I have connected the DAC outputs to galvanically isolated 4 to 20 mA converters, which are loop powered. Thus the converter only needs a voltage between 0.5 and 2.5 VDC from the DAC as an input and will control the output between 4 and 20 mA. The measured resistance of the input is 2.7 kOhm. Measuring the output at the DAC's without the converter connected I can generate 0 to 3.3 VDC.
The problem I encounter is, that the voltage levels out at about 1.36 VDC, when the converter is connected, as if the DAC cannot drive more than about 0.6 mA into the input. Can anybody confirm that?
