Results 1 to 21 of 21
Thread: "Flight Sim Controls + Joystick" non-functional on Teensy 3.2 and 3.6
    Member pilotplater's Avatar
    Dec 2017
    Ontario, Canada
    33
    User PeeWeeSweden made a post back in September 2017 about this issue.
    Can confirm it's also the case on Teensy 3.6 - if you select "Flight Sim Controls + Joystick" the Teensy plugin won't recognize flight sim controls are connected whatsoever, but works fine on just "Flight Sim Controls"
    I know this feature is new to the Teensy 3 line, I was just really looking forward to simplifying/expanding my setup when I ran into this road block. Far as I know I'm on the 1.0 version of the (XPlane) plugin, is there a newer version? I think I'm on the latest teensyduino version too, as I just downloaded it recently.
    To Reproduce:
    Any sketch including "bare minimum" sample code
    Select "Flight Sim Controls" at upload and it shows as connecting and disconnecting in plugin on XPlane
    Select "Flight Sim Controls + Joystick" at upload and the joystick works flawlessly when implemented, but the XPlane plugin sees nothing.
    27,097
    Which version of Teensyduino are you using? Click Help > About in Arduino to check.
    A bug affecting flight sim with floats on Teensy 3.5 and 3.6 was recently fixed, so this could matter if you have less than 1.41...
    Dec 2017
    Ontario, Canada
    33
    Currently at 1.41 and Arduino 1.8.5
    Seems like that's the latest supported right?
    Thanks for the quick response!
    Dec 2017
    Ontario, Canada
    33
    I see there was something that changed in 1.42 beta 1 about FlightSimFloat - think I'll give the latest beta a try today to see what it does.
    Dec 2017
    Ontario, Canada
    33
    Bug still appears to be present in 1.42 beta 3. Flight Sim Controls works but not Flight Sim Controls + Joystick
    27,097
    Is the problem only with Teensy 3.6? Or are all 3.x boards affected?
    27,097
    Oh, I think I see what's happening here. The plugin wasn't ever updated to look for PID 0x04D9 (or 0x0476).
    Dec 2017
    Ontario, Canada
    33
    Just ran a test on my Teensy 3.2 and yes this problem is on 3.2, and also 3.6 as before. Don't have other 3.x gen boards to test.
    Tried it on our faster sim computer and it's actually surprisingly quick for xPlane to recognize the joystick, but Teensy plugin for xPlane doesn't see it when using "Flight Sim Controls + Joystick" mode. Also tried "All of the above" with the same result - joystick component detected, sim plugin can't find Teensy.
    the PIDs sound promising!
    Dec 2017
    Ontario, Canada
    33
    I'm happy to test a beta version of the plugin for you Paul if you don't have xPlane set up. I think we're on 10.31, but could update to 10.50 for testing too.
    27,097
    I changed the PID number in the latest beta. Maybe that will solve the problem?
    https://forum.pjrc.com/threads/52525...no-1-42-Beta-6
    Dec 2017
    Ontario, Canada
    33
    it works
    Dec 2017
    Ontario, Canada
    33
    Hey Paul,
    I've run into a very similar issue as I did in 2018, but the reverse problem to what I had then.
    If Keyboard+Mouse+Joystick is selected, the joystick seems to function fine:
    If Flight Sim Controls + Joystick is selected (the mode I'm running in), windows recognizes a joystick is connected, but it doesn't seem to be initialized/reporting any data:
    I believe my arduino install I've been using has been unchanged since 2018, arduino version 1.8.5 and the teensyduino beta that you published back then. I just made a new arduino install of 1.8.11, and the latest teensyduino 1.50 and it seems to do the same thing. Odd to me that this has changed when I'm pretty sure my arduino software didn't, wondering if I'm missing something.
    Observed on both Teensy 3.6 and 3.2
    Dec 2017
    Ontario, Canada
    33
    Quick update, can only seem to reproduce the problem on one windows 7 computer, am now suspecting a driver issue. Will attempt to reinstall the drivers
    Sep 2022
    Bellevue, NE
    2
    Well, it's over two years later. Has this problem been resolved? I'm still experiencing the issue of Flight Sim Controls + Joystick not working. I can't tell what version of the Teensy Plug-in I'm using.
    Apr 2020
    DFW area in Texas
    512
    Steve: If you click on "Help" then "About Arduino" from the Arduino IDE, the pop-up dialog will show both the Arduino version (latest = 1.8.19) & the Teensyduino version (latest release = 1.57, latest beta = 1.58-beta2).
    Hope that helps . . .
    Mark J Culross
    KD5RXT
    Dec 2017
    Ontario, Canada
    33
    Talking
    Quote Originally Posted by SteveLehr View Post
    Hey Steve, YES!
    Paul kindly fixed the problem for us, he posted a link to the latest beta which corrected some usb device ids. The issue I had since then was just a misconfigured arduino install I believe, was able to resolve it.
    Andy
    27,097
    If you have a really old version of the software, and you're running Microsoft Windows, here are direct links to download the installers to update.
    https://downloads.arduino.cc/arduino-1.8.19-windows.exe
    https://www.pjrc.com/teensy/td_157/T...inoInstall.exe
    Sep 2022
    Bellevue, NE
    2
    Thanks Mark, Andy, Paul. I updated to the latest Arduino and Teensyduino IDE, and now the Flightsim Controls + Joystick works as expected. Now I just have to figure out how to map a Joystick button to a GamePad button, but's that's a task for the Voicemeeter Forum.
    Thanks again!
    SwL
    Dec 2017
    Ontario, Canada
    33
    Thanks again!
    SwL
    Well done Steve,
    Pm me if you get stuck using the teensy joystick stuff I might be able to help.
    Oct 2018
    6
    Flight Sim Controls and Joystick Teensy LC
    I installed a fresh Arduino IDE from the ling above. Trying to install Teensyduino the installer cannot find the Arduino IDE.
    I also notice that older instalations do not have Flight Sim Controls and Joystick as an option for the Teensy LC, but do for other Teensies. Is this by design or my installations?
    Oct 2018
    6
    Argh, Just found the correct location and Teensyduino installed. Sorry my bad.
    However for the LC no Flight Sim Controls+Joystick. So is this by design or have I boobed again?Click image for larger version.
