I get the following error when compiling the file pins_teensy.c:
This error relates to the last five lines of the following code snipped:
The compilation command was:
Any idea?
Uwe
pins_teensy.c:163:56: error: expected identifier before numeric constant
voidFuncPtr isr_table_portA[CORE_MAX_PIN_PORTA+1] = { [0 ... CORE_MAX_PIN_PORTA] = dummy_isr };
pins_teensy.c: In lambda function:
pins_teensy.c:163:82: error: expected '{' before '=' token
static void dummy_isr() {};
typedef void (*voidFuncPtr)(void);
#if defined(KINETISK)
#ifdef NO_PORT_ISR_FASTRUN
static void port_A_isr(void);
static void port_B_isr(void);
static void port_C_isr(void);
static void port_D_isr(void);
static void port_E_isr(void);
#else
static void port_A_isr(void) __attribute__ ((section(".fastrun"), noinline, noclone ));
static void port_B_isr(void) __attribute__ ((section(".fastrun"), noinline, noclone ));
static void port_C_isr(void) __attribute__ ((section(".fastrun"), noinline, noclone ));
static void port_D_isr(void) __attribute__ ((section(".fastrun"), noinline, noclone ));
static void port_E_isr(void) __attribute__ ((section(".fastrun"), noinline, noclone ));
voidFuncPtr isr_table_portB[CORE_MAX_PIN_PORTB+1] = { [0 ... CORE_MAX_PIN_PORTB] = dummy_isr };
voidFuncPtr isr_table_portC[CORE_MAX_PIN_PORTC+1] = { [0 ... CORE_MAX_PIN_PORTC] = dummy_isr };
voidFuncPtr isr_table_portD[CORE_MAX_PIN_PORTD+1] = { [0 ... CORE_MAX_PIN_PORTD] = dummy_isr };
voidFuncPtr isr_table_portE[CORE_MAX_PIN_PORTE+1] = { [0 ... CORE_MAX_PIN_PORTE] = dummy_isr };
arm-none-eabi-g++ -mcpu=cortex-m4 -std=c++14 -x c++ -mthumb -O0 -I/home/ufechner/teensy/include -I/home/ufechner/teensy_io/include -c -o pins_teensy.o pins_teensy.c
Any idea?
Uwe
