I’m running a Teensy 3.2 and using a LT1009 as an external 2.5V reference as per the first circuit diagram in the 1009 data sheet.
http://www.analog.com/media/en/technical-documentation/data-sheets/1009ff.pdf
In regard to the ground, I have three choices but not sure which one is correct or I should use:
1. Ignore AGND and just run the reference ground tho the common Teensy ground;
2. Just run the reference ground to AGND; or
3. Run the reference ground to both AGND and the common Teensy ground?
I currently doing it as per option 1. but not sure this is the best method.
Any guidance would be appreciated.
