Results 1 to 3 of 3
Thread: not recording
    not recording
    HI everyone - the code used to record and I have changed something and now it is not recording to the SD card even though it is printing out that it is doing so - can anyone see why this is the case?? thanks in advance - here is my code. I wonder if the file name is too long? but I am thinking it is something re the 512 buffer which I read was the most efficient way too do this? Happy to have feedback and another set of eyes - I just can not find where this is Brocken. thanks heaps
    [ CODE]
    #include <TimeLib.h>
    #include <TimeAlarms.h>
    AudioInputI2S i2s1; //xy=202,157
    AudioRecordQueue queue1; //xy=481,150
    AudioConnection patchCord1(i2s1, 0, queue1, 0);
    AudioControlSGTL5000 sgtl5000_1; //xy=279,278
    #define SDCARD_CS_PIN 10
    #define SDCARD_MOSI_PIN 7
    #define SDCARD_SCK_PIN 14
    const int myInput = AUDIO_INPUT_MIC;
    String recordingName = "Rec01";
    int recordingCount = 0;
    File frec;
    // setTime params: hr, min, sec, day, month, year
    setTime(18, 05, 0, 5, 5, 18);
    // Alarm each 10 minutes. startRec() will record
    Alarm.timerRepeat(600, startRec);
    AudioMemory(60);
    sgtl5000_1.enable();
    sgtl5000_1.volume(0.5);
    // Initialize the SD card
    SPI.setMOSI(SDCARD_MOSI_PIN);
    SPI.setSCK(SDCARD_SCK_PIN);
    while (!(SD.begin(SDCARD_CS_PIN))) {
    Serial.println("Unable to access the SD card - retry in 10 seconds");
    delay(10000);
    delay(2000);
    startRec();
    //digitalClockDisplay();
    Alarm.delay(1000);
    // Record ten seconds of audio
    // While this is recording the clock display will stop
    void startRec() {
    byte buffer[512];
    Serial.println("Start Rec");
    recordingCount++;
    String rec = recordingName + "_" + recordingCount + "-" + hour() + ":" + minute() + ":" + second() + "_" + day() + "-" + month() + "-" + year() + ".RAW";
    Serial.println("RecName: " + rec);
    frec = SD.open(rec.c_str(), FILE_WRITE);
    queue1.begin();
    // 31007 is the number of buffers to make 44100 samples/sec for 3 min at 256 buffer size
    // calculate ((Min*60) * (SampleRate 44100))/bufferSize 256
    for (int i = 0; i < 51680; i++) {
    memcpy(buffer, queue1.readBuffer(), 256);
    queue1.freeBuffer();
    memcpy(buffer+256, queue1.readBuffer(), 256);
    // write all 512 bytes to the SD card
    frec.write(buffer, 512);
    stopRec();
    void stopRec()
    Serial.println("Stop Rec");
    queue1.end();
    frec.close();
    void digitalClockDisplay() {
    // digital clock display of the time
    Serial.print(hour());
    printDigits(minute());
    printDigits(second());
    Serial.print(" -- ");
    // Serial.print(day());
    // printDigits(month());
    // printDigits(year());
    // Serial.println();
    void printDigits(int digits) {
    Serial.print(":");
    if (digits < 10)
    Serial.print('0');
    Serial.print(digits);
    [/ CODE]
    2,366
    Quote Originally Posted by garthpaine View Post
    you should only read from queue if there is a buffer available (or did I miss the line?)
    There is a byte buffer[512]; just at the top of startRec() I did wander if this needs to be refreshed in the loop during recording or not?
Tags for this Thread
