Results 1 to 4 of 4
Thread: Which transistor to use?
    May 2018
    5
    Hi there,
    i want to control a LED strip which uses 12V. Each color got it's own power lane, so with PWM i should mix the colors i want.
    However i'm wondering which transistor i should use which i can hook up the the teensy (3.3V out afaik) and can handle the 12V.
    Unfortunalety i have not much electritian knowledge so i'm asking you, if you can recommend any transistor that fits in my case.
    I read a whole bunch of datasheets but due to my limited knowledge i don't really know which transistor can be used.
    Feb 2017
    368
    I've used this MOSFET from Adafruit successfully:
    https://www.adafruit.com/product/355
    They also have a tutorial:
    https://learn.adafruit.com/rgb-led-strips?view=all
    Dec 2016
    Montreal, Canada
    3,267
    you can also get the RFP30N06LE from adafruit, dont forget to get 10K ohm resistors for your mosfets
    21,473
    If you're controlling many of these 12V LED strips, these inexpensive boards usually end up costing less than you can even buy the bare transistors.
    https://www.amazon.com/CHINLY-channe.../dp/B01MG9KYCD
    https://www.ebay.com/itm/30Channel-3...V/291695075649
    https://www.aliexpress.com/item/30-c...333091413.html
    The good news is you can very easily transmit DMX from Teensy 3.x using the serial ports. Serial1 & Serial2 are best because they have the FIFOs, for fewer interrupts.
Tags for this Thread
