPIOC_PCOR=(1<<5)
int main(void)
volatile uint32_t n;
uint32_t v;
uint8_t mask;
PORTC_PCR5 = PORT_PCR_MUX(0x1); // LED is on PC5 (pin 13), config as GPIO (alt = 1)
GPIOC_PDDR = (1<<5); // make this an output pin
LED_OFF; // start with LED off
v = (uint32_t)mcg_clk_hz;
v = v / 1000000;
while (1)
for (n=0; n<1000000; n++) ; // dumb delay
mask = 0x80;
while (mask != 0)
LED_ON;
for (n=0; n<1000; n++) ; // base delay
if ((v & mask) == 0) LED_OFF; // for 0 bit, all done
for (n=0; n<2000; n++) ; // (for 1 bit, LED is still on)
LED_OFF;
mask = mask >> 1;
return 0; // should never get here!
