wiz52io SPI speed and buffer increase compile error
Zjcc56
New member
I know this has been covered before but after reading through this thread i cant really find a solution so here it goes:
I cant break the 4 universe limit on this without it getting really choppy led movement and when i view the serial monitor i can see that i am only receiving universe 0-4 and sometimes 5 6 or 7 if Im lucky but not enough to be useful. I know that increasing the spi speed and buffer can help but i just cant get my head around editing the 5100.h or 5100.cpp files. I've tried with no success to edit them. Ive tried using the ethernet 1-socket library and it wont compile.
From what ive read it seems like a simple edit of those two files but, Im having a hard time with it.
Thanks!
SETUP:
WIZ820io with adapter
OctoWS2811
osx 10.12.6
Arduino IDE 1.8.5
Teency 1.41
all libraries are from the teensy installer unless listed below:
artnet library from https://github.com/natcl/Artnet
ethernet library from: https://github.com/alex-Arc/Ethernet/tree/1-socket
this is supposed to increase the SPI clock to 30mhz and the buffer to 16k
if i replace this with the standard ethernet library all returns to normal (barely 4 universe)
QLC+ sending 8 Universes of DMX via artnet (120x8) Led matrix >Thunderbolt to ethernet adapter > tl-sg108 switch from tp link > WIZ820io
The Code
This is a basic example that will print out the header and the content of an ArtDmx packet.
This example uses the read() function and the different getter functions to read the data.
This example may be copied under the terms of the MIT license, see the LICENSE file for details
#include <Artnet.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
Artnet artnet;
// Change ip and mac address for your setup
byte ip[] = {169, 254, 2, 255};
byte mac[] = {0x04, 0xE9, 0xE5, 0x00, 0x69, 0xEC};
  artnet.begin(mac, ip);
  Serial.println(Ethernet.localIP());
  if (artnet.read() == ART_DMX)
    // print out our data
    Serial.print("universe number = ");
    Serial.print(artnet.getUniverse());
    Serial.print("\tdata length = ");
    Serial.print(artnet.getLength());
    Serial.print("\tsequence n0. = ");
    Serial.println(artnet.getSequence());
    Serial.print("DMX data: ");
    for (int i = 0 ; i < artnet.getLength() ; i++)
      Serial.print(artnet.getDmxFrame()[i]);
      Serial.print("  ");
The Error
Arduino: 1.8.5 (Mac OS X), TD: 1.41, Board: "Teensy 3.2 / 3.1, Serial, 120 MHz (overclock), Faster, US English"
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware -hardware /Users/coryscott/Library/Arduino15/packages -tools /Applications/Arduino Only Teency Vanilla.app/Contents/Java/tools-builder -tools /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/tools/avr -tools /Users/coryscott/Library/Arduino15/packages -libraries /Users/coryscott/Documents/Arduino/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=120,opt=o2std,keys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10805 -build-path /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363 -warnings=none -build-cache /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_cache_376486 -verbose /Users/coryscott/Documents/Arduino/artnettest/artnettest.ino/artnettest.ino.ino/artnettest.ino.ino.ino
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware -hardware /Users/coryscott/Library/Arduino15/packages -tools /Applications/Arduino Only Teency Vanilla.app/Contents/Java/tools-builder -tools /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/tools/avr -tools /Users/coryscott/Library/Arduino15/packages -libraries /Users/coryscott/Documents/Arduino/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=120,opt=o2std,keys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10805 -build-path /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363 -warnings=none -build-cache /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_cache_376486 -verbose /Users/coryscott/Documents/Arduino/artnettest/artnettest.ino/artnettest.ino.ino/artnettest.ino.ino.ino
Using board 'teensy31' from platform in folder: /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr
Using core 'teensy3' from platform in folder: /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr
Detecting libraries used...
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/sketch/artnettest.ino.ino.ino.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/sketch/artnettest.ino.ino.ino.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/sketch/artnettest.ino.ino.ino.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/sketch/artnettest.ino.ino.ino.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master/Artnet.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/Dhcp.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/Dns.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/Ethernet.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/EthernetClient.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/EthernetServer.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/EthernetUdp.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/socket.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/w5100.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI/SPI.cpp" -o "/dev/null"
Generating function prototypes...
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/sketch/artnettest.ino.ino.ino.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/sketch/artnettest.ino.ino.ino.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/sketch/artnettest.ino.ino.ino.cpp.o"
Compiling libraries...
