phillipps76
What pins do I need to wire between a Teensy 3.6 and an OctoWS2811 to simply use the onboard 74HCT245 -- assuming they are not stacked together?
I have a Teensy 3.6 with an audio board attached and from what I have read it's not easy to use both boards together but the OctoWS2811 seems like a very nice implementation of a 74HCT245. It's a lot cleaner than the one i built using a terminal block for the strips.
My plan is to relocate the LED pins to the other end of the teensy. Besides VIN, GND and 3.3 do I need to connect anything else to get the Octo to work as a simple level shifter?
