Results 1 to 19 of 19
Thread: Mux encoders?
    Nov 2016
    179
    Mux encoders?
    Hi
    I have to poll way too much encoders so I slowly run out of inputs. I asked myself if there is a way to mux them like I mux e.g. switchbuttons with a 4051?
    I have found this: https://massimoriggi.files.wordpress...encoder_bb.png .. ans tried it out, but somehow it does not work.
    Can some suggest a way to mux encoders?
    20,322
    The easiest "mux" is using a Teensy LC to read several encoders and send the data as serial or I2C communication.
    Nov 2016
    179
    hi,
    hmmm.. I don't know if this could be a problem in the future.. I already need to power a Teensy3.2 and a RaspberryPi from the same source .. if I now add a Teensy LC.. could this lead to problems?
    Germany
    461
    There was a discussion with a working solution recently:
    https://forum.pjrc.com/threads/51002...light=encodersre
    Nov 2016
    179
    BRO!!!!! .. THIS MIGHT SAVE MY LIFE !!! )) thank you!!!
    I will try this out as soon as I am at home. But I wonder about this code here:
    void readInputs(uint8_t i) {
      selectAddress(i);
      delayMicroseconds(50);
      readEnc(i);
    does this delay have to be there? delayMicroseconds(50);
    I would rather have no delays.. can I use millis() here?
    Germany
    461
    I didn't write the linked code but I assume that the delay is meant to wait for the switching time of the used mux but 50Ķs seems to be quite long. Look in the datasheet of the port extender you intend to use, it probably is much faster.
    20,322
    Quote Originally Posted by AdmiralCrunch View Post
    Yes, a delay is always required after switching a mux, because the mux output takes time to change. How much time is a good question. 50 us may be overly conservative. With rotary encoders, the time will depend on the pullup resistors. If you want a faster time, use really pullup resistors between 1K to 3.3K. The ones built into the chip are much higher impedance, so the signal takes longer to change.
    May 2017
    208
    In the linked code, you know what the next value of the variable 'i' is going to be, so you could change that readInputs function to set up the mux address to the next input to be read and reduce or eliminate the delay needed.
      //delayMicroseconds(50);
      readEnc(i);
      selectAddress((i+1)&7);     // only works for 8 inputs
    Nov 2016
    179
    thanks you .. will try this out
    Quote Originally Posted by rcarr View Post
      readEnc(i);
    cool dude .. this is a very nice idea .. will check this out
    Nov 2016
    179
    guys, this works perfectly!! ) thank you so much
    maybe one last question.. how would I decouple this? .. a capacitor to the 4051? or 3k3 resistors from each pin to 5V as pull-ups and one 10nF capacitor from each pin to ground for de-bouncing?
    Apr 2017
    131
    I would recommend looking at the manual for the encoders that you have, they usually have their own recommended schematic for this.
    Nov 2016
    179
    Quote Originally Posted by vjmuzik View Post
    hi, .. I did .. unfortunately for me as a total noob, this is all chinese to me.. :/
    I know that this must be decoupled but i wonder if I should decouple the ICs`? or the encoders itself? or both?
    Apr 2017
    131
    This is more or less the filter circuit that my encoders use. I didnít design that part of the board, but it looks very similar. The board was part of a old Open Labs controller before they went a different direction and stopped making and supporting their controllers. They never released 64 bit drivers for this controller so I repurposed it. I didnít decouple any of the 4051ís on my board, but I canít say wether you should or not I just know mine has worked pretty solid so far.
    Nov 2016
    179
    I use this Encoders here: https://www.amazon.de/gp/product/B00...?ie=UTF8&psc=1
    .. when i used directly on my Teensy, without a 4051, I had inconsistent values.. then I read about decoupling and did it like
    "one 3k3 resistor from each pin A/B to +3.3V as pull-ups and one 10nF capacitor from each pin A/B to ground for de-bouncing".. and this worked perfectly..
    but now I mux them with the 4051s and again I deal with this inconsistent values.. and now I'm asking myself, if I should decouple on the IC-Pins where the Encoder is connected(?) or decouple the IC itself(?)... or both?
    Apr 2017
    131
    Two questions.
    1. Did you make sure to disable interrupts for the encoders?
    2. How long of a delay did you use after switching the mux address?
    Nov 2016
    179
    Two questions.
    1) ehm.. no .. oO .. I did not even know that one could do that(?) oO .. how would I do this?
    2) no delay.. I use rcarr's suggestion for the code..
      readEnc(i);
    Apr 2017
    131
      readEnc(i);
    At the very top of your code before the encoder library is defined you have to
    #define ENCODER_DO_NOT_USE_INTERRUPTS
    And if that still doesnít work you can try to add some delay and see if that fixes it.
    Nov 2016
    179
    And if that still doesn’t work you can try to add some delay and see if that fixes it.
    aaaah okay,.. thank you ) .. I will try this out
