Totally inexperienced noob here.
I've been putting together a midi project with a TeensyLC. Initial plug in the board blinked. Then I did a bunch of soldering and a some desoldering and re-soldering. Now I try and upload the code I'm going to use and the board's led flashes briefly then doesn't come back on. I'm unable to upload anything to the board.
I measured the voltage across 5v and 3.5v witih a multimeter and both are reading just under 1v. I checked it wasn't the multimeter by double checking an arduino uno I had kicking around and the voltage pins on that read as expected.
Do you think I've fried the board, or is it likely there's some crappy soldering and trying to rework the connections may help?
