ooelectronoo
i am having an issue with liquid crystal serial output from gps. this is the example code from the library timegps with liquid crystal spliced in where i thought it should go based on my very rough understanding.
I am not new to coding, I'm just not very good at it. this is on a teensy3.1 so i can learn and also i don't need that much brain power or speed for this first iteration. i am just trying to learn and also use what i have atm. Once i get this working i will start to change it to see if i can get more information displayed and or add hardware to change info displayed ( like button trigger to change info)
gps module:Adafruit Ultimate GPS Breakout V3
teensy 3.1
16x2 lcd white on blue
everything is wired up correctly, i can run hello world and i also get the gps d&t on the monitor.
p.s. i could have some names wrong i.e. lcd is looking for the wrong serial output?
edit. To whom it may concern, i confirm that mcafee does not play nice with the Arduino ide.
teensy 3.1
* TimeGPS.pde
#include <TimeLib.h>
#include <TinyGPS.h>
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
TinyGPS gps;
#define SerialGPS Serial1
// Offset (UTC)
const int offset = -5; // dst
//const int offset = -6; // cst
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// Ideally, it should be possible to learn the time zone
// based on the GPS position data. However, that would
// require a complex library, probably incorporating some
// sort of database using Eric Muller's time zone shape
// maps, at http://efele.net/maps/tz/
time_t prevDisplay = 0;
lcd.begin(16, 2);
SerialGPS.begin(9600);
Serial.println("Waiting for GPS time ... ");
while (SerialGPS.available())
if (gps.encode(SerialGPS.read()))
unsigned long age;
int Year;
byte Month, Day, Hour, Minute, Second;
gps.crack_datetime(&Year, &Month, &Day, &Hour, &Minute, &Second, NULL, &age);
if (age < 500)
setTime(Hour, Minute, Second, Day, Month, Year);
adjustTime(offset * SECS_PER_HOUR);
if (timeStatus()!= timeNotSet)
if (now() != prevDisplay)
prevDisplay = now();
digitalClockDisplay();
if (Serial.available())
lcd.clear();
while (Serial.available() > 0)
lcd.write(Serial.read());
void digitalClockDisplay()
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
void printDigits(int digits)
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
