ClearPathStepGen.h - Interrupt driven library for Sending High frequency Step signals to Clearpath motors using an Arduino- Version 1
Teknic 2017 Brendan Flosenzier
This library is free software; you can redistribute it and/or
modify it.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
A ClearPathStepGen is activated by creating an instance of the ClearPathStepGen class, and passing the constructor references to the motors it will control.
The motors are pulsed in the background according to move information stored within each motor.
Only motors of type; ClearPathMotorSD may be used.
There can only be one instance of Step Controller at any time.
This class uses Timer2, so other functions and classes which use timer 2 will not work correctly ie: tone(), MsTimer2() etc.
The ISR is set to 2KHz, nominally
Note: Each attached motor must have its direction/B pin connected to one of pins 8-13
other devices can be connected to pins 8-13 as well
Start(time) - gets Direction pins for all connected motors (make sure all motors have been attached before this is called
Configures the ISR to run at 2kHz
Stop() - disables the ISR in this class
#include "Arduino.h"
#include "ClearPathMotorSD.h"
#include "ClearPathStepGen.h"
// Declare Variables used in this class
// They aren't private because the ISR needs to access them
ClearPathMotorSD* _motors[6]; //6 clearpath motor pointers for up to 6 digital pins in PORTB
uint8_t _numAxis=0; //this keeps track of how many pointers are active
uint8_t _BurstSteps[6]={0, 0, 0, 0, 0, 0}; //this is the container for the motors to dump however many steps need to be pulsed
uint8_t _pins[6]={0, 0, 0, 0, 0, 0}; //This holds the port address (Binary) for each motors Step Pin
uint8_t _SUMPINS=0; //This holds the Binary Sum of all active motor Step Pin addresses
uint8_t _OutputBits; //this is the container to write to output PORTB
boolean _flag=false; //This is the flag to show when to finish pulsing the motors
//This is the Interupt Service Routine.
// It asks each motor how many steps to send, and then pulses to PORTB
#if defined(__AVR__)
ISR(TIMER2_COMPA_vect)
#elif defined(__arm__) && defined(TEENSYDUINO)
// discussion about this port for 32 bit Teensy...
// https://forum.pjrc.com/threads/51236-ClearPath-Teknic-servos
static IntervalTimer myTimer;
static void isr()
//Prevent Interupts
cli();
//Turn on pin 2 to see how long the ISR takes
// digitalWrite(2,HIGH);
//Poll all axes to fill BurstSteps[]
for(int i=0;i<_numAxis;i++)
_BurstSteps[i]=_motors[i]->calcSteps();
//loop through BurstSteps decrementing each value to 0
do
_flag=false;
_OutputBits = PORTB; //Read the port
// this is redundant, right?
if(_BurstSteps[0] && _BurstSteps[0]--) //Assume at least one axis is active, and check/decrement BurstSteps
_flag=true;
_OutputBits |= _pins[0]; //Activate the B input for motor 1
if(_pins[1] > 0 && _BurstSteps[1] && _BurstSteps[1]--) //Check if Axis is active, then check/decrement BurstSteps
_flag=true;
_OutputBits |= _pins[1]; //Activate the B input for motor 2
if(_pins[2] > 0 && _BurstSteps[2] && _BurstSteps[2]--) //Check if Axis is active, then check/decrement BurstSteps
_flag=true;
_OutputBits |= _pins[2]; //Activate the B input for motor 3
if(_pins[3] > 0 && _BurstSteps[3] && _BurstSteps[3]--) //Check if Axis is active, then check/decrement BurstSteps
_flag=true;
_OutputBits |= _pins[3]; //Activate the B input for motor 4
if(_pins[4] > 0 && _BurstSteps[4] && _BurstSteps[4]--) //Check if Axis is active, then check/decrement BurstSteps
_flag=true;
_OutputBits |= _pins[4]; //Activate the B input for motor 5
if(_pins[5] > 0 && _BurstSteps[5] && _BurstSteps[5]--) //Check if Axis is active, then check/decrement BurstSteps
_flag=true;
_OutputBits |= _pins[5]; //Activate the B input for motor 6
PORTB = _OutputBits; //Write to the ports
digitalWriteFast(2, (_OutputBits & 1) ? HIGH : LOW);
digitalWriteFast(4, (_OutputBits & 2) ? HIGH : LOW);
digitalWriteFast(6, (_OutputBits & 4) ? HIGH : LOW);
digitalWriteFast(8, (_OutputBits & 8) ? HIGH : LOW);
digitalWriteFast(29, (_OutputBits & 16) ? HIGH : LOW);
digitalWriteFast(38, (_OutputBits & 32) ? HIGH : LOW);
delayMicroseconds(2); //Short Delay
_OutputBits &=63-_SUMPINS ; //Turn off all active pins
// TODO: is a delay needed here for processors much faster than 8 bit AVR ???
} while(_flag);
//turn off debug pin
//digitalWrite(2,LOW);
//allow interupts
sei();
/* This is the minimum constructor for ClearPathStepGen it requires a pointer to one ClearPathMotorSD, or
one ClearPathMotorSD motor. It requires a pointer because this class must use the functions of the
same clearpath object used in the main routine.
