PassThroughUSB with queues
kk12
For some reason, following code that was modified from PassThroughUSB -example, doesn't function while using queues. How to make it work? Left channel is flooded with unwanted noise, wheras right channel (without queues) is correct audio from PC.
#include <SerialFlash.h>
AudioInputUSB            usb1;           //xy=200,69  (must set Tools > USB Type to Audio)
AudioOutputI2S           i2s1;           //xy=365,94
AudioRecordQueue    queue1;
AudioPlayQueue      queue3;
AudioConnection     patchCord1(usb1, 0, queue1, 0);
AudioConnection     patchCord3(queue3, 0, i2s1, 0);
AudioConnection     patchCord2(usb1, 1, i2s1, 1);
AudioControlSGTL5000     sgtl5000_1;     //xy=302,184
short array1[AUDIO_BLOCK_SAMPLES];
  AudioMemory(80);
  sgtl5000_1.enable();
  sgtl5000_1.volume(0.6);
 // INPUT
  memcpy(&array1, queue1.readBuffer(), AUDIO_BLOCK_SAMPLES*2);
  queue1.freeBuffer();
  // OUTPUT
  memcpy(queue3.getBuffer(), &array1, AUDIO_BLOCK_SAMPLES*2);
  queue3.playBuffer();
Constant noise was kind of misleading. Its a constant frequency instead of widespectrum noise.
You need to test that there's a queue buffer available before copying data and sending it.
  if (queue1.available() >= 1) {
    memcpy(array1, queue1.readBuffer(), AUDIO_BLOCK_SAMPLES*2);
and do a similar thing with queue3 before calling getBuffer and copying array1 into it.
Pete
Thanks Pete!
So here goes a working example of USB-passthrough teensy->usb & usb->teensy. It uses queues and could be used as a soundcard for PC. Also bit manipulation is possible because of using queues. Just Teensy, audio shield and microphone needed.
AudioRecordQueue          rqueue1;
AudioPlayQueue            pqueue2;
AudioConnection          patchCord1(usb1, 0, rqueue1, 0);
AudioConnection          patchCord2(pqueue2, 0, i2s1, 0);
AudioInputI2S            i2s2;           //xy=105,63
AudioOutputUSB           usb2;
AudioRecordQueue         rqueue3;
AudioPlayQueue           pqueue4;
AudioConnection          patchCord3(i2s2, 0, rqueue3, 0);
AudioConnection          patchCord4(pqueue4, 0, usb2, 0);
const int myInput = AUDIO_INPUT_MIC;
int ret=0;
int i=0;
int j=0;
short array2[AUDIO_BLOCK_SAMPLES];
  AudioMemory(24);
  rqueue1.begin();
  rqueue3.begin();
  Serial.println("Begin");
  // read the PC's volume setting
  float vol = usb1.volume();
  // scale to a nice range (not too loud)
  // and adjust the audio shield output volume
  if (vol > 0) {
    // scale 0 = 1.0 range to:
    //  0.3 = almost silent
    //  0.8 = really loud
    vol = 0.3 + vol * 0.5;
  // use the scaled volume setting.  Delete this for fixed volume.
  sgtl5000_1.volume(vol);
  ret=rqueue1.available();
  //Serial.println(ret);
  if(ret>=1)
    memcpy(&array1[j*128], rqueue1.readBuffer(), 2*AUDIO_BLOCK_SAMPLES);
    rqueue1.freeBuffer();
    memcpy(pqueue2.getBuffer(), &array1[j*128], 2*AUDIO_BLOCK_SAMPLES);
    pqueue2.playBuffer();
  ret=rqueue3.available();
  if(ret>=1)
    memcpy(&array1[j*128], rqueue3.readBuffer(), 2*AUDIO_BLOCK_SAMPLES);
    rqueue3.freeBuffer();
    memcpy(pqueue4.getBuffer(), &array1[j*128], 2*AUDIO_BLOCK_SAMPLES);
    pqueue4.playBuffer();
  //delay(100);
