Projectitis
Hi all,
I'm getting a very weird bug on T_3.6 trying to copy a byte from an array in PROGMEM to a struct in ram.
My program just simply stops executing at a certain point (at least, my Serial debug commands stop coming).
The code is relatively big, so I'll explain what I can below. You can grab the code from the repo here: https://github.com/projectitis/libxm_t3
Some background:
This macro reads one uint8_t from the module in flash (moddata is a const char* pointing to the module in flash mem), with overflow protection:
The other thing you need to know is that the 'sample' struct contains volume as a float.
Here is the code in question (load.c, line 393):
There are 7 samples in the module.
Changing the code to this has the exact same result (broken):
Changing the code to this (just for testing) works (but doesn't set the actual volume value):
Changing it to this breaks it again, even though I can verify that the value of temp_float is 1.0f;
It's important to highlight that when the code dies on sample 1 it has already run exactly the same code with exactly the same values on sample 0.
I thought maybe it had something to do with memory alignment, but we're only reading a single byte here, so that shouldn't be an issue?
In my case the actual memory addresses are as follows:
There are two places in the code where this program fails during execution, and both of them involve reading a byte, converting it to a float (with a division) and assigning it to a struct member.
Any help appreciated!
- Add libxm_t3 as a library
- Run the sketch in the examples folder
Some background:
#define READ_U8(offset) (((offset) < moddata_length) ? (*(uint8_t*)(moddata + (offset))) : 0)
float volume;
sample->volume = (float)READ_U8(offset + 12) / (float)0x40;
- For sample 0, the uint8_t is 64, the float is 1.0f, and the code works fine
- For sample 1, the unit8_t is 64, the float is 1.0f, and the code dies trying to assign the float to sample->volume;
temp_uint8 = READ_U8(offset + 12); // This works ok
temp_float = temp_uint8 / 64.0f; // This works ok
sample->volume = temp_float; // This is where it dies
sample->volume = 1.0f;
- For sample 0, the volume byte is at 56943 in flash mem. This is the one that works
- For sample 1, the volume byte is at 60180 in flash mem. This is the one that doesn't work