Compiling library "Artnet-master"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master/Artnet.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/libraries/Artnet-master/Artnet.cpp.o"
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master/Artnet.cpp: In member function 'uint16_t Artnet::read()':
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master/Artnet.cpp:94:40: warning: embedded '\0' in format [-Wformat-contains-nul]
         sprintf((char *)id, "Art-Net\0");
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master/Artnet.cpp:107:54: warning: embedded '\0' in format [-Wformat-contains-nul]
         sprintf((char *)shortname, "artnet arduino\0");
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master/Artnet.cpp:108:64: warning: embedded '\0' in format [-Wformat-contains-nul]
         sprintf((char *)longname, "Art-Net -> Arduino Bridge\0");
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master/Artnet.cpp:143:109: warning: embedded '\0' in format [-Wformat-contains-nul]
         sprintf((char *)ArtPollReply.nodereport, "%i DMX output universes active.\0", ArtPollReply.numbports);
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master/Artnet.cpp:160:1: warning: control reaches end of non-void function [-Wreturn-type]
Compiling library "Ethernet-1-socket"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/Dhcp.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/libraries/Ethernet-1-socket/Dhcp.cpp.o"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/Dns.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/libraries/Ethernet-1-socket/Dns.cpp.o"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/Ethernet.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/libraries/Ethernet-1-socket/Ethernet.cpp.o"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/EthernetClient.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/libraries/Ethernet-1-socket/EthernetClient.cpp.o"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/EthernetServer.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/libraries/Ethernet-1-socket/EthernetServer.cpp.o"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/EthernetUdp.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/libraries/Ethernet-1-socket/EthernetUdp.cpp.o"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/socket.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/libraries/Ethernet-1-socket/socket.cpp.o"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/w5100.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_786363/libraries/Ethernet-1-socket/w5100.cpp.o"
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/w5100.cpp:88:6: warning: #warning "30MHz SPI clock" [-Wcpp]
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/w5100.cpp: In static member function 'static uint8_t W5100Class::init()':
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket/w5100.cpp:89:25: error: 'SPI_CLOCK_30MHz' was not declared in this scope
   SPIFIFO.begin(ss_pin, SPI_CLOCK_30MHz);  // W5100 is 14 MHz max
Using library Artnet-master in folder: /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Artnet-master (legacy)
Using library Ethernet-1-socket at version 1.1.1 in folder: /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/Ethernet-1-socket
Using library SPI at version 1.0 in folder: /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI
Error compiling for board Teensy 3.2 / 3.1.
Thanks for the response!
So i replaced the ethernet library with the one you provided and opened up the code you gave me too and when i try to verify it without the board it throws an error, but a different one from the other library.
The megapixel project is very interesting and probably will pick up some pcbs for it, its very elegant.
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware -hardware /Users/coryscott/Library/Arduino15/packages -tools /Applications/Arduino Only Teency Vanilla.app/Contents/Java/tools-builder -tools /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/tools/avr -tools /Users/coryscott/Library/Arduino15/packages -libraries /Users/coryscott/Documents/Arduino/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=120,opt=o2std,keys=en-us -ide-version=10805 -build-path /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199 -warnings=none -build-cache /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_cache_373093 -verbose /Users/coryscott/Downloads/MegaPixelController-master/MegaPixel_E1.31/MegaPixel_E1.31.ino
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware -hardware /Users/coryscott/Library/Arduino15/packages -tools /Applications/Arduino Only Teency Vanilla.app/Contents/Java/tools-builder -tools /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/tools/avr -tools /Users/coryscott/Library/Arduino15/packages -libraries /Users/coryscott/Documents/Arduino/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=120,opt=o2std,keys=en-us -ide-version=10805 -build-path /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199 -warnings=none -build-cache /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_cache_373093 -verbose /Users/coryscott/Downloads/MegaPixelController-master/MegaPixel_E1.31/MegaPixel_E1.31.ino
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/sketch/MegaPixel_E1.31.ino.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/sketch/MegaPixel_E1.31.ino.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/sketch/MegaPixel_E1.31.ino.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/sketch/MegaPixel_E1.31.ino.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/sketch/MegaPixel_E1.31.ino.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI/SPI.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Dhcp.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Dns.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Ethernet.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetClient.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetServer.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetUdp.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/socket.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/w5100.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811/OctoWS2811.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/FastLED.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/bitswap.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/colorpalettes.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/colorutils.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/hsv2rgb.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/lib8tion.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/noise.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/power_mgt.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/wiring.cpp" -o "/dev/null"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/sketch/MegaPixel_E1.31.ino.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/sketch/MegaPixel_E1.31.ino.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/sketch/MegaPixel_E1.31.ino.cpp.o"
