Results 1 to 5 of 5
Thread: When playing multiple wav files it have distortion when overlapping files! teensy 3.6
    Mar 2018
    8
    I have teensy 3.6.
    When i play file and start new one when the first still playing it have distortion at the beginning , what do i have to check to solve this issue?
    thank you.
    #include <Time.h>
    #include <TimeLib.h>
    #include <TimeAlarms.h>
    int sensoreCount = 24;
    int boardActive = 1;//Will toggle Board Activation
    #define SDCARD_CS_PIN    BUILTIN_SDCARD
    const int knockSensors [24] = {A0, A1, A2, A3, A4, A5, A10, A11, A8, A9, A6, A7, A12, A13, A14, A15, A16, A17, A18, A19, A20, A21, A23, A24};
    const long soundInterval = 300;
    unsigned long currentTiming = millis();
    AudioPlaySdWav     Sound[12];
    AudioMixer4              mixer3;
    AudioMixer4              mixer2;
    AudioMixer4              mixer1;
    AudioMixer4              mixer4;
    AudioOutputAnalogStereo  dacs1;
    AudioConnection          patchCord1(Sound[0], 0, mixer1, 0);
    AudioConnection          patchCord2(Sound[1], 0, mixer1, 1);
    AudioConnection          patchCord3(Sound[2], 0, mixer1, 2);
    AudioConnection          patchCord5(Sound[3], 0, mixer1, 3);
    AudioConnection          patchCord4(Sound[4], 0, mixer2, 0);
    AudioConnection          patchCord6(Sound[5], 0, mixer2, 1);
    AudioConnection          patchCord7(Sound[6], 0, mixer2, 2);
    AudioConnection          patchCord8(Sound[7], 0, mixer2, 3);
    AudioConnection          patchCord9(Sound[8], 0, mixer3, 0);
    AudioConnection          patchCord10(Sound[9], 0, mixer3, 1);
    AudioConnection          patchCord11(Sound[10], 0, mixer3, 2);
    AudioConnection          patchCord12(Sound[11], 0, mixer3, 3);
    AudioConnection          patchCord13(mixer3, 0, mixer4, 0);
    AudioConnection          patchCord14(mixer2, 0, mixer4, 1);
    AudioConnection          patchCord15(mixer1, 0, mixer4, 2);
    AudioConnection          patchCord16(mixer4, 0, dacs1, 0);
    AudioConnection          patchCord17(mixer4, 0, dacs1, 1);
    int knockState [24] = { 0 ,   0 ,  0 , 0 , 0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 , 0 ,   0 ,  0 , 0 , 0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 };
    int sensorReading[24];
    unsigned long timing[24] = { 0 ,   0 ,  0 , 0 , 0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 , 0 ,  0 ,  0 , 0 , 0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 ,  0 };
    int sensetivity = 500 ;
    int instrument = 1;
      //Set New Instrument
      pinMode(2, INPUT_PULLUP);
      pinMode(3, INPUT_PULLUP);
      pinMode(4, INPUT_PULLUP);
      pinMode(13, OUTPUT);
        while (1) {
          Alarm.delay(500);
      AudioMemory(25);
      for (int Vol = 0 ; Vol < 4; Vol++) {
        mixer1.gain(Vol, 0.1);
        mixer2.gain(Vol, 0.1);
        mixer3.gain(Vol, 0.1);
        mixer4.gain(Vol, 0.1);
      for (int i = 0; i <= 10; i++) {
        playMusic(i);
        Alarm.delay(500);
    //increase Volume
        mixer1.gain(Vol, 0.4);
        mixer2.gain(Vol, 0.4);
        mixer3.gain(Vol, 0.4);
        mixer4.gain(Vol, 0.4);
      Serial.println("Finish Set UP");
      Alarm.delay(1500);
    void playMusic(int note) {
      if (!boardActive) return;
      String directory = "drum";
      char HoldName[15];
      char fullName[15];
      Serial.println(instrument);
      switch (instrument) {
        case 1: directory = "piano";  break;
        case 2: directory = "drum";  break;
        case 3: directory = "droid";  break;
        default: directory = "piano";  break;
      char filename[15] = "piano/1.wav";
      int currentNote = note + 1;
      sprintf(filename, "/%i.wav", currentNote);
      directory.toCharArray(HoldName, 15);
      sprintf(fullName, "%s%s", HoldName, filename);
      Serial.println(fullName);
      Serial.println(note);
      AudioNoInterrupts();
      if (note <= 11)
        Sound[note].play(fullName);
        Sound[note - 12].play(fullName);
      Serial.print("Audio Memory : ");
      Serial.println(AudioMemoryUsageMax());
      AudioInterrupts();
      Alarm.delay(1);
      int dr2 = 0;
      int dr3 = 0;
      int dr4 = 0;
      for (int count = 0; count <= sensoreCount - 1 ; count++) {
        sensorReading[count] = analogRead(knockSensors[count]);
        if ((sensorReading[count] > sensetivity) && (knockState[count] == 0) && (currentTiming - timing[count] >= soundInterval)) {
          timing[count] = currentTiming;
          knockState[count] = 1;
          playMusic(count);
          delay(300);
        else {
          if (sensorReading[count] < sensetivity) knockState[count] = 0;
          if (currentTiming < timing[count]) timing[count] = 0;
      dr2 = digitalRead(2);
      dr3 = digitalRead(3);
      dr4 = digitalRead(4);
      if (dr2 == LOW) instrument = 1;
      else if (dr3 == LOW) instrument = 2;
      else if (dr4 == LOW) instrument = 3;
    Mar 2018
    8
    Any suggestions?
    1,876
    I think the sum of the gains should be no more than 1.
    From the notes on the mixer in the audio designer:
    Signal clipping can occur when any channel has gain greater than 1.0, or when multiple signals add together to greater than 1.0.
    Try reducing all the 0.4 to 0.2 or, at most 0.25.
    Pete
    Mar 2018
    8
    Will give it a try ():
    thank you
    26,561
    Looks like you have 12 possible sound sources. If their combined levels are more than 1.0 amplitude, you get clipping.
    For more info about clipping, check out part 2-2 in the tutorial, starting on page 12 of the PDF:
    https://www.pjrc.com/store/audio_tutorial_kit.html
    Or if you'd prefer to watch, it starts at 9:06 in the tutorial walkthrough video.
Tags for this Thread
