Hey there,
I've run into a little problem, I can't compile code that has worked before and still compiles on a customers Mac. I'm running Arduino 1.8.2 on my mac, to work with a Teensy++ 2.0 that is connected to a MAX3421E and needs the USB host shield to work. It seems to have no idea what the pins 'Pb0' to 'Pb3' are, too.
If anyone has any ideas, please tell, I'm not sure what went wrong here.
// http://www.angelaitp.com/2017/01/30/creating-a-game-controller/
2016-03-21
2016-10-08 UPDATES
2018-02-02 starting on the EEPROM stuff again
EEEPROM thoughts
- 100.000 write cycles
- maybe external eeprom better suited (More than 1 Million Erase/Write Cycles)
- 1k EEPROM ATMEGA32U4 (leonardo)
- 4k EEPROM AT90USB1286 (teensie 2++)
- max 408 customers / rides per day
- with 10 reads of 16bytes
https://github.com/felis/USB_Host_Shield_2.0/issues/286
- had to remove RFID stuff for now, due to conflicting SPI stuff
#ifdef dobogusinclude
#include <spi4teensy3.h>
#include <Time.h>
#include <TimeLib.h>
#include <hidboot.h>
#include <usbhub.h>
#include <EtherCard.h> // ENC28J60
#define OPTO_GATE 10 //
#define OPTO_BTN 11 //
#define RFID_SS 45 //
#define RFID_RST 44 //
#define ENC_SS 40 // A1 on older models? now A2
#define USB_YES 38 // A0
#define BEEPER 43 // A0
#define BUILTIN_LED 6 // A0
#define USB_RST 25 // A0
#define USB_INT 24 // A0
#define RELAY_RED 14 //
#define RELAY_YELLOW 15 //
#define RELAY_GREEN 16 //
#define RELAY 17 //
#define IDLE_MAIN 0
#define REQUEST_CLIENT 1
#define REQUEST_RFID 2
#define WAIT_CLIENT 3
#define WAIT_RFID 4
#define FREE_ETHER 5
#define FREE_ETHER_FOR_RFID 6
#define IDLE_FOR_RFID 7
#define INIT 8
#define WAIT_TIME 9
#define USB_ONLY 10
#define TIMEOUT_MS 10000 // queries
#define GATE_TIMEOUT_MS 3500 // gate
byte Ethernet::buffer[800];
// static byte session;
const char website[] PROGMEM = "api.xserver.com";
uint32_t id;
char idToText[16];
// test-wasserski-wedau test
static byte mymac[] = { 0x74, 0x68, 0x68, 0x2D, 0x30, 0x2F };
const char link[24] = "bridge.php?cid=TEST0001";
const char link_id[5] = "&id=";
const char url_in0[6] = "&in=0";
const char url_in1[6] = "&in=1";
const char url_fR[5] = "&fR=";
const char url_rT[5] = "&rT=";
char json_response[16] = "";
char url[72];
int retry_cnt=0;
int8_t state;
int8_t statePrev = -1;
static uint32_t timer;
static uint32_t gate_timer;
static uint32_t rfid_timer;
static uint32_t timer_gate_btn;
static uint32_t usb_keyboard_timeout;
static uint32_t response_timer;
static uint32_t last_response_time;
boolean button_pressed = false;
int usbVCC;
int usbCap = 450;
uint32_t dataSize = 8;
USB Usb;
HIDBoot<HID_PROTOCOL_KEYBOARD> HidKeyboard(&Usb);
uint32_t next_time;
class KbdRptParser : public KeyboardReportParser
void OnKeyDown (uint8_t mod, uint8_t key);
void KbdRptParser::OnKeyDown(uint8_t mod, uint8_t key)
uint8_t c = OemToAscii(mod, key);
uint8_t l = strlen(idToText);
if ((c == 10 || c == 13 || c == 19) && l > 5)
id = atoi(idToText);
retry_cnt=0;
state = REQUEST_CLIENT;
else if (c == '%' || c =='#')
usb_keyboard_timeout = millis();
state = USB_ONLY;
strcpy(idToText, "");
idToText[l++] = c;
idToText[l] = '\0';
KbdRptParser Prs;
void setup ()
pinMode(RELAY, OUTPUT);
pinMode(RELAY_RED, OUTPUT);
pinMode(RELAY_YELLOW, OUTPUT);
pinMode(RELAY_GREEN, OUTPUT);
pinMode(OPTO_GATE, INPUT);
pinMode(OPTO_BTN, INPUT);
pinMode(BUILTIN_LED, OUTPUT);
digitalWrite(BUILTIN_LED, HIGH);
pinMode(USB_RST, OUTPUT);
digitalWrite(USB_RST, LOW);
SPI.begin();
Serial1.begin(9600); // Hardware Serial SparkFun Pro Micro or serial barcode reader