This function saves the clearpath pointer, and establishes the pins of said motor
NOTE: the DirPins of the passed motor must be one of pins 8-13
ClearPathStepGen::ClearPathStepGen(ClearPathMotorSD* motor1)
_SUMPINS=0;
_flag=false;
_numAxis=1;
_motors[0]=motor1;
if(_motors[0]->PinB-8 >= 0)
_pins[0]=(1<<(_motors[0]->PinB-8));
_SUMPINS=_pins[0];
/* This is a constructor for ClearPathStepGen, it requires 2 pointer to ClearPathMotorSD, or
ClearPathMotorSD motors. It requires pointers because this class must use the functions of the
same clearpath objects used in the main routine.
This function saves the clearpath pointers, and establishes the pins of said motors
NOTE: the DirPins of the passed motor must each be one different of pins 8-13
ClearPathStepGen::ClearPathStepGen(ClearPathMotorSD* motor1, ClearPathMotorSD* motor2)
_SUMPINS=0;
_flag=false;
_numAxis=2;
_motors[0]=motor1;
_motors[1]=motor2;
if(_motors[1]->PinB-8 >= 0)
_pins[1]=(1<<(_motors[1]->PinB-8));
_SUMPINS=_pins[0]+_pins[1];
/* This is a constructor for ClearPathStepGen, it requires 3 pointer to ClearPathMotorSD, or
ClearPathStepGen::ClearPathStepGen(ClearPathMotorSD* motor1, ClearPathMotorSD* motor2, ClearPathMotorSD* motor3)
_SUMPINS=0;
_flag=false;
_numAxis=3;
_motors[0]=motor1;
_motors[1]=motor2;
_motors[2]=motor3;
if(_motors[2]->PinB-8 >= 0)
_pins[2]=(1<<(_motors[2]->PinB-8));
_SUMPINS=_pins[0]+_pins[1]+_pins[2];
/* This is a constructor for ClearPathStepGen, it requires 4 pointer to ClearPathMotorSD, or
ClearPathStepGen::ClearPathStepGen(ClearPathMotorSD* motor1, ClearPathMotorSD* motor2, ClearPathMotorSD* motor3, ClearPathMotorSD* motor4)
_SUMPINS=0;
_flag=false;
_numAxis=4;
_motors[0]=motor1;
_motors[1]=motor2;
_motors[2]=motor3;
_motors[3]=motor4;
if(_motors[3]->PinB-8 >= 0)
_pins[3]=(1<<(_motors[3]->PinB-8));
_SUMPINS=_pins[0]+_pins[1]+_pins[2]+_pins[3];
/* This is a constructor for ClearPathStepGen, it requires 5 pointer to ClearPathMotorSD, or
ClearPathStepGen::ClearPathStepGen(ClearPathMotorSD* motor1, ClearPathMotorSD* motor2, ClearPathMotorSD* motor3, ClearPathMotorSD* motor4, ClearPathMotorSD* motor5)
_SUMPINS=0;
_flag=false;
_numAxis=5;
_motors[0]=motor1;
_motors[1]=motor2;
_motors[2]=motor3;
_motors[3]=motor4;
_motors[4]=motor5;
if(_motors[4]->PinB-8 >= 0)
_pins[4]=(1<<(_motors[4]->PinB-8));
_SUMPINS=_pins[0]+_pins[1]+_pins[2]+_pins[3]+_pins[4];
/* This is a constructor for ClearPathStepGen, it requires 6 pointer to ClearPathMotorSD, or
ClearPathStepGen::ClearPathStepGen(ClearPathMotorSD* motor1, ClearPathMotorSD* motor2, ClearPathMotorSD* motor3, ClearPathMotorSD* motor4, ClearPathMotorSD* motor5, ClearPathMotorSD* motor6)
_SUMPINS=0;
_flag=false;
_numAxis=6;
_motors[0]=motor1;
_motors[1]=motor2;
_motors[2]=motor3;
_motors[3]=motor4;
_motors[4]=motor5;
_motors[5]=motor6;
if(_motors[5]->PinB-8 >= 0)
_pins[5]=(1<<(_motors[5]->PinB-8));
_SUMPINS=_pins[0]+_pins[1]+_pins[2]+_pins[3]+_pins[4]+_pins[5];
This function sets up the ISR to run at 2kHz if it is passed the value of 249.
It also, rechecks the direction pins of each connected motor
void ClearPathStepGen::Start()
int time = 249; //Set Frequency 2kHz
_SUMPINS=0;
for( int i=0; i<_numAxis; i++)
if(_motors[i]->PinB-8 >= 0)
_pins[i]=(1<<(_motors[i]->PinB-8));
_SUMPINS+=_pins[i];
cli();//stop interrupts
// set up Timer 1
TCCR2A = 0;// set entire TCCR2A register to 0
TCCR2B = 0;// same for TCCR2B
TCNT2 = 0;//initialize counter value to 0
//Set compare match register to time
OCR2A = time;// time should be 249, 1-256 will produce different frequencies
// turn on CTC mode
TCCR2A |= (1 << WGM21);
// Set CS21 bit for 8 prescaler
TCCR2B = 0;
TCCR2B |= (1 << CS01) | (1 << CS00);
// enable timer compare interrupt
TIMSK2=0;
TIMSK2 |= (1 << OCIE2A);
sei();//allow interrupts
myTimer.begin(isr, (float)(time + 1) * 2e-6);
This function disables the ISR so any motor connected will no longer output pulses
The motors should remember what command they were on, but if a move was interuppted
by this function, large accelerations/deccelerations may be experienced.
void ClearPathStepGen::Stop()
// set up Timer 1
myTimer.end();
// This is a debugging function
int ClearPathStepGen::getsum()
return _motors[0]->calcSteps();
