I have a simple two-line program
This compiles and works fine with a T3.2, but when I compile this same program for a T3.5 & upload, I get a 'Port failed to open' error. I have tried this trick with two different T3.5's with the same result.
I have verified that the Tools->Serial option is set for 'Serial', and I have tried using the reset button to make sure the 3.5 is in programming mode - no luck.
Am I missing something here?
TIA,
Frank
HTML:
Serial.println("Starting Teensy");
/* add setup code here */
TIA,
Frank
