Compiler Error Arduino IDE Teensy 3.5 WIN7
kg4rul
While compiling a block of code which complies correctly for an UNO or ProMicro for the Teensy 3.5, I get the following error (highlighted at the end):
Arduino: 1.8.5 (Windows 7), TD: 1.41, Board: "Teensy 3.5, Serial, 120 MHz, Faster, US English"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\DRZ\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\DRZ\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\DRZ\Documents\Arduino\libraries -fqbn=teensy:avr:teensy35:usb=serial,speed=120,opt=o2std,keys=en-us -ide-version=10805 -build-path C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789 -warnings=null -verbose C:\Users\DRZ\Documents\arduino\ZDuino\ZDuino.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\DRZ\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\DRZ\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\DRZ\Documents\Arduino\libraries -fqbn=teensy:avr:teensy35:usb=serial,speed=120,opt=o2std,keys=en-us -ide-version=10805 -build-path C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789 -warnings=null -verbose C:\Users\DRZ\Documents\arduino\ZDuino\ZDuino.ino
Using board 'teensy35' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\sketch\ZDuino.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\sketch\ZDuino.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\sketch\ZDuino.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\sketch\ZDuino.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\sketch\ZDuino.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\Wire.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\WireKinetis.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility\twi.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI\SPI.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\sketch\ZDuino.ino.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\sketch\ZDuino.ino.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\sketch\ZDuino.ino.cpp.o"
Compiling libraries...
Compiling library "ZDuinoGlobals"
Compiling library "Wire"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\Wire.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\libraries\Wire\Wire.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\WireKinetis.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\libraries\Wire\WireKinetis.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility\twi.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\libraries\Wire\utility\twi.c.o"
Compiling library "SPI"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI\SPI.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\libraries\SPI\SPI.cpp.o"
Compiling library "LiquidCrystal_I2C"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp.o"
Compiling core...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\memcpy-armv7m.S" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\memcpy-armv7m.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\memset.S" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\memset.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\analog.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\analog.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\eeprom.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\eeprom.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\keylayouts.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\keylayouts.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\math_helper.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\math_helper.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\mk20dx128.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\mk20dx128.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\nonstd.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\nonstd.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\pins_teensy.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\pins_teensy.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\ser_print.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\ser_print.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial1.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial1.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial2.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial2.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial3.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial3.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial4.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial4.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial5.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial5.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial6.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial6.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial6_lpuart.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial6_lpuart.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\touch.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\touch.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_desc.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_desc.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_dev.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_dev.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_joystick.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_joystick.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_keyboard.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_keyboard.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_mem.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_mem.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_midi.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_midi.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_mouse.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_mouse.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_mtp.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_mtp.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_rawhid.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_rawhid.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_seremu.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_seremu.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_serial.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_serial.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_touch.c" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_touch.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\AudioStream.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\AudioStream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\DMAChannel.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\DMAChannel.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\EventResponder.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\EventResponder.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial1.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\HardwareSerial1.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial2.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\HardwareSerial2.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial3.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\HardwareSerial3.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial4.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\HardwareSerial4.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial5.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\HardwareSerial5.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial6.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\HardwareSerial6.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\IPAddress.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\IPAddress.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\IntervalTimer.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\IntervalTimer.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\Print.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\Print.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\Stream.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\Stream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\Tone.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\Tone.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\WMath.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\WMath.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\WString.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\WString.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\avr_emulation.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\avr_emulation.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\main.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\main.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\new.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\new.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_audio.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_audio.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_flightsim.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_flightsim.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_inst.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\usb_inst.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\yield.cpp" -o "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\yield.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\memcpy-armv7m.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\memset.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\analog.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\eeprom.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\keylayouts.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\math_helper.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\mk20dx128.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\nonstd.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\pins_teensy.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\ser_print.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial1.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial2.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial3.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial4.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial5.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial6.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\serial6_lpuart.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a" "C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\touch.c.o"
[B][I]c:\program files (x86)\arduino\hardware\tools\arm\bin\../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ar.exe: unable to rename 'C:\Users\DRZ\AppData\Local\Temp\arduino_build_703789\core\core.a'; reason: File exists[/I][/B]
Using library ZDuinoGlobals in folder: C:\Users\DRZ\Documents\Arduino\libraries\ZDuinoGlobals (legacy)
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
Using library LiquidCrystal_I2C at version 1.1.2 in folder: C:\Users\DRZ\Documents\Arduino\libraries\LiquidCrystal_I2C
Error compiling for board Teensy 3.5.
What virus protection code are you using? McAfee? Try disable real time scanning and see if it builds
That got it - compiled and uploaded! Though these days it is scary turning off scanning for any reason! Thanks!
