Results 1 to 3 of 3
Thread: Embed Xcode Teensy3.1 usbMIDI
    Member Van's Avatar
    Mar 2018
    Dresden, Germany
    35
    I'm trying to switch over and use Xcode for my projects. everything compiles fine except usbMIDI. (usbMIDI not found..)
    Any clue on how to set it up?
    greets, van
    22,488
    I can't speak to Xcode details, but I can tell you the code depends on the gcc compiler being run with "-DUSB_MIDI". The default is "-DUSB_SERIAL", so if you can find a setting with Xcode for "-DUSB_SERIAL", change it to "-DUSB_MIDI". Or you could change it to "-DUSB_MIDI_SERIAL" to get both MIDI and USB Serial, which can be really helpful for troubleshooting if Xcode doesn't have a way to receive Serial.print() in just MIDI mode (as Arduino+Teensyduino can).
    Member Van's Avatar
    Mar 2018
    Dresden, Germany
    35
    thank you very much!
    it is in the Teensy.mk file.
    changed the line:
    USB_FLAGS += -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=$(shell date +%s)
    to:
    USB_FLAGS += -DUSB_MIDI_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=$(shell date +%s)
    and it works!
    cheers, van
