Results 1 to 10 of 10
Thread: How can i use DAC0 for analog input and DAC1 for audio output?
    Mar 2018
    8
    Hi
    i need to use analogRead(A21), and use audio output on DAC1.
    thank you
    2,633
    This works for me on T3.6
      analogReadResolution(12);
      analogWriteResolution(12);
      for (int i = 0; i < 4095; i += 64) {
        analogWrite(A22, i);
        delayMicroseconds(3); // DAC settle
        Serial.printf("DAC out %d  A21 %d\n", i, analogRead(A21));
    jumper A21 to A22
    Mar 2018
    8
    I use audio library so the write to the dac is via the play function (playing wave files) ... so what adjustments i have to do to make it work...
    this is the base functions i use:
    Sound.play(file name on sd);
    analogRead(A21);
    when reading A21 with no sound library included it work ok!!
    2,633
    So we don't have to guess what your sketch is doing, obey the forum rule above:
    The audio lib is probably configuring both DAC pins for output, precluding use with analogRead(). You may have to modify the audio lib.
    Mar 2018
    8
    This ia the code
    #include <Time.h>
    #include <TimeLib.h>
    #include <TimeAlarms.h>
    int sensoreCount = 24;
    int boardActive = 1;//Will toggle Board Activation
    #define SDCARD_CS_PIN    BUILTIN_SDCARD
    const int knockSensors [24] = {A0, A1, A2, A3, A4, A5, A10, A11, A8, A9, A6, A7, A12, A13, A14, A15, A16, A17, A18, A19, A20, A21, A23, A24};
    const long soundInterval = 300;
    unsigned long currentTiming = millis();
    AudioPlaySdWav     Sound[12];
    AudioMixer4              mixer3;
    AudioMixer4              mixer2;
    AudioMixer4              mixer1;
    AudioMixer4              mixer4;
    AudioOutputAnalogStereo  dacs1;
    AudioConnection          patchCord1(Sound[0], 0, mixer1, 0);
    AudioConnection          patchCord2(Sound[1], 0, mixer1, 1);
    AudioConnection          patchCord3(Sound[2], 0, mixer1, 2);
    AudioConnection          patchCord5(Sound[3], 0, mixer1, 3);
    AudioConnection          patchCord4(Sound[4], 0, mixer2, 0);
    AudioConnection          patchCord6(Sound[5], 0, mixer2, 1);
    AudioConnection          patchCord7(Sound[6], 0, mixer2, 2);
    AudioConnection          patchCord8(Sound[7], 0, mixer2, 3);
    AudioConnection          patchCord9(Sound[8], 0, mixer3, 0);
    AudioConnection          patchCord10(Sound[9], 0, mixer3, 1);
    AudioConnection          patchCord11(Sound[10], 0, mixer3, 2);
    AudioConnection          patchCord12(Sound[11], 0, mixer3, 3);
    AudioConnection          patchCord13(mixer3, 0, mixer4, 0);
    AudioConnection          patchCord14(mixer2, 0, mixer4, 1);
    AudioConnection          patchCord15(mixer1, 0, mixer4, 2);
    AudioConnection          patchCord16(mixer4, 0, dacs1, 0);
    AudioConnection          patchCord17(mixer4, 0, dacs1, 1);
    int knockState [24] = { 0 ,   0 ,  0 , 0 , 0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 , 0 ,   0 ,  0 , 0 , 0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 };
    int sensorReading[24];
    unsigned long timing[24] = { 0 ,   0 ,  0 , 0 , 0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 , 0 ,  0 ,  0 , 0 , 0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 };
    int sensetivity = 500 ;
    int instrument = 1;
      //Set New Instrument
      pinMode(2, INPUT_PULLUP);
      pinMode(3, INPUT_PULLUP);
      pinMode(4, INPUT_PULLUP);
      pinMode(13, OUTPUT);
        while (1) {
          Alarm.delay(500);
      AudioMemory(25);
      for (int Vol = 0 ; Vol < 4; Vol++) {
        mixer1.gain(Vol, 0.1);
        mixer2.gain(Vol, 0.1);
        mixer3.gain(Vol, 0.1);
        mixer4.gain(Vol, 0.1);
      for (int i = 0; i <= 10; i++) {
        playMusic(i);
        Alarm.delay(500);
    //increase Volume
        mixer1.gain(Vol, 0.4);
        mixer2.gain(Vol, 0.4);
        mixer3.gain(Vol, 0.4);
        mixer4.gain(Vol, 0.4);
      Serial.println("Finish Set UP");
      Alarm.delay(1500);
    void playMusic(int note) {
      if (!boardActive) return;
      String directory = "drum";
      char HoldName[15];
      char fullName[15];
      Serial.println(instrument);
      switch (instrument) {
        case 1: directory = "piano";  break;
        case 2: directory = "drum";  break;
        case 3: directory = "droid";  break;
        default: directory = "piano";  break;
      char filename[15] = "piano/1.wav";
      int currentNote = note + 1;
      sprintf(filename, "/%i.wav", currentNote);
      directory.toCharArray(HoldName, 15);
      sprintf(fullName, "%s%s", HoldName, filename);
      Serial.println(fullName);
      Serial.println(note);
      AudioNoInterrupts();
      if (note <= 11)
        Sound[note].play(fullName);
        Sound[note - 12].play(fullName);
      Serial.print("Audio Memory : ");
      Serial.println(AudioMemoryUsageMax());
      AudioInterrupts();
      Alarm.delay(1);
      int dr2 = 0;
      int dr3 = 0;
      int dr4 = 0;
      for (int count = 0; count <= sensoreCount - 1 ; count++) {
        sensorReading[count] = analogRead(knockSensors[count]);
        if ((sensorReading[count] > sensetivity) && (knockState[count] == 0) && (currentTiming - timing[count] >= soundInterval)) {
          timing[count] = currentTiming;
          knockState[count] = 1;
          playMusic(count);
          delay(300);
        else {
          if (sensorReading[count] < sensetivity) knockState[count] = 0;
          if (currentTiming < timing[count]) timing[count] = 0;
      dr2 = digitalRead(2);
      dr3 = digitalRead(3);
      dr4 = digitalRead(4);
      if (dr2 == LOW) instrument = 1;
      else if (dr3 == LOW) instrument = 2;
      else if (dr4 == LOW) instrument = 3;
    2,633
    if you need stereo output through DAC0 and DAC1, i don't think you can do analogRead() on A22 or A21. It might work with mono output (DAC0) and using A22 rather than A21 for analogRead(). For mono change AudioOutputAnalogStereo dacs1; to AudioOutputAnalog dacs1;
    Using the WaveFilePlayer example on DAC0 I was able to analogRead(A22).
    you also have A25 and A26 on the backside
    Mar 2018
    8
    I Don't need streo, just need to play sound thru A22 and Read analog A21 !!
    14,466
    ... It might work with mono output (DAC0) and using A22 rather than A21 for analogRead(). For mono change AudioOutputAnalogStereo dacs1; to AudioOutputAnalog dacs1;
    Quote Originally Posted by ovedmo View Post
    This looks to provide a possible answer to the question - and an alternative?
    Mar 2018
    8
    i cant change the input output now, can you upload the code you used?
    I think it read wrong data like it have "noise" not the analog data i send.
    When i try to read analog(set any signal on the A21) when sound play and it stop playing(vol 0).
    2,633
    You'll have to modify the Audio library to use DAC1 for AudioOutputAnalog in place of DAC0 in
    hardware/teensy/avr/libraries/Audio/output_dac.cpp
    Good Luck
Tags for this Thread
