PI hat skywriter help
Update
Using an Arduino uno it works!
but not with a teensy 3.2
here is the sample code
#include <skywriter.h>
#define PIN_TRFR  2    // TRFR Pin of Skywriter
#define PIN_RESET 3    // Reset Pin of Skywriter
/////////////debugleds///////
int led10 = 10;
int led11=11;
int led12= 12;
int led13 =  13;
long touch_timeout = 0;
int air_wheel_counter = 0;
  Serial.begin(57600);
pinMode(led10,OUTPUT);
pinMode(led11,OUTPUT);
pinMode(led12,OUTPUT);
pinMode(led13,OUTPUT);
  Skywriter.begin(PIN_TRFR, PIN_RESET);
  // Bind skywriter events
  Skywriter.onTouch(touch);
  Skywriter.onAirwheel(airwheel);
  Skywriter.onGesture(gesture);
  Skywriter.poll(); // Poll for any updates from Skywriter
  if( touch_timeout > 0 ) touch_timeout--;
void enter(){
void gesture(unsigned char type){
  switch (type){
    case SW_FLICK_WEST_EAST:
 Serial.println(" SW_FLICK_WEST_EAST");
 digitalWrite(led10,HIGH);
 delay (100);
           digitalWrite(led10,LOW);
    case SW_FLICK_EAST_WEST:
       Serial.println(" EAST_WEST");
       digitalWrite(led11,HIGH);
       delay (100);
           digitalWrite(led11,LOW);
    case SW_FLICK_SOUTH_NORTH:
     Serial.println(" SOUTH_NORTH");
     digitalWrite(led12,HIGH);
     delay (100);
           digitalWrite(led12,LOW);
    case SW_FLICK_NORTH_SOUTH:
     Serial.println("NORTH_SOUTH");
     digitalWrite(led13,HIGH);
     delay (100);
           digitalWrite(led13,LOW);
void airwheel(int number){
  if( air_wheel_counter > 5 ){// Prevent the command being run excessive times for negligible difference
    if( number > 0 ){ // If the wheel's going in the "increase" direction
    else{
  else{
    air_wheel_counter++;
  touch_timeout = 10000;
void touch(unsigned char type){
  /*Serial.println("Got touch ");
  Serial.print(type,DEC);
  Serial.print('\n');*/
  if( touch_timeout > 0 ) return; //Ensure that falsely detected touches within a small time interval of a real touch are ignored
  switch (type) {
    case SW_TOUCH_WEST:
      Serial.println("SW_TOUCH_WEST");
    /* Launch selective area screenshot
     * Alt-; is the keyboard shortcut I have it bound to
    case SW_TOUCH_SOUTH:
     Serial.println("SW_TOUCH_SOUTH");
    /* Launch spotify web player
     * Switch to chrome, open new tab, and start typing URL
    case SW_TOUCH_NORTH:
    Serial.println("SW_TOUCH_NORTH");
    /* Launch facebook messenger
    case SW_TOUCH_EAST:
     Serial.println("SW_TOUCH_EAST");
Your github link didn't work, here it is: https://github.com/pimoroni/skywriter-hat/tree/master/arduino/Skywriter
Looks like it uses Wire, are you using pins 18 and 19 of the 3.2? by default, those are the Wire pins. You should also call Wire.begin() in setup().. :)
EDIT: sorry the source code already calls Wire.begin();, check pins 18 & 19? You must also use pullups for I2C! without it, it wont work on teensy...
EDIT2: Just for the curious on logic level:
The Skywriter ( full sized ) has an onboard 3.3v low dropout regulator, so it’ll work with either a 5V or a 3.3V power supply. All of the data lines are level shifted, so they’ll also be fine.
Thanks!!
regarding Pullups is 1k a good value or less?
