I am trying to conduct an experiment using teensy 3.6 microcontroller and teensy audio board. I have a working code. The circuit was working perfectly till yesterday. But today when I plug in the usb from laptop to the microcontroller, the led indicating that the microcontroller is powered does not glow. I checked voltage at the Vin and 3.3V pin. It gives the required output. But the system doesn't work, even though the code is successfully uploaded. I tried changing the usb cord as well. What do I do next?
Thank you.
Anagha
Thank you.
Anagha