usbVCC = analogRead(USB_YES);
if (usbVCC > usbCap)
Serial.println("USB connected");
Serial.println(link);
init_enc();
state = INIT;
Serial.println("Starting USB controller");
digitalWrite(USB_RST, HIGH);
if (Usb.Init() == -1)
Serial.println("OSC did not start.");
delay( 200 );
next_time = millis() + 5000;
HidKeyboard.SetReportParser(0, (HIDReportParser*)&Prs);
if (statePrev != state)
printlnSerial(state);
statePrev = state;
switch (state)
case USB_ONLY: // 10
// timer fuer check wenn keine Abbruchbedingung auftrat
if (millis() - usb_keyboard_timeout > 2000)
state = IDLE_MAIN;
Usb.Task(); // check for usb stuff happening
case INIT:
delay(200);
ether.browseUrl(PSTR("/"), "time.php", website, cb_time);
state = WAIT_TIME; // Go to state to wait for response from browseURL
timer = millis() + TIMEOUT_MS;
case IDLE_MAIN:
// just in case anything happens or the arp has to go somewhere - maybe this get's lost
ether.packetLoop(ether.packetReceive());
if (Serial1.available())
Serial1.readBytesUntil('\n', idToText, 15);
if (l > 5)
retry_cnt=0;
if (
!digitalRead(OPTO_BTN) &&
!button_pressed
Serial.println("Button pressed");
digitalWrite(RELAY, HIGH); // OPEN
delay(1);
digitalWrite(RELAY_RED, HIGH); // through
delay(1);
digitalWrite(RELAY_YELLOW, HIGH); // through
delay(1);
digitalWrite(RELAY_GREEN, HIGH); // through
delay(1);
timer_gate_btn = millis() + GATE_TIMEOUT_MS;
button_pressed = true;
if (
(millis() > timer_gate_btn) &&
button_pressed)
Serial.println("Button released");
digitalWrite(RELAY, LOW); // timeout
delay(1);
digitalWrite(RELAY_RED, LOW); // through
delay(1);
digitalWrite(RELAY_YELLOW, LOW); // through
delay(1);
digitalWrite(RELAY_GREEN, LOW); // through
delay(1);
case IDLE_FOR_RFID: //7 - basically second IDLE
if (!digitalRead(OPTO_GATE))
printlnSerial("OPN");
digitalWrite(RELAY, LOW); // through
delay(1);
delay(1);
delay(1);
delay(1);
state = REQUEST_RFID;
if (millis() > gate_timer)
printlnSerial("CLS");
delay(1);
delay(1);
delay(1);
delay(1);
state = FREE_ETHER;
case REQUEST_CLIENT: //1
//while ( ether.packetLoop(ether.packetReceive()));
// ether.packetLoop(ether.packetReceive());
int fR = freeRam();
char fRbuf[6];
sprintf(fRbuf, "%i", fR);
char rtbuf[11];
sprintf(rtbuf, "%lu", last_response_time);
// reset url char array
strcpy(url, "");
strcat(url, link);
strcat(url, url_in0);
// free Ram size
strcat(url, url_fR);
strcat(url, fRbuf);
// last ressponse Time
strcat(url, url_rT);
strcat(url, rtbuf);
strcat(url, link_id);
strcat(url, idToText);
Keyboard.print('%');
Keyboard.print(idToText);
Keyboard.println();
response_timer = millis();
printlnSerial(url);
ether.browseUrl(PSTR("/"), url, website, cb_client);
state = WAIT_CLIENT; // Go to state to wait for response from browseURL
timer = millis() + TIMEOUT_MS; // 5 second timeout
case REQUEST_RFID: // 2
int fR = freeRam();
char fRbuf[6];
char rtbuf[11];
strcpy(url, "");
strcat(url, link);
strcat(url, url_in1);
// free Ram size
strcat(url, fRbuf);
strcat(url, rtbuf);
printlnSerial(url);
ether.browseUrl(PSTR("/"), url, website, cb_gate);
state = WAIT_RFID;
rfid_timer = millis() + TIMEOUT_MS;// 5 second timeout
// wait for response of gate gone through
case WAIT_RFID: // 4
if (millis() > rfid_timer)
// timeout waiting for response
printlnSerial("?ID");
if (retry_cnt<5)
Serial.print("retry: ");
Serial.println(retry_cnt);
retry_cnt++;
state = FREE_ETHER;
// waiting for response from previois calback
// wait for response of customer check
case WAIT_CLIENT: //3
if (millis() > timer)
state = FREE_ETHER;
