Ronnodoggo
New member
I have just inherited responsibility for a production test solution that uses a Teensy 3.0 to provide an interface to the unit under test. The previous developer did not use source control for the Teensy source code and left what I assume is the .ino file used to program the Teensy in the test solution on a network drive. I have now been tasked with getting the Teensy source code into a configuration control tool and need to verify that the .ino file I have found is the one used to program the Teensy. One possible way to do this would be to read the contents of the Flash from the Teensy and compare it with the hex file generated during programming (following some file conversion using LabVIEW), however I am struggling to find a way to read the contents of the Flash without modifying the Teensy to allow access to the JTAG / EZPORT on the uP. I really do not want to start cutting tracks / lifting pins and soldering onto the only working module that I have! Is there any way of doing this via the USB port?
