Results 1 to 6 of 6
Thread: Teensy 3.6 and RTC date and time not ok when power lost.
    May 2018
    16
    I have a Teensy 3.6 with a battery, when i reset the Teensy, the clock is ok.
    When i lost the power, the time is from te HEX file?
    Also with the Example "TimeTeensy3" what is this???
    Thanks.
    2,557
    as forum rule states: please post complete source code ...
    you probably need setSyncProvider(getTeensy3Time);
    see https://forum.pjrc.com/threads/43336...sy-3-6-and-RTC
    this question has been asked and answered on the forum often.
    May 2018
    16
    Yes, this is into the setup loop "setSyncProvider(getTeensy3Time);"
    How can the rtc time to the hex time ?
    Thanks.
    22,272
    Quote Originally Posted by Stanleyvc View Post
    The RTC is supposed to keep time as long as 3V remains on the VBAT pin.
    If you disconnect power from VBAT, then next time you boot the RTC is uninitialized. The time you compiled the code is used as a default, because no other info is available. If you have access to accurate time, you can use the functions to set the time.
    May 2018
    16
    Thanks Paul,
    Is the rtc state or \ and the vbat reading in the source?
    Thanks.
    May 2018
    16
    The battery house was the problem, not good connection.