printlnSerial("?CUS");
case WAIT_TIME: // 9
state = FREE_ETHER;
printlnSerial("?TIME");
// Flush the content or at least wait for the response and just wait and reset
case FREE_ETHER:
// while ( ether.packetLoop(ether.packetReceive()));
state = IDLE_MAIN;
case FREE_ETHER_FOR_RFID:
state = IDLE_FOR_RFID;
default:
// time call back
static void cb_time (byte status, word off, word len)
printlnSerial("CBTIME");
Ethernet::buffer[off + 800] = 0;
char* response = (char*) Ethernet::buffer + off;
getResponseWithoutHeader(response, json_response);
if (strtol(json_response, NULL, 0) > 0)
setTime(strtol(json_response, NULL, 0));
digitalClockDisplay();
state = FREE_ETHER;
// called when the client request is complete
static void cb_gate (byte status, word off, word len)
last_response_time = millis() - response_timer;
printlnSerial("CBG");
if (strncmp(json_response, "OK", 2) == 0)
state = FREE_ETHER;
static void cb_client (byte status, word off, word len)
printlnSerial("JSR");
if (strncmp(json_response, "no school", 9) == 0)
printlnSerial("!SCL");
state = FREE_ETHER;
else if (strncmp(json_response, "user_not_found", 14) == 0)
state = FREE_ETHER;
else if (strncmp(json_response, "user_no_ride", 12) == 0)
// red
state = FREE_ETHER;
printlnSerial("NOP");
else if (strtol(json_response, NULL, 0) > 0)
uint32_t timeForId = strtol(json_response, NULL, 0) + now();
// green
printlnSerial("THR");
delay(1);
delay(1);
delay(1);
delay(1);
gate_timer = millis() + GATE_TIMEOUT_MS;
state = FREE_ETHER_FOR_RFID;
else if (strtol(json_response, NULL, 0) < 0)
// red
state = FREE_ETHER;
printlnSerial("EXP");
printlnSerial(json_response);
int freeRam ()
extern int __heap_start, *__brkval;
int v;
return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
void init_enc ()
Serial.println("init ethernet");
if (ether.begin(sizeof Ethernet::buffer, mymac, ENC_SS) == 0)
printlnSerial("!ENC");
init_enc();
return;
if (!ether.dhcpSetup())
printlnSerial("!DHC");
init_enc();
return;
ether.printIp("IP: ", ether.myip);
ether.printIp("GW: ", ether.gwip);
ether.printIp("DNS: ", ether.dnsip);
if (!ether.dnsLookup(website))
printlnSerial("!DNS");
init_enc();
return;
ether.printIp("SRV: ", ether.hisip);
void getResponseWithoutHeader(char* response, char* new_response)
strcpy(new_response, "");
char * pch;
pch = strstr (response, "\r\n\r\n");
int length = 15;
if (strlen(pch + 4) < 15)
length = strlen(pch + 4);
printlnSerial(pch + 4);
strncpy (new_response, pch + 4, length);
// strcat(new_response, '\0');
void printlnSerial(char const a[])
Serial.println(a);
void printlnSerial(char *a)
Serial.println(a);
void printlnSerial(int a)
Serial.println(a);
void digitalClockDisplay() {
// digital clock display of the time
Serial.println(millis());
Serial.print(year());
Serial.print("-");
printDigits(month());
Serial.print("-");
printDigits(day());
Serial.print(" ");
printDigits(hour());
Serial.print(":");
printDigits(minute());
Serial.print(":");
printDigits(second());
void printDigits(int digits) {
if (digits < 10) Serial.print('0');
Serial.print(digits);
Warning: Board tiny:avr:nyan doesn't define a 'build.board' preference. Auto-set to: AVR_NYAN
In file included from /var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/Usb.h:36:0,
from /var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/hid.h:20,
from /var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/hidboot.h:20,
from /somewhere/something.ino:39:
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h:89:14: error: 'Pb1' was not declared in this scope
