Mr Underhill
New member
Hi all,
First post here, so apologies in advance for any mistakes in protocol!
I'm wondering if it's possible to connect the Teensy++ 2.0's USB directly to a PCB, rather than having to use a cable via the standard port?
As it stands I'll be running a cable inside a case from the Teensy's USB connector up to a USB connector on the surface of the case. It seems like it'd make more sense to access the USB via the pins, and then link to a surface mount female USB which I can put on the top of the PCB, with everything else that's up on the front plate.
Many thanks for any info!
James
James
