Good evening forum!
I am trying to send data from a Teensy 3.2 to a Teensy 3.5 through Serial communication.
I am sending a 34 bytes package on Serial1 (to Serial1).
The code for the T3.2 and the T3.5 are implemented inside an IntervalTimer.
In particular if I am using a baudrate of 115200 for the communication and 1000 ms as the interval time, the communication blocks.
Also with 2000ms it does not work properly. (It works properly with 333 Hz - 3000ms, but I need at least 500 Hz for my project).
I have tried to increase the baud rate to 230400 but, after some seconds, the communication is blocked again with both 2000 and 1000ms of interval timer.
I just would like to understand what is the maximum baud rate for a Teensy to Teensy communication and what are the best configurations (baudrate and time interval) to make the communication works at at least 500Hz with a package of 30 bytes.
Thank you very much for any suggestion!