typedef SPi< Pb1, Pb2, Pb3, Pb0 > spi;
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h:89:19: error: 'Pb2' was not declared in this scope
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h:89:24: error: 'Pb3' was not declared in this scope
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h:89:29: error: 'Pb0' was not declared in this scope
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h:89:33: error: template argument 1 is invalid
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h:89:33: error: template argument 2 is invalid
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h:89:33: error: template argument 3 is invalid
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h:89:33: error: template argument 4 is invalid
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h:89:38: error: invalid type in declaration before ';' token
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h: In member function 'int8_t MAX3421e<SPI_SS, INTR>::Init()':
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h:394:18: error: qualified-id in declaration before '(' token
spi::init();
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h: In member function 'int8_t MAX3421e<SPI_SS, INTR>::Init(int)':
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/usbhost.h:431:18: error: qualified-id in declaration before '(' token
spi::init();
In file included from /var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/Usb.h:37:0,
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/UsbCore.h: At global scope:
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/UsbCore.h:36:18: error: 'P20' was not declared in this scope
typedef MAX3421e<P20, P24> MAX3421E; // Teensy++ 1.0 and 2.0
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/UsbCore.h:36:23: error: 'P24' was not declared in this scope
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/UsbCore.h:36:26: error: template argument 1 is invalid
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/UsbCore.h:36:26: error: template argument 2 is invalid
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/UsbCore.h:36:36: error: invalid type in declaration before ';' token
from /somewhere/somewhere.ino:39:
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/UsbCore.h:201:29: error: expected class-name before '{' token
class USB : public MAX3421E {
WS17_DREHKREUZ: In function 'void setup()':
WS17_DREHKREUZ:217: error: 'class USB' has no member named 'Init'
WS17_DREHKREUZ: In function 'void cb_client(byte, word, word)':
WS17_DREHKREUZ:581: warning: unused variable 'timeForId'
In file included from /somewhere/something.ino:39:0:
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/hidboot.h: In instantiation of 'uint8_t HIDBoot<BOOT_PROTOCOL>::Init(uint8_t, uint8_t, bool) [with unsigned char BOOT_PROTOCOL = 1u; uint8_t = unsigned char]':
/somewhere/something.ino:712:1: required from here
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/hidboot.h:348:30: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
epInfo[0].maxPktSize = (uint8_t)((USB_DEVICE_DESCRIPTOR*)buf)->bMaxPacketSize0;
/var/folders/rk/5m9lbt8n3l9841wwpztr4kf40000gn/T/arduino_build_601125/sketch/usb_host/hidboot.h:379:21: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
num_of_conf = ((USB_DEVICE_DESCRIPTOR*)buf)->bNumConfigurations;
Multiple libraries were found for "TimeLib.h"
Used: /somewhere/Sketchbook/libraries/Time
Not used: /Applications/Arduino copy.app/Contents/Java/hardware/teensy/avr/libraries/Time
