Just got a 3.2 and have the Arduino and Teensy loader installed. I'm looking to make some keyboard inputs on button pushes. There is an example program called Buttons which looks to be just what I need but it isn't working correctly. After loading it immediately inputs the rising edge text:
After that putting ground on any of the buttons does nothing. Here is the code in question:
The Blink code works and the keyboard Simple code works.
ease
B7 release
B8 release
B9 release
B0 release
B1 release
B2 release
B3 release
B4 release
B5 release
/* Buttons to USB Keyboard Example
You must select Keyboard from the "Tools > USB Type" menu
#include <Bounce.h>
// Create Bounce objects for each button. The Bounce object
// automatically deals with contact chatter or "bounce", and
// it makes detecting changes very simple.
Bounce button0 = Bounce(0, 10);
Bounce button1 = Bounce(1, 10); // 10 = 10 ms debounce time
Bounce button2 = Bounce(2, 10); // which is appropriate for
Bounce button3 = Bounce(3, 10); // most mechanical pushbuttons
Bounce button4 = Bounce(4, 10);
Bounce button5 = Bounce(5, 10); // if a button is too "sensitive"
Bounce button6 = Bounce(6, 10); // to rapid touch, you can
Bounce button7 = Bounce(7, 10); // increase this time.
Bounce button8 = Bounce(8, 10);
Bounce button9 = Bounce(9, 10);
// Configure the pins for input mode with pullup resistors.
// The pushbuttons connect from each pin to ground. When
// the button is pressed, the pin reads LOW because the button
// shorts it to ground. When released, the pin reads HIGH
// because the pullup resistor connects to +5 volts inside
// the chip. LOW for "on", and HIGH for "off" may seem
// backwards, but using the on-chip pullup resistors is very
// convenient. The scheme is called "active low", and it's
// very commonly used in electronics... so much that the chip
// has built-in pullup resistors!
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP); // Teensy++ LED, may need 1k resistor pullup
pinMode(7, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
// Update all the buttons. There should not be any long
// delays in loop(), so this runs repetitively at a rate
// faster than the buttons could be pressed and released.
button0.update();
button1.update();
button2.update();
button3.update();
button4.update();
button5.update();
button6.update();
button7.update();
button8.update();
button9.update();
// Check each button for "falling" edge.
// Type a message on the Keyboard when each button presses
// Update the Joystick buttons only upon changes.
// falling = high (not pressed - voltage from pullup resistor)
// to low (pressed - button connects pin to ground)
if (button0.fallingEdge()) {
Keyboard.println("B0 press");
if (button1.fallingEdge()) {
Keyboard.println("B1 press");
if (button2.fallingEdge()) {
Keyboard.println("B2 press");
if (button3.fallingEdge()) {
Keyboard.println("B3 press");
if (button4.fallingEdge()) {
Keyboard.println("B4 press");
if (button5.fallingEdge()) {
Keyboard.println("B5 press");
if (button6.fallingEdge()) {
Keyboard.println("B6 press");
if (button7.fallingEdge()) {
Keyboard.println("B7 press");
if (button8.fallingEdge()) {
Keyboard.println("B8 press");
if (button9.fallingEdge()) {
Keyboard.println("B9 press");
// Check each button for "rising" edge
// Type a message on the Keyboard when each button releases.
// For many types of projects, you only care when the button
// is pressed and the release isn't needed.
// rising = low (pressed - button connects pin to ground)
// to high (not pressed - voltage from pullup resistor)
if (button0.risingEdge()) {
Keyboard.println("B0 release");
if (button1.risingEdge()) {
Keyboard.println("B1 release");
if (button2.risingEdge()) {
Keyboard.println("B2 release");
if (button3.risingEdge()) {
Keyboard.println("B3 release");
if (button4.risingEdge()) {
Keyboard.println("B4 release");
if (button5.risingEdge()) {
Keyboard.println("B5 release");
if (button6.risingEdge()) {
Keyboard.println("B6 release");
if (button7.risingEdge()) {
Keyboard.println("B7 release");
if (button8.risingEdge()) {
Keyboard.println("B8 release");
if (button9.risingEdge()) {
Keyboard.println("B9 release");
