Hello guys, after almost a year I'm still here..
Now I'm trying this lib: https://github.com/maxgerhardt/rotar...-over-mcp23017
I've the polling example running fine with 1 encoder.
How to handle buttons ?
For 16 encoders, I'would use 3 mcp: 2 for encoders and 1 for buttons but how ??
The third mcp should be handled in different/separate way..
Any hints ?
Here the code:
#include <Arduino.h>
#include <Adafruit_MCP23017.h>
#include <Rotary.h>
#include "RotaryEncOverMCP.h"
// https://github.com/maxgerhardt/rotary-encoder-over-mcp23017
/* Our I2C MCP23017 GPIO expanders */
Adafruit_MCP23017 mcp;
//Array of pointers of all MCPs if there is more than one
Adafruit_MCP23017* allMCPs[] = { &mcp };
constexpr int numMCPs = (int)(sizeof(allMCPs) / sizeof(*allMCPs));
/* function prototypes */
void RotaryEncoderChanged(bool clockwise, int id);
/* Array of all rotary encoders and their pins */
RotaryEncOverMCP rotaryEncoders[] = {
// outputA,B on GPA7,GPA6, register with callback and ID=1
RotaryEncOverMCP(&mcp, 7, 6, &RotaryEncoderChanged, 1)
constexpr int numEncoders = (int)(sizeof(rotaryEncoders) / sizeof(*rotaryEncoders));
void RotaryEncoderChanged(bool clockwise, int id) {
Serial.println("Encoder " + String(id) + ": "
+ (clockwise ? String("clockwise") : String("counter-clock-wise")));
void setup(){
Serial.println("MCP23007 Polling Test");
mcp.begin(); // use default address 0
//Initialize input encoders (pin mode, interrupt)
for(int i=0; i < numEncoders; i++) {
rotaryEncoders[i].init();
void pollAll() {
//We could also call ".poll()" on each encoder,
//however that will cause an I2C transfer
//for every encoder.
//It's faster to only go through each MCP object,
//read it, and then feed it into the encoder as input.
for(int j = 0; j < numMCPs; j++) {
uint16_t gpioAB = allMCPs[j]->readGPIOAB();
for (int i=0; i < numEncoders; i++) {
//only feed this in the encoder if this
//is coming from the correct MCP
if(rotaryEncoders[i].getMCP() == allMCPs[j])
rotaryEncoders[i].feedInput(gpioAB);
pollAll();
Thanks,
Daniele.