In file included from /Users/coryscott/Downloads/MegaPixelController-master/MegaPixel_E1.31/MegaPixel_E1.31.ino:37:0:
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.008
 #    pragma message "FastLED version 3.001.008"
/Users/coryscott/Downloads/MegaPixelController-master/MegaPixel_E1.31/MegaPixel_E1.31.ino: In function 'void sacnDMXReceived(unsigned char*, int, int)':
/Users/coryscott/Downloads/MegaPixelController-master/MegaPixel_E1.31/MegaPixel_E1.31.ino:157:10: warning: unused variable 's' [-Wunused-variable]
     byte s = pbuff[111]; //sequence
Compiling library "SPI"
Using previously compiled file: /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/libraries/SPI/SPI.cpp.o
Compiling library "MegaPixel-One-Socket-Ethernet-master"
Using previously compiled file: /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/libraries/MegaPixel-One-Socket-Ethernet-master/Dhcp.cpp.o
Using previously compiled file: /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/libraries/MegaPixel-One-Socket-Ethernet-master/Dns.cpp.o
Using previously compiled file: /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/libraries/MegaPixel-One-Socket-Ethernet-master/Ethernet.cpp.o
Using previously compiled file: /var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetClient.cpp.o
"/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811" "-I/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED" "/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetServer.cpp" -o "/var/folders/b5/20lcrffd0tg129snynlw2lvw0000gn/T/arduino_build_46199/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetServer.cpp.o"
In file included from /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetServer.cpp:2:0:
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/w5100.h:21:0: warning: "SPI_ETHERNET_SETTINGS" redefined
 #define SPI_ETHERNET_SETTINGS SPISettings(30000000, MSBFIRST, SPI_MODE0)
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/w5100.h:17:0: note: this is the location of the previous definition
 #define SPI_ETHERNET_SETTINGS SPISettings(14000000, MSBFIRST, SPI_MODE0)
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/w5100.h:26:0: warning: "MAX_SOCK_NUM" redefined
 #define MAX_SOCK_NUM 1
In file included from /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetServer.cpp:1:0:
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Ethernet.h:6:0: note: this is the location of the previous definition
 #define MAX_SOCK_NUM 4
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetServer.cpp:4:50: error: conflicting declaration 'uint16_t EthernetServer::server_port [1]'
 uint16_t EthernetServer::server_port[MAX_SOCK_NUM];
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Ethernet.h:194:18: note: previous declaration as 'uint16_t EthernetServer::server_port [4]'
  static uint16_t server_port[MAX_SOCK_NUM];
/Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetServer.cpp:4:50: error: declaration of 'uint16_t EthernetServer::server_port [4]' outside of class is not definition [-fpermissive]
Using library MegaPixel-One-Socket-Ethernet-master at version 1.1.2 in folder: /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master
Using library OctoWS2811 at version 1.4 in folder: /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/OctoWS2811
Using library FastLED at version 3.1.8 in folder: /Applications/Arduino Only Teency Vanilla.app/Contents/Java/hardware/teensy/avr/libraries/FastLED
I know on the windows side of things you have multiple ethernet libraries. perhaps the wrong one is replaced? In order for it work I had to go under the arduino/hardware/teensy/avr/libraries and remove the ethernet in that directory and replace it with the one socket version.
ok, well i got rid of all the libraries in the arduino/hardware/teensy/avr/libraries except for the SPI and the Ethernet library you provided.
its the simplest code possible just including the ethernet library and nothing else and i still get the same error
i just want to point out the path to verify it
Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/
also when i download the last stable release (2015) from the github you gave me the link to it works but i assume its without the speed increase or socket changes
Arduino: 1.8.5 (Mac OS X), TD: 1.42-beta3, Board: "Teensy 3.2 / 3.1, Serial, 120 MHz (overclock), Faster, US English"
In file included from /Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Dhcp.cpp:6:0:
/Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/w5100.h:21:0: warning: "SPI_ETHERNET_SETTINGS" redefined
/Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/w5100.h:17:0: note: this is the location of the previous definition
/Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/w5100.h:26:0: warning: "MAX_SOCK_NUM" redefined
In file included from /Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Dhcp.cpp:4:0:
/Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Ethernet.h:6:0: note: this is the location of the previous definition
In file included from /Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Dns.cpp:7:0:
In file included from /Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Dns.cpp:5:0:
In file included from /Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Ethernet.cpp:2:0:
In file included from /Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Ethernet.cpp:1:0:
In file included from /Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetClient.cpp:3:0:
In file included from /Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetClient.cpp:1:0:
In file included from /Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetServer.cpp:2:0:
In file included from /Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetServer.cpp:1:0:
/Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetServer.cpp:4:50: error: conflicting declaration 'uint16_t EthernetServer::server_port [1]'
/Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/Ethernet.h:194:18: note: previous declaration as 'uint16_t EthernetServer::server_port [4]'
/Users/coryscott/Desktop/Arduino 1.8.5.app/Contents/Java/hardware/teensy/avr/libraries/MegaPixel-One-Socket-Ethernet-master/EthernetServer.cpp:4:50: error: declaration of 'uint16_t EthernetServer::server_port [4]' outside of class is not definition [-fpermissive]
#include <Ethernet.h>
